Everything posted by KennyH78
Found a little time to put in some work at the shipyard this evening. I was only able to get 1 strake completed, but I was taking my time to ensure that it was all done correctly and that everything fit tightly. Hopefully, I will have more time tomorrow to add some more strakes to the starboard side.
Now that I have completed the planking on my Confederacy, it was time to show the Medway longboat some modeling love. As Chuck has suggested in his monogram, I started the planking task by lining off the hull with thin strips of tape. This is where it currently sits. I think I will walk away for a little bit and come to give it a second look with a fresh set of eyes. Edit: looked at the bow again after typing this post and saw that the lines had to adjusted.
She's a beaut, JJ! Very impressive model; can't wait to see what chapter 3 has in store.
Planking on the starboard side is progressing at a steady pace. I hope to have it finished up by the end of the weekend. So far, the first belt is completed and the second belt is 1-2 strakes away from being halfway done. Once her hull is fully planked, I will need to switch gears and show Chuck’s Medway longboat some planking love.
She is looking really nice. I love the CNC'd figure head and stern carvings. I think I may not have mentioned this before, but I love how you combined POB and POF model into a hybrid model!
Finished planking the port side of the hull today. I also gave that side a rough sanding with 80 grit and 100 grit paper to smooth out the planks. I will come back with 180, 220 and 320 once the starboard side is completed. I am debating on applying a coat of WOP to the planks to help protect them. All in all, I am quite happy with how it turned out, especially since this is the first big hull that I have planked. Anyways, here are a few pics of the port side.
vaddoc, I am going to pull up a chair and follow along. I also watched Leo's YouTube series on rebuilding Tally Ho and thought about building a model of her. There is something about her story that just draws you in. I may still attempt a model, but that is a long way off; I need to learn how to draft a set of workable plans for a build from the lines plans first.
deck planking options
KennyH78 replied to manning16's topic in Building, Framing, Planking and plating a ships hull and deck
I like the look of the holly against the cherry; but that is just my humble opinion. I like the contrast of the two woods together. Although the boxwood would give the model a nice subtle look on the other hand. As others have suggested, do some testing to see which looks better to you. -
Got the first belt on the port side finished. I think I will continue on the port side before I move onto the starboard side. So far I am happy with how it is progressing. I did have to redo some of the planks at the stern because it didn’t look right to me. I toyed with the idea of just letting it be, but ultimately decided that I can do better and that I would be happier if I just went ahead and fixed the planks. I sure am glad that I did.
Looking really good, JJ! Following your progress on the prototype makes it very tempting to get one of your production kits.
Planking below the wales has begun. First thing I did was to line off the hull and separate the hull into 3 belts. Then I started planking the first belt on the port side. I am about half way through with this belt, it will consist of about 9-10 planks. So far I am pretty happy with how the planking is progressing.
