Thanks for the props Brian and all the likes. Working on the hammock stanchions. Started with 18 gauge copper wire, hammered it flat, measured to the appropriate length, bent it to the appropriate 90's and blackened. CA'd the stanchions to the main rail. Also finished the bell and Sampson post.
Anchors pretty much done. Used some weather-it on the wood from my model railroading days. Also added some brass strips around the wood. If you have not seen it this Solder-it is awesome. A mixture of flux and solder and melts at 420 degrees. Makes brass work easy.
Edited by Carlmb
