Everything posted by popeye2sea
Me giving a tour last year.... Oh, and no ship that's not crewed by the damned and captained by a man so evil that Hell itself spat him back out could possibly have black sails, therefore couldn't possibly be any other ship than the Black Pearl. Is that what you're telling me?
- 601 replies
- constitution
- revell
If you consider that the sewn lines are the seams of the sail cloths used to construct the sail, then the emblem would have been an additional piece sewn over the cloths. Hence the seams would be hidden by the emblem.
How to Attach the Mast to the Yard?
popeye2sea replied to mkmossop's topic in Masting, rigging and sails
Dan, Does Lee suggest that one of the parrel rope methods is older than the other. I would think that the one that brings the end of the parrel strop to the deck to be the later of the two. -
Looks like the bottom of a fish tank.
Chuck, I received mine and they look great. Now I have to start making strops and hooks to go with them . I'm waiting on Alexey's serving machine so that I can begin the strops. 96 2mm blocks and strops and 48 hooks to rig 12 cannons
Hooks
popeye2sea replied to popeye2sea's topic in Discussion for a Ship's Deck Furniture, Guns, boats and other Fittings
Thanks folks, This being my first build I really do not know what to expect. I keep thinking that I have to allow for tension. I guess that is another reason that I am glad I found this site. The advice I get is priceless. -
I have been told that the Loring model of the Constitution is a mix of different iterations(?) of the ship. And it is not a very good model to use as a reference piece.
- 446 replies
- Revell
- Constitution
There is a flexible rammer made of rope that would allow the powder and shot to be rammed down the barrel without the end (or the sailor) being stuck out of the gun port.
- 601 replies
- constitution
- revell
Enamle vs Acrylic
popeye2sea replied to Timothy Wood's topic in Painting, finishing and weathering products and techniques
Thank you Spiff and Wefalk. Your comments explain a lot. I'll prime with white from now on. -
Rigging sizes in relation to scale of model
popeye2sea replied to HKC's topic in Masting, rigging and sails
R.C. Anderson gives a rule of thumb in his Rigging of Ships in the Age of the Spritsail Topmast as follows: Diameter of the Main Stay = 1/6 the diameter of the mast Fore stay = 4/5 of the Main Stay Mizzen Stay = 1/2 of the Fore Stay Stay collars = 3/4 of the stay Shroud and stay laniards = 1/2 of the stay or shroud, except main stay is 1/3 Shrouds are 1/2 of their respective stays, i.e. topmast shrouds are 1/2 of the topmast stay Mast tackle pendants, backstays = 1/2 of the shrouds Tackle runners are 2/3 of their pendant Tackle falls are 1/2 of their runner or pendant Ties = shrouds Halyards = 2/3 of the Tie Lift and Brace pendants = 1/2 of the shroud Lifts = 3/8 of the shroud Braces = 3/4 of the Brace pendant Tacks = 1/2 of the shrouds Sheets = 3/4 of the shroud Clews = 1/2 of the sheet Bowline = 1/2 of the shroud Leechlines and Buntlines = 1/3 of the shroud Blocks sheaves are 9 times the diameter of the line, blocks are 12 times the diameter of the line. Hope it helps -
Lambsbk, There are two hawse pipes on the gun deck and corresponding ones on the berth deck that allow the cable to pass down to the orlop. I will take pictures of them on Tuesday when I am aboard next.
- 446 replies
- Revell
- Constitution
A question on working mizzen lateen sails
popeye2sea replied to Stevinne's topic in Masting, rigging and sails
The difficulties in handling this yard was probably the reason it was replaced by a simpler gaff and boom rig. -
Enamle vs Acrylic
Thanks Russ. And Tim, I apologize for hijacking your thread. -
Enamle vs Acrylic
I'm on the third coat now and the blue molded plastic is still showing through. Multiple coats are not really a problem because there is no surface detail to hide, but it's just a pain in the a## to have to paint so many coats. -
Enamle vs Acrylic
I am currently using Testor's Model Master acrylic #4630 Red. I have also tried Model Expo's #MS 4802-B Gun Red. It goes on a bit thicker but still has poor coverage. -
Enamle vs Acrylic
Thanks Chuck. I'll look into Badger paints. I'm currently painting the interior bulwarks of my Soliel Royal. I have three coats on it now and it's nowhere near covering the blue plastic they are molded from. The red paint seems to go on like a wash, unlike any other color I have used. -
You guys are incredible Most of these you are getting these in 15 - 30 min. I am in awe.
Finally have some new progress to report. Seems like there is never enough time to work on the build. I am working on correcting the deficiencies in the head of the ship. Since no one really knows what this area of the ship looked like I took some artistic license. I was also pointed in the direction of a build log on another site which gave me some good ideas. Here's what I came up with: I filled the space between the cheeks with a billet carved from styrene stock. Then I cast some silicone molds using the decoration on one of the quarter galleries and cast some pieces in resin. Here are the resin pieces mounted and painted Next I carved some head rail timbers from strip styrene And mounted them Then I cast another decoration to ornament the head timbers and mounted them to finish out this project And here is a couple of pics with the head rails and grating temporarily fitted That's all for now. Thanks for looking in on the build. P.S. I'm hoping this is not too horrible a build. No one has commented yet
- 196 replies
- plastic
- soleil royal
