Don Quixote
Posts posted by Don Quixote
Hello, fnkershner.
First of all, this plank job is 100% practice. Using one planks means twisting this way AND that. I'd rather break it down to what *I* feel is a manageable plank. I've tried beveling the whole plank, then bending and twisting. For me it's not practical.
Like I said, the bulkheads are so screwed up that the very 1st plank didn't lay straight. Now I have the dip, or curve I mentioned in my last message.
Because the bulkheads are so far outta whack, the first plank could not follow correctly. That is now causing me to ever so slightly push up on the plank being installed. See the gap? At this rate I'm going to have a problem. I can either continue and hope the garboard plank fills it on, or I can let the plank lay naturally and fill the gap in with wood filler. Which would you do?
Also, I have a FEW planks staggered but towards the bow there's not much staggering.
So how does one plan the stagger?
First of all, the planks that come with the kit are long enough to cover the entire length of the ship. I don't want to do it that way. I want to stagger the planks. How does one go about planning the length needed? 15 bulkheads.
And I am one LUCKY ducky. Model-expo sent me 2 sets of keel and bulkheads. Since I already have 2 ships, and I bought better wood for the planking so I should have enough to practice on 2 hulls and use the good wood on the last that I'll complete.
On 9/27/2017 at 5:15 PM, Worldway said:
I moved over to scalpels.
I have now! Never use an x-acto again, will I? Once that blade snaps in, it's not going anywhere. E-Xacto's always unscrew.
So where can I get some 25-a's? Can't find them on Amazon.
In other words, start at top or bottom and keep it that way. Never switches?
Thanks!
When we plank, we reduce the clinker effect by beveling an edge. Question is, top or bottom and does it ever switch?
- GrantGoodale and Nirvana
2
Amateur, You were of course right. Lots of wood filler. I call it bondo. Some sanding down but not too bad. I'm just going to play around with the planking, but I also have another problem I didn't catch. There are 2 blocks I used to square the bulkheads that extend too far down. I won't be able to planks the entire bottom 1/4 of the ship.
I couldn't find a 25a but I found a 24 and 25 that look like sweet chisels.
I bought a practicum with photo cd for the Bluenose. I don't recall from where, and I HATE the search engine here.
Anyone know what I'm talking about? I lost it in a major overhaul of my garage.
Contacted model shipway's, they said they don't care why I need the parts, they'll send them to me.
So, I broke the keel at the bearding line. To make the line, I took a #11 x-acto and cut the bottom line, then using a curved blade (I don't know the number) and carved out the beard.
Any better ideas?
Bluenose by Nirvana - Model Shipways - Scale 1:64
I didn't realize you were building her. Right off the bat you pointed out what both the MFG. docs and Mr. Hunt's regarding the water way.
