Hello All, Thanks for the comments and Likes, as always very much appreciated.
I Did have a Picture before the Cannon Balls and Painting.. Bloody SD card on the phone has come corrupt.
Used a Fridge Magnet to stock pile the cannon balls.
Edited by Rich.f
Rich.
Builds in Progress:   HMS Victory
Completed Builds:   Constucto Enterprise
Future Builds 2021/2022 USS Constitution
Today. Nice sunny day,  ( in the UK)
I fine sanded the Port Side Hull and Spayed it copper.
After a few hours of other ship duties and part building, I sat down to start the copper tiles...
And this happend>>
Any Suggestions< ?
Rich.
Rich,
That is extremely unfortunate!!! :( Was that a water based paint? It looks like the wood swelled on you. I am assuming its the same paint you used on the other side, what did you do different? Maybe let it sit overnight and see what it does? If it stays like that it looks like you're re-sanding unfortunately. Hopefully somebody has a better suggestion.
Sam
Current Build Constructo Enterprise
Hi Rich
What a shame. It certainly looks like the wood has swollen with water from the paint. Looks like a rub down and fill job. I know its a bit late but when I did mine hull i primed it with Dulux acrylic primer first so as to seal the filler and minor gaps and rubbed it down ready to paint. I think that would be a way forward.
This ship building is supposed to be fun but sometimes I do wonder.
It will all be OK in the end and nobody will know about the trouble you had (Except us fellow sufferers)
Hi guys,
Not sure if it was water base paint.. the hull was primed with while paint first..
bloody frustrating. oh well.
Is it worth coving the hull in pva, sand and fill. Then resand??
Rich.
Is it possible that the planks have curled across their width? That would suggest the wood was too wet for too long and the wood absorbed the water and swelled  the grain unevenly hence the curl  it could have been damp timber where was it stored ? I would try PVA  brushed into the cracks which should get into the cracks and stick them to the first layer of planking. When dry apply a watered down coat over alI. Then I would fill it and sand it and apply an acrylic primer and rub that down and re prime until you are happy with the finish. It all gets cover in tiles so it doesn't matter what it looks like.
I have PVA/Wood Glue, the hull, tonight i'm going to sand it, then fill it.
I have finished for now, the upper gun fixings and the steps to the lower deck. I'm not going to add these until i have finished the hull copper plating.
Rich.
After gluing the hull, filling sanding and repainting>
I have tarted the copper plates, and I must say they have gone on with ease, probably because I know how to fit them, need more practice mind you..
From the center out 10 tiles each way.
Rich.
Hi
I've never done this coppering... but it Looks very good. Perhaps I will dare some day to build a model with a coppered hull...
Go on this way - its very nice
Cheerio
Max
Next: Friedrich Wilhelm zu Pferde by Euro Model 1:47
Finished: Half Moon Corel;  HMY Royal Caroline Panart; HMB Endeavour Occre 1:54; Fregatte Berlin, Corel, 1:40
A life without dogs is possible... but worth to live?
Hi Max,
Thanks for stopping by,
I have had fun with the copper plates and I really don't want to do it again... Its been a challenge
Rich.
I have Run out of copper ties this is due to the problems at the start so ill up dat again soon when they have arrived and made more progress.
Rich.
Well Progress has been rather rapid this week and I Must say, I have taken a bit not note from Roberts Log, ((Thanks)) LOL
Every thing also just slipped in to place, To the point I am at the point to I rip off the side I have completed and do it the same as I am doing.
The cost of 1500 tiles are about £40. ($60). But Not sure.. time will tell..
Rich.
Thanks Guys.
Need about 300 more tiles to complete this side.. Almost done Ill upload Picture Monday. Still Unsure if to redo starboard side?
Hmm..
Rich.
Rich,
I try to find out what is wrong but I can not see it !
It looks great !
And don't forget, when the hull is done, you have to look at the total pictures when she is on the standard......
Sjors
A very thin strip to cover the very top of the plating painted black. I've attached a picture of the has trincomalee where you can see it clearly. I added this to my HMS Diana model also and just finishes it off. Then if there are any small gaps between the plates just touch up with a bit of copper paint.
Anton T
Current build
1/78 Sovereign of the Seas - Sergal - kit bashed
1/72 Arleigh Burke class DDG flight iia/iii - Sratch built RC - no log
Waiting for further inspiration
STS Leeuwin II 1/56 scratch built (90% completed)
Previous builds - completed
1/72 HMAS Brisbane, Airwarfare Destroyer 2014 -Scratch built RC - completed
1/64 HMS Diana 1796 - caldercraft kit - completed
1/75 Friesland 1668- mamoli kit - completed
1/96 HMAS Newcastle FFG 2011- scratch built RC - completed
1/75 Vasa - Billing Boats - completed
Hi Guys,
Sam, Just wanted to have a sharper line,
Anton, Thanks very much for that.  I think I have read do that somewhere before.
I have a few Ideas running around the head now!
Rich.
