Thanks for all the input here Jpett,
Well after our talk yesterday Iwent ahead ad removed the battens. This ended up in about an hour worth of repairs and sanding.
Now I measured the g bulkhead and still only make 15 strakes, then I spent the rest of the day pondering why i have 40,3/32 decking pieces in the kit, i went back and read the directions only to seemingly infer some of these can be used for strakes.This revelation sent me on another tangent, so I went and looked at the link you supplied and then decided to try something , if it worked great if it didnt I would only be out a few pieces of decking.
What i did was take two 5/32 plankes and line them up on the keel. This allowed me to uses the width of the garbord to then follow the curve of the rabbet.After checking for trueness and triming , I soaked it in hot water and then pinned it into place.It worked like a charm. Now I have a dried fair garboard that I can now easily leave in place without gluing and work on the next strake. I am going to attempt this for the first section, and when I am happy with it then go back and glue them all before I move on.
Incidentally, if i used the 3/32 planks I would come up with 18 strakes not including the garbard qnd wale lines.post-15856-0-75374900-1417585246_thumb.jpgpost-15856-0-54795300-1417585272_thumb.jpg
Edited by RevKB
"Smooth seas make for poor sailors"
"Hebrews 6:19  Which hope we have as an anchor of the soul, both sure and steadfast..."
In His Dust RevKB
RattleSnake Build
http://modelshipworld.com/index.php/topic/8288-rattlesnakecormorant-by-revkb-1780-1786/?p=246048
Just found your build log Kenny. The Rattlesnake is one of the ships I have always wanted to build. Looking forward to following along.
Jesse
 Current build: Syren : Kit- Model Shipways
Side project: HMS Bounty - Revel -(plastic)
On hold: Pre-owned, unfinished Mayflower (wood)
Past builds: Scottish Maid - AL- 1:50, USS North Carolina Battleship -1/350  (plastic),   Andromede - Dikar (wood),   Yatch Atlantic - 14" (wood),   Pirate Ship - 1:72 (plastic),   Custom built wood Brig from scratch - ?(3/4" =1'),   4 small scratch builds (wood),   Vietnamese fishing boat (wood)   & a Ship in a bottle
Howdy Scott, so far it seems to be working fine . I am in the process of adding strakes now and am up to the third one above the Garboard. one thing I found was that I went a little to far the other way from your suggestion to not allow the garboad to rise up the keel. I took the over cautious rout and ended up having to spill the second strake up in order to make it back to true on the hull.
I will post pictures tomorrow if I can . I have found that the planking plans are a little confusing to me with all the measuring and strips. I also find that out of three different directions they all come at it differently. So I decided to employ my experience to the wood and only time will tell if it was the wise choice.
I will say this , that oddly enough this is very relaxing to work on these planks , Im not finding it the problem child of the ship modeling .
Time will tell, but so far Im having a blast, and that's what truly counts in the end right?
In His Dust RevKB
RattleSnake Build
Ships log,
After spending time reading and re-re-re-re-reading the planking instructions I found myself confused and a little hesitant on trying to attempt the planking of my snake the ways they were instructing, mostly because of their differing approaches on how to do it . I also came to the realization that the RS instructions are unique to this hull and the practicums were on different hulls, I know that the methods were the same but none of them could reconcile what I knew from experience. So with the practicums echoing in my mind ( I know they really had room to echo) I decided to embark into the saw dust.
As shown above I measured and cut out the Garboard plank and placed it into Very Hot water so that I could make a wet set . I like this method as it lets the board dry in place before gluing and allows you to fine tune it easier than fighting to keep it in place. For all of my soaking I use a Voss wide mouth water bottle filled all the way to the top. I let the planks soak only about 5 mins as any longer makes the wood swell to much and no further pliability comes as a result.
Here you can see the Garboad plank is bent to the shape of the hull
One thing I took to the extreme cost me in having to spill the third strake downward and that was not allowing the garboard plank to naturally ride up the Stem, I was overly mindful to keep it flat and level along its length.Now I took all of your advise in not letting the Garboad go too far up the stem and yet didn’t realize that it can naturally ride up instead of staying flatt. If you look closely you will notice the third plank in the middle is only 3mm while in the stern and stem it is 5mm. It took some extra work  to make it fair for the future planks and was well worth the effort.
This is where I had an apostrophe, I knew I was going to have a measurement problem going from stern to stem. I knew I couldn’t have the planks less than half of their width , and my sample planks shwed me I would be way over that it I didn’t have exact measurements. But how could I have exact measurements to use the planking fan unless I had something to measure against? The battons / lines I had placed on the hull were not exact and I found others troubles with them to be of no use on how to solve this issue so  It dawned on me now that I had the three planks in at the keel and they were fixed , I needed another fixed position to measure against . that being the wale line > it was time to place the wale line .post-15856-0-65209600-1418414398.jpg
So I wet set the wale plank and took exact measurements to assure fairness on both sides, I let it set over night to dry and marked each bulkhead to assure their proper gluing in place, I then glued them with wood glue to allow me to fine tune them into position.
The end result was a flowing wale plank down the length of the hull and their measurements were right on the money. Over all I am very pleased at how they came out and look forward to trying the planking fan now that I have something to measure against.
This concludes my ships build log for December 12, 2014
Edited by RevKB
In His Dust RevKB
RattleSnake Build
Ken,
Yes, I too had real concerns and intrepidation on the various planking instructions.  I found three and eventually settled on one.  Of course my planking did not come out 100% like the instructions said they would but I was able to wing it enough, take my time, measure twice, three times, more, cut once and then sand down to shape.  Was it easy?...... no.  Did I have to pull a plank or two off once the glue had dried when I had the Oh S*&t moment,  You betcha.  All I can say, is what I just did above.  Fortunetely MS gives you extra pieces of wood to accomidate those note so perfect moments.  No rush.  Remember, you can always sand a piece down but you can't build it up.
