Thanks guys, I'm still trying to figure out what or how that false deck is going to be put in.
Made a little progress on the bulkhead. A couple more bits and it will be done. I like how it came out. Once finish is applied it will look good (if it can Be seen).
Next I worked one the transome fashion piece. I used an epoxy putty called " knedalite." I hope that's the correct spelling.
I love this stuff. The down side to it is that it is not wood. The up sides are endless. When you first mix it its a little like chewing gum. It sticks well and if you let it sit for a bit it becomes very workable. Thought I should pass this on for those tricky things we have to make. post-1401-0-55954900-1421715262_thumb.jpg
Edited by sport29652
Eric
Current build(s) ;
AL San Francisco II
http://modelshipworld.com/index.php?/topic/862-san-francisco-2-by-eric-al-190-sport29652/
MS Rattlesnake
http://modelshipworld.com/index.php?/topic/868-rattlesnake-by-eric-model-shipways-164-sport29652/page-2
Sitting on the shelf : MS Constitution, MS Sultana,
Wish List : MS Essex, Confederacy, and Syren, and a Victory kit by someone ?
"80% of the time it works every time."
Ahoy Sport :D
You mean this stuff right
Kneadatite Blue/Yellow Epoxy Putty Tape 36" "Green Stuff"
I might buy some and borrow your idea "again"
She looks great
I really like the lettering
 On with the Show.... B)
  J.Pett
“If you're going through hell, keep going” (Winston Churchill)
Current build:  MS Rattlesnake (MS2028)
http://modelshipworld.com/index.php?/topic/45-model-shipways-rattlesnake-ms2028-scale-164th/
Side Build: HMS Victory: Corel
http://modelshipworld.com/index.php?/topic/3709-hms-victory-by-jpett-corel-198/?p=104762
On the back burner:  1949 Chris Craft Racer: Dumas
http://modelshipworld.com/index.php?/topic/939-1949-chris-craft-racer-by-jpett-dumas-kit-no-1702/
Sometime, but not sure when: Frigate Berlin: Corel
http://www.corel-srl.it/pdf/berlin.pdf
JPett that's the stuff. It takes 24 hrs to fully cure. I'm thinking about adding some additional decoration to the transom using it. P.S. A little goes a long ways. I bought 18" of it and maybe used 1/4 inch.
Eric
Current build(s) ;
AL San Francisco II
MS Rattlesnake
Quick update; finished the cabin bulkhead. I used thick black paper (same as used for my caulking) for the hinges and the epoxie putty for the door knobs. I've added top railing with and put a decoritive molding around it. Also added the foredeck bottom rail. Don't know if you can see it in the pictures but I didn't set it high enough. It flows into the mid deck railing so I'll have to improvise on how to make these two rails separate and the decorative molding on the hull to flow to the bow without looking like a train wreck.
post-1401-0-05415400-1422816221_thumb.jpgpost-1401-0-71879700-1422816239_thumb.jpgpost-1401-0-56083100-1422816257_thumb.jpgpost-1401-0-83959700-1422816275_thumb.jpg
Eric
Current build(s) ;
AL San Francisco II
MS Rattlesnake
Thanks Scott and JP.
I seem to be jumping all over with my build. Here is some work on the head rails. I decided to make them out of two pieces. I lifted the pattern from the plans and cut to shape. Once I installed them I sanded the joints flush (or as flush as I could get them). I've been using the epoxy putty to fill cracks and help fix defects.
post-1401-0-15677600-1424578775_thumb.jpgpost-1401-0-16821500-1424578793_thumb.jpgpost-1401-0-64888400-1424578812_thumb.jpgpost-1401-0-06129900-1424578835_thumb.jpgpost-1401-0-97162600-1424578886_thumb.jpg
Eric
Current build(s) ;
AL San Francisco II
MS Rattlesnake
Scott, It was not too bad. I soaked the wood (Swiss pear) and then bent it using a planking iron. What made it a little easier was making them out of two pieces.
Eric
Current build(s) ;
AL San Francisco II
MS Rattlesnake
Here is my use of more of the two part epoxy putty to make decorative pieces. The headrails show one side finished and one ready to be painted. The mid rail decorative piece shows the green stuff before it has been sanded but just after shaping and cured.
post-1401-0-63922600-1424751443_thumb.jpgpost-1401-0-67578900-1424751456_thumb.jpgpost-1401-0-23401700-1424751475_thumb.jpg
Eric
Current build(s) ;
AL San Francisco II
MS Rattlesnake
Eric
I also am a veteran of two models.  And, so far, I have learned not to rush the 'foundation' of the model.  The other thing I learned is to always listen to Russ.
Cheers.
Ken
Washington 1776 Galley
Completed Builds:
Pilot Boat Mary  (from Completed Gallery) (from MSW Build)
Hey Eric:
I have to get some of the putty.  I looks really good.  Definitely adds to your excellent model.
Cheers.
Ken
Completed Builds:
Very nice build Eric,
I like that cabin bulkhead it Looks great.....
Nils
Current builds
-Lightship Elbe 1
Completed
  • 9 months later...
So it's been ten or so months since I made any progress. I moved and have my dream basement workshoppost-1401-0-80685500-1449637809_thumb.jpgpost-1401-0-21788900-1449637844_thumb.jpg
My shop is still under construction but have found the time to work on the snake a bit. I have worked on the head framing and the gallery windows. Also let me apologize for any missed responses or emails with the move I neglected to respond to quite a few people post-1401-0-97918000-1449638023_thumb.jpgpost-1401-0-45467500-1449638037_thumb.jpgpost-1401-0-02246500-1449638053_thumb.jpgpost-1401-0-09945000-1449638069_thumb.jpg
Eric
Current build(s) ;
AL San Francisco II
MS Rattlesnake
That's a nice workspace!  I'm eyeballing your table saw and band saw -- I always have to drag mine out onto the driveway.
Current Build:  HMS FLY 1776
Previous Builds:  Rattlesnake 1781
                        Prince de Neufchatel
As always thanks to everyone for your comments and encouragement !
Almost done with the headrails. Working on the grating and seats of ease. It's going to be a tight fit. My headrails are 2/32 or 1.5 mm pear wood bent and painted.
post-1401-0-67208800-1450670246_thumb.jpgpost-1401-0-06242300-1450670258_thumb.jpgpost-1401-0-31152800-1450670269_thumb.jpgpost-1401-0-37491500-1450670282_thumb.jpg
Eric
Current build(s) ;
AL San Francisco II
MS Rattlesnake
Christmas break this year was very productive. Installed the steps worked on the ships boat and nearly finished the capstanpost-1401-0-11153200-1451530810_thumb.jpgpost-1401-0-30091200-1451530821_thumb.jpgpost-1401-0-04335900-1451530836_thumb.jpgpost-1401-0-21131000-1451530848_thumb.jpgpost-1401-0-74839400-1451530859_thumb.jpgpost-1401-0-46775300-1451530871_thumb.jpgpost-1401-0-85769800-1451530884_thumb.jpgpost-1401-0-44926200-1451530896_thumb.jpgpost-1401-0-54690600-1451530907_thumb.jpg
Eric
Current build(s) ;
AL San Francisco II
MS Rattlesnake
Eric,
Your capstan looks really nice, keep up he good work!
Aaron
“The World is a book, and those who do not travel read only a page.” - Augustine
Artesania Latina San Francisco II 1:90 Scale
On the Shelf:
Model Shipways Armed Virginia Sloop 1:48 Scale
Aaron thanks, here it is complete
Eric
Current build(s) ;
AL San Francisco II
MS Rattlesnake
