thibaultron
3 Followers
About thibaultron
  • Birthday 04/11/1955
  • Gender
  • Location
    Warrenville, SC
  • Interests
    Ship, plane, and train modeling, history, science.
10,300 profile views
  1. Do you have any plans to make Chucks cannon diorama kit. I think it was for the Speedwell.
  2. One way is to measure the cannons that came in the kit, and use the overall length in the spreadsheet to determine which files to print.
  3. This site has a a download for a 1/32 catapult for your plane. https://cults3d.com/en/3d-model/game/1-32-catapult-for-ar-196?srsltid=AfmBOopjPiW1PObYmJ4LTa_i9BiZmiKRNl3uQHpk2HqH03CkxE76Mnn_ Maybe not an exact model of Bismark's, but still one for a German ship.
  4. The 1/32 looks great! For those who are building smaller versions, Distefan 3D Print, offers the Bismark catapult assembly in 1/72nd and smaller scales. I'm hoping to get their 14" 45 caliber (Used on at lest the USS Arizona, and Pennsylvania) Turret and catapult model in 1/72nd, though the ~325 price is going to be hard to find. I built the Arizona in 91 for my RC Combat competitions, and want a model of one of her turrets in 1/72nd to match my other Takoma turrets.
  5. I'd forgotten there was a model in the center fold. I just bought a second copy so I can build the card model, and still have the first complete book.
  6. Determine the length using the drawn bore width as a meteric.
  7. Cardstock for printers is about 0.011" thick, or about 1 3/8 thick in 1/120 scale, so you could use that as the sign, and just print the lettering on it. You can buy acid free cardstock, so it would not yellow on you, and would not need to be painted.
  8. Fantastic work! These are at a fantastic level of detail! Have you tried Zipping/Compressing the STL file to reduce the size?
  9. Great work! Thanks for sharing them!
  10. In the model railroad hobby, they have been saying the same thing for over 60 years! This hobby will also survive.
  11. I save my work several times during a session upping the "Revision" number each time (i.e. File_011.f3d, File_002....). This allows me to both not loose the last X (mins, hours) time of work, if the computer or program hiccups, (or a cat jumps on my keyboard), or I think of a better way to do an operation. And Yes, I have some of my projects that have run into hundreds of revision files. I can always delete or Zip them when I finish. Do not be afraid to go back and redo something, if you find new information/details during the design, or something you did does not print and fit like you thought.
  12. I run piece of wire or wood into the bore and touch hole to get any resin out, and print with the muzzles pointing away from the plate to encourage the resin to drip out. Holding the barrel in a pool of cleaner while cleaning the bore helps. I let the cannons dry over night, after final cleaning, before curing them. This allows any moisture in the barrel to dry, and not have liquid run out and mar the exterior surface. For larger scales I have an UV LED that run into the barrel, to insure the bore is cured. I think I detailed these steps earlier in this thread.
  13. Depending on how must saw dust or dust you are creating, several companies make ceiling mount units similar to this. https://www.grizzly.com/products/grizzly-hanging-air-filter-3-speed/g0738 I was lucky ans found a delta unit used for much less.
