SawdustDave
Everything posted by SawdustDave
  1. You are so right Frank. I hate to think of what it would have been if I had fitted all thirty of these chain plate assemblies as I was going. And there's no reason to think I would have found my mistake before completing all of them. I can picture the Amiral walking into the room and saying to me....."What's wrong sweetheart? Why are you crying? Thank you Nigel.
  2. OK, we have a pretty good ending to this particular brain f__t. Shame on me for fitting those first deadeyes improperly oriented. Having never used heart shaped deadeyes before, I've never worried about orientation at this point since round deadeyes can easily be rotated when ready for reeving the lanyards. The good news.... * Since the brass nails were pressure fitted, there was no big problem removing the five assemblies. * Before - There were three corners, requiring five bends, to the shaping of the wire tightly around each deadeye. * Fitted correctly - There are only two corners, requiring two bends! Much easier and quicker. These seven assemblies seen here were done much quicker than the original five first posted. Sometimes there's a silver lining to them dark clouds.
  3. DAMN!!! Sure am glad you pointed that out before I got any farther along Nigel. All together now....."Slow down and THINK!"
  4. Thank you Piet and Omega. Just applied a thin coat of wipe-on poly to the channels and realized I should have done so before taking the above photos. What a difference! Think I'll re-shoot later today after I finish installing the starboard waste channel assembly.
  5. Looks great Ken. I love the look of furled sails on a ship. Nice work.
  6. Mounted starboard fore channel w/deadeyes / chain plates. 1st photo..... Shows brass pins used to secure channels to the hull. 2nd photo.... Close up of knees. 3rd photo.... Close up of installed assembly
  7. As for the deadeyes.... 1st photo.... better look at the profile of the turned stock. Note the two boards used to keep the turned piece from moving around while being sanded. 2nd photo....better look at the scoring of the turning. 3rd photo.... the modified Dremel bit used to drill the deadeye holes.
  8. Frank....Have you tried walnut? Works fairly well as long as you keep your tools sharp. Let me know if I can be of further assistance.
  9. Sure Thing Frank. Take a close look at the third photo and you can see my turnings. Note that the one right below the cluster of deadeyes has been reShaped by sanding three sides fairly flat....careful not to take them too far because you don't want the tips to be sharp. You might need to tell me if that helps, or are you having another type of problem.
  10. Thanks Joe....going to take a while to crank all those little suckers out. This will be the first ship I've ever made the deadeyes for.
  11. Hello Piet my friend. Alistair....proud to have you join my little project. Just wish I could make my work look as sharp as your Fly. Joe....Here's the dime size reference...
  12. Thanks Popeye, Kees, and Russ. Since my golf plans for the morning is a rainout, it looks like I'll get in some shop time before poker night begins at 6:00pm.
  13. Quick update on next step....channels, deadeyes, and chain plates: 1st photo.... all channels have been rough cut. 2nd photo....All knees have been shaped. 3rd photo.....used lathe to turn walnut stock and score each deadeye. There are two sizes needed (60 pieces of 1/4" for lower channels - and 24 pieces of 3/16" for top mast shrouds). Each deadeye will be drilled and dressed before cutting off....then finish dressed with a fine file. 4th photo....shows channel, deadeye, and chain plate assembly. The chain plates consist of 5 pieces cut and shaped from 74mm black wire. There will be 42 sets required. I don't need to say what I will be busy working on for a next few days.
  14. Looks great Andy Suggest you clear out the background of your photos in order for your subject to show up better. I usually spread a cheap plastic table cloth from Walmart for most of my shots. Anything with a solid color will do.
  15. That's the way to go Frank. It's YOUR ship, and you can bash it up any way your heart desires. Please let me know when you launch your log.
  16. Omega - I would have said the same thing about MF before I got into the smaller scale build and discovered there was much more to her than first meets the eye. In fact, after taking a couple of years off from modeling, I was looking for a little "warm-up" project before diving back into something more serious. Boy was I surprised. She's a real "sleeper" for sure. I should add, I think Chuck Passaro's MF kit is excellent, (using his plan sheets for this build) and highly recommend it for builders at any level. Although, as a scratch builder, I tend to do some personal bashing, my MF is 90% strict adherence to his kit design. I look forward to tackling his Winnie once I ever finish these MF projects. It looks really special.....in the class of the Confederacy.
  17. Thanks Adam, hope you're having a wonderful vacation....feel the same about seeing her rigged. I get to go to school on your work. I like that. Russ - Always good to see you dropping in.
  18. OMG!!! All of your updates are magnificent....and the stove in mind blowing. All I can think of is WOW!
  19. Russ....your progress on the deck fixtures are inspiring. I love your clean, sharp details. Beautiful job mate. Dave
  20. Please explain the bit you used to cut the tree nails Marsalv. Amazing! And - what is the wood? Beautiful deck by the way. Enjoying your build very much.
  21. Finished with the beakhead assembly for now. I can finally enjoy seeing her complete profile. Channels next, then on to masts and we all know where that is leading.......
  22. Thanks all....appreciate the encouraging comments. Omega, I promise, if I decide to rip this section out and re-do it, I'll do the UTube thing. Pretty sure I'm going to go with this as is.
  23. Thanks Piet. Passion is true in most cases, but I don't recall any of my passions causing "withdrawal" symptems? Admit it my friend, this stuff can cause deep problems that only Docter Phil can understand. My appointment is next week.
