I can't find any scale nautical figures for a 1:90. Are all ships lifeless? (edited by admin)
I can't believe that after extensive online searching I can't find any scale nautical figures for a 1:90 scale ship model I am finishing.  Does anyone know of a source for appropriate scale figures for period wooden ships?  Help!!
Part of the problem is the rather odds scales, like your 1/90th scale, that model companies make their kits in. Marketing tells manufacturers that the average ship kit-builder is looking for something about "x" inches long that will fit a display table about "y" inches long. Therefore, they scale their vessel down to fit the desired size, and in so doing, they end up with some pretty strange scales, to be sure. (This I got from the manager of the long-gone Sarasota Model Expo Store.) That also makes it hard to find replacement cannon, etc., should the kit be lacking.
But you're close to 1/87th scale, which I believe is a common railroad modeler scale, (HO Scale - yes?), so you might find conductor and townsfolk figures to start with, should you want to modify them to look like sailors.
Edited by uss frolick
Thank you for the input.  I ended up buying a bunch of HO scale sets from which I modified several figures.  I guess the 1:90 scale is a bit of an oddball but i've never really seen nautical figures in any scale.
I believe Artesenia Latina now offer 1/84 crew figures as part of their fittings range.
Kind Regards
Nigel
Currently working on Royal Caroline
Hi Mike,
you may want to look into scale 1:87 (common H0 model Train scale), search for sailors or ships Crew. I have not found figures in 1:87 for historic 18th century on the web yet.
Nils
Current builds
-Lightship Elbe 1
Completed
Hi
At the request of my son I am going to try to crew the HMS Surprise I am building. Had locating anything but found a company that does 20 mm war gaming naval Napoleonics. At 20 mm that should roughly be around 1/87. Not convinced that the look quite right for the size of the build but the figures themselves are pretty well made and have posted some.
Web site
http://newlinedesigns.co.uk/index.php?main_page=index&cPath=410_415_428
Edited by Waitoa