Edited by scott larkins
Ahoy Ken :D
If it makes you feel any better I went through a "boat load" of wood. Remade some planks four or five times. My local hobby store carried the same wood and I bought quite a bit of it.  I found the challenge of fitting planks very therapeutic and totally enjoyed the experience.  I also found the wood the hobby store sold to be of much higher quality.
Good luck and happy planking. She looks great
 On with the Show.... B)
  J.Pett
“If you're going through hell, keep going” (Winston Churchill)
Current build:  MS Rattlesnake (MS2028)
http://modelshipworld.com/index.php?/topic/45-model-shipways-rattlesnake-ms2028-scale-164th/
Side Build: HMS Victory: Corel
http://modelshipworld.com/index.php?/topic/3709-hms-victory-by-jpett-corel-198/?p=104762
On the back burner:  1949 Chris Craft Racer: Dumas
http://modelshipworld.com/index.php?/topic/939-1949-chris-craft-racer-by-jpett-dumas-kit-no-1702/
Sometime, but not sure when: Frigate Berlin: Corel
http://www.corel-srl.it/pdf/berlin.pdf
Thanks for the great replies guys, I also find working on the planking very therapeutic . I am also going to work a little instructional video of how I tackled the hull planking.
I also worked the planking fan measurements tonight and found an easier way for me to take samples.
In His Dust RevKB
RattleSnake Build
I like the idea of the instructional video. I'd like to see that.
Ok so , I made my planking video and I pray it helps somebody understand the basic idea of How I have reconciled the Job of planking . Please feel free to comment .
 Here is the video link ,
Edited by RevKB
In His Dust RevKB
RattleSnake Build
Ahoy Robert :D
Really nice video
I am sure the community will really appreciate the effort you put into this.
  J.Pett
I like how you added an extra arm to the clips. Wish I had known this tip before.
Nice video.  Those clips are great aren't they.  Just remember. once you get to an area where the planks are too close, you will have to come up with another way to get those puppies to form and hold for you.  I hear some people use super glue I didn't like that option though.  Too permanent too quickly.  My wood glue dried pretty quickly so I ended up using my fingers for some of it.  You do what ever you have to when you get to this step.  Perhaps another video on your solution would be nice.  Keep up the good work.
When planking, don't forget to bevel one edge otherwise you will have a gap between the planks where the hull budges out. Also if you are not painting the wood, adding some dark color to one edge (Charcoal, pencil, etc.) gives the effect of caulking between the planks.
I pray that all of your Christmas celebrations were filled with love of family and friends and your new year’s found you all safe and sound .its been a little while since my last post as this past Holiday season was filled with family and church .
I start out this build log saying that I had a blast at planking and found that following the directions to the letter was almost impossible to do . I made it up to where the first batten was and found that the curvature of the hull called for some spilling in order to keep the plank line I wanted. This process also revealed that My wale board was a little off and so I needed to remove it and re-situate it .
 so here is the progress thus far.
Here is where you can see the hull line did not match the line I wanted for the hull. so some trimming had to be done
Here is the spilled piece in place to check for alignment
Progression of planking went easy after that and i found I didnt have too much bunching at the stem although I did have to place one stealer , because i thought it would look cool and authentic
so far so good
all done view , notice the stealer and that not too much bunching at the stem of the planks , I mantained at least half the plank width
 these pictures are pre-sanding, I have decided to stain this hull with a ceramic process of staining and then antiquing it to look worn and weathered.
Over all I am very pleased with how well this hull came out , although I did learn some new things as the planking process advances. I will be making a short video of this process as well .
Edited by RevKB
In His Dust RevKB
RattleSnake Build
Nicely done.
I agree, very well done!
Howdy everybody!
It sure has been a very busy couple of Months with my daughters wedding , masters classes and ministry.
I just uploaded a new video of planking and look to progress more this week on the old snake. Take a look and I will post some more of my progress this next week.
https://www.youtube.com/watch?v=WWr_U1claH4
In His Dust RevKB
RattleSnake Build
Wow! Great video.
Eric
Current build(s) ;
AL San Francisco II
http://modelshipworld.com/index.php?/topic/862-san-francisco-2-by-eric-al-190-sport29652/
MS Rattlesnake
http://modelshipworld.com/index.php?/topic/868-rattlesnake-by-eric-model-shipways-164-sport29652/page-2
Sitting on the shelf : MS Constitution, MS Sultana,
Wish List : MS Essex, Confederacy, and Syren, and a Victory kit by someone ?
"80% of the time it works every time."
  • 2 months later...
Howdy Guys ,
I know its been some time since my last post , But the spring session was a bear and I only got to play on my build a few times. But here is the latest video from my build . I Plan on working on the Snake these next few weeks .
Have a look and subscribe to my channel.
In His Dust RevKB
RattleSnake Build
Ok a little side note , I have been working nicely on the Snake over the past 2 weeks or so , adding some detail .
But the great news is I was blessed to take a business trip to Philly this past week and afterwards headed to NYC to see the L' Hermione.
Here are some great pics of that trip , can anyone guess what ship Im working on  next?
On a side note I does anyone know where I can find plans for Her?
More Pictures to follow
Edited by RevKB
In His Dust RevKB
RattleSnake Build
RevKB - Try this site for the kit:
Victory Model Ships
Thanks JS ,
 Im Looking to do a scratch build , and possibly a cut away for the viewing of the berth and storage areas.
so blue prints would be my beginning point
In His Dust RevKB
RattleSnake Build
Well, they built the replicate ship from something, maybe those people can point you where you need to go to get plans.
Nice that you got to squeeze in some pleasure with your business trip!
