1.8 . Imitation of nails
Imitation of nails is executed from a brass wire of 0,5 mm by means of a self-made mini-drill (the DPM motor in the case from cases for a film + the boss with grips) with a drill of 0,5 mm and side-cutting pliers.
Best regards,
Garward
Is under construction Montanes
Ready models Golden Star Corsair San Francisco II
Bronze 24-pdr canone Le Fleuron
Bronze 24-pdr canone Le Fleuron (second version)
Great job! Much accuracy!
Thanks for the comment!
Best regards,
Garward
Continuation
Before continuation of further works on the hull the sheeting is put on its lower part - two layers of shellac.
Best regards,
Garward
Continuation
Rubbing piece and covering from ebony fine line are covered with a black pigment.
Best regards,
Garward
1.9 . Figured levels for rubbing piece and guard rail
Levels are made of a pear on the MF-70 Proxxon milling machine by means of extras - a laid on little table (brass of 6 mm, fastens in grooves of a coordinate table) and self-made figured mills (from nails with a diameter of 3 mm).
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
Figured curves of the ends of guard rail are made of a pear.
Best regards,
Garward
Continuation
 Guard rail is established on the hull.
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
Decorative rubbing piece are established.
Best regards,
Garward
1.10. Channel board
Channel board are made of a plate, glued of 4 layers of an interline interval of ebony. Plywood bracket from a kit are replaced by the wooden.
Best regards,
Garward
Continuation
Best regards,
Garward
Garward,
This really is a great log, and I'm happy to see it back again, and you! Hope you find the time to put your other logs back on.
Carl
Garward,
Hi, Carl, thanks for an assessment! Yes, I plan to restore gradually the main reports on the models, published earlier on MSW.
Best regards,
Garward
1.11. Manufacturing samson post
Best regards,
Garward
Continuation
Best regards,
Garward
1.12. Fore body of the hull
Installation of details of fore body of the hull.
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
Best regards,
Garward
Garward, This posting is excellent as is the quality of the model. Thank you for (re)sharing this with us.
I am about to produce samson posts for my ship. What type of wood did you use?
Ian M.
Ian M.
Current build: HMS Unicorn  (1748) - Corel Kit
Advice from my Grandfather to me. The only people who don't make mistakes are those who stand back and watch. The trick is not to repeat the error.
Ian M.
I tried to do samson posts of different breeds of wood, but stopped on a pear.
Best regards,
Garward
1.13. Сontrol blade
Loops of a control blade are made of a brass foil of 0,5 mm and a wire of 1,5 mm; PV 209 gumboil, PSR 40 silver solder.
Best regards,
Garward
Continuation
Best regards,
Garward
1.14 . Production of imitation of cannon hooks and eyes
The brass foil 0,3 mm thick, wire of 0,75 mm, rubber lining and drill shaft for foil punching is used.
Best regards,
Garward
Continuation
Best regards,
Garward
Hello Garward and welcome back!
That's a huge amount to repost. Good luck with that. Just take your time.
Take care,
Anja
Those we loved but lost are no longer where they were, but are always where we are.
In the gallery: Albatros 1840 - Constructo
Always a pleasure to follow your build log, Garward.
I wonder if I would ever be able to work with metal, especially with such tiny pieces.
Thank you - spasiba
Nelu A
The shipbuilder without patience is like the ship without an anchor.
Completed build: SAINT JOHN THE BAPTIST by Mioriticul – D’Agostini (AL) – scale 1:50 – first wooden ship model
Take care,
Anja
Good evening, Anja! Thanks for care about we wash health, I considered it and have just supper and now with new forces I will continue :) . Work at the computer to me is very habitual and at all I don't strain, at the same time I also systematize available information. That I already published on Montanes on new MSW - only small part of the previous publications. Therefore while there is time and opportunity I try to restore a new forum to a look habitual for us.
Best regards,
Garward
