Don Quixote
Posts posted by Don Quixote
Looks pretty good to me, mate!
When the time comes, I have a wife that I spent over a grand on a sewing machine that known how to use every function. Had to take classes.
Look at all those typo's! This texting while driving is not easy.
I like your answer. You do have to look for the hitch in the line though. Had I not been looking for it I'd have missed it.
Maybe I wouldn't hid the rigging:)
I admire your tenacity to go into so much detail.
I'm betting I can paint mine by hand. No taping off.
As for the repetitive, I always try to make a jig, or fine some way to mass produce. I think that's what gets me in trouble.
For the stability of the yard, could you cut the joint at an angle to give more surface area for the glue? Then wrap the joint in some brass. I got strips, like 3/32x1/64x18" for next to nothing on amazon.
Sails, could you die them after gluing?
Once you've eliminated all the wrong ways, the right way is all that's left.
I like the last one best.
- mikiek, Tom E and fnkershner
3
Try this: use the symbol @MarisStella.hr
Don will be notified that's he's been mentioned in a post.
@texxn5, I'll pm you. That's not the first time I've heard of that model. I have your table saw as well, the one that the saw tilts and all that.
Tell me a lot more about the bearing you mention.
Oh, that's right, Ma.
And thanks.
Freaking nag.
Those Palm planes look a little cheaper than the lathe.
Is there a lathe that can handle the small diameter, but long length of a mast?
That's so beautiful I'd like to see is on the main floor of my house!
Mike, Getting back to twisting planks. When I twisted that boxwood, I put it between helping hands of 2 units so I had some distance. I then used my steamer until the wood was soaked. I then immediately gave it a slight twist, let it dry, soaked, twisted. Probably took me 6 hours to do that.
So, here's my idea for the fake stanchions. I'm going to try a blend of ideas I've seen. I'm mounting a plank temporarily while I add the stanchions. My thinking is that the strength of wood glue against the bottom and planks should be enough to handle adding the second plank. I'm hoping with only 1 plank to deal with it'll be easier to cut off the bulkheads.
Like my hi-tech jig? I'm still not comfortable with the length of the stanchions themselves though. I've read and read, following other build, but I don't seem to understand. Oh well, I can always rip it a part or use wood filler.
- fnkershner, Tlampen and russ
3
Trajta by mikiek - FINISHED - Marisstella
Oxyclean will get that blood out
