Continuation
Best regards,
Garward
Is under construction Montanes
Ready models Golden Star Corsair San Francisco II
Bronze 24-pdr canone Le Fleuron
Bronze 24-pdr canone Le Fleuron (second version)
Continuation
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
Best regards,
Garward
Dida:
When soldering the deadeye strops, do the soldering before the deadeyes are inserted. That way, they do not get burned. The strops should be flexible enough after annealing and soldering that you can easily slide the deadeye into the strop and then squeeze the strop around the deadeye.
Russ
Dida,
I had that, burning the brass, once with the deadeyes, but I diminished the flame and it worked well after that.
Carl
Dida,
Karl, not only you burned brass when I started soldering with a gas torch, at me it too sometimes occurred  :)
Best regards,
Garward
  • 9 months later...
Continuation
Hi Garward. Nice work sir and was wondering how do you make the round dome heads on the bolts?  Do you have a jig and is it possible for you to show how you make other metal fiitings also for your works? Am very interested in how the good folks of the site make different item's in metal and yours are high on my list. Thank you sir. Gary
I use a simple soldering iron - solder melts at an ideal temeperature of around 270C for soldering based my process control days in electronics for a lead solder, never used a flame yet and soft solder holds well enough if spotlessly clean before hand.
Norman
Norman
Current build Trumpeter Arizona 1:200 with White Ensign PE and a Nautilus Wooden Deck.
Built Caldercraft Convulsion, HM Brig Badger and HMS Snake.
Awaiting - Zvelda HMS Dreadnought planning to get the Pontos Deck and PE Upgrades, Panart 1:23 Gun deck model and couple of the cannon kits Manatu - French siege mortar, and American coastal cannon.
Echo that Garward
we're waiting for your next tutors....
