Posts posted by Paul0367
So near, all framed just trim to add, so far all the top two layers frames removed all glazing scrapped and windows recut. Why, when trimmimg was being fitted it became apparent that the trims were not going to meet, actually well off despite the bottom windows being perfect and the upper were pre fabricated. How I did not see this prior to all the glazing and framing is beyond me. Well im having to raise both the middle later and the top layer to line it all up. Oh and then re glaze and frame... OH JOY. Tinyelle be extra careful not to suffer the same fate
Thank you David, although thinking about it, im sure ive called you Sid in the past.
- Kevin, mtdoramike, GuntherMT and 1 other
- 4
Would email breech copy rights
Hi
The very start I pinned her with the pins supplied which snap on removal and found it very slow and tedious also I broke two tiny drill bits, as they need pre drilling to prevent splitting the wood. I never thought of the idea to use them large pins, fitted next to the wood not actually through it, I pinched the idea but it worked really well for me. Ok back to the question, I use Everbuild 502 wood adhesive it handles high loading/stress areas. Ideal for a peice of timber fighting to be straight again. Really its strong stuff and initially bonds in ten mins but solid in 4 hours. Just like PVA in its use and dries clear.
Ha, ha, the pondering about cutting a beautiful hull where hours has poured in. Possible tip, ditch the dremil and get a drill used by the fairer sex during there nail visits. These drills don't pulse like a dremil at slower revs and also you can get your fingers very close to the tip for accuracy.
You should be fine with the planking, really. there is more fear spread about the job than actually it is. The only problem about it is that its our first ever so we don't have any idea what can be acceptable prior to sanding. My tip for you is just shave some off the contact area of the plank especially on the curved sections to prevent a gap, the planks are thick, good for sanding back, hell to bend... and lots of cursing to come, before planking I would add 5mm to all the canon back plates because look back over my pictures and you will see some are not inline enough... If you go by the plans you will hit ribs, I hit my first, this if a pain and takes a while to cut out but ok below deck just more work but please, please, please plan your top deck where the ribs are seen from behind, these have to be right and not touched / cut even if it means cheating and moving them a little. I have made a few spindles which I am replacing the brass etchings with. see pic, I plan on making a stupid amount to replace all the brass.
Thank you, hey welcome back, we were almost at the same stage of the build last time I heard from you. I have used International yacht varnish from B and Q, I'm not sure wether the next coat should be satin rather than super shiny gloss, Jury is out. I have now decided to make my own spindles for the cabin decoration and ditch the copper ( short Length) ones also, it will take a while to make them all but I'm not in a race. Oh just incase your wondering I'm keeping her wood colour, shows all the effort more than paint. I may build another in the future and paint her.
I've finished the portside windows and due to fingers adding grease to the hull I've varnished her today so all works stopped whilst she dries awaiting a re sand and further coats. Mike do you prefer blue to yellow or blue overall, ie blue under framed in wood as as opposed to black. I went black as that's all I see on the real girl sat in Portsmouth
Mike, would it be possible to run a fan behind the sails (cloth) and as they bellow spray starch on them and allow to dry. Just a thought, I've not tried this.
Welcome back, having time is one thing but having the will is another, I refer to framing if the gun ports and windows, painfully taxing on the brain. Repetitively painful, but so necessary, will keep an eye out on your build as always
I have moved on to the captains quarters now detail and frames going in, the picture shows my additional frames part installed in the windows, this takes so much time and is so fiddily but I hope it's seen as a better addition by fellow modellers. I also put in a blue window and framed it as the kit intended. I personally felt this was a let down by Constructo and a bit of a cop out. I'm
Finally finished canon port hole framing, I have also done a dry instal of the canons and some of the backplates didnt line up, despite being prefabricated. I had to make sections small enough to fit the canon holes, pre drill them and instal, this works but really should be unnecessary. you can see them in the images. Anyone building this kit i would recommend adding to the depth of the cannon mount board before planking as its a pain to sort through a port hole
Yeah Mike, thanks, really need reminding about the quantity involved. ha, ha, 104 ports so that 416 individual pieces to cut/size and glue. 416, oh 416,416,416. Ahhh less now, I've done a few.
Yeh Manzonia the doesn't want to bend or comply timber, some brown some grey/brown. Look at my lower starboard Wale and it's two parts and there is a huge colour difference. I didn't mind as I was painting her until Mike changed my mind again but hey its now called a battle repair. Artistic licence some one once posted. Ply parts, this kit so far and looking ahead has no visible ply, intrigued Kevin, why did you close the gunport lids. Difficulty found on this contrasting timber is the Manzonia (pain) tries it's best to bleed into the light Ayous when sanding. Progress now has hit a crawl pace as the messy not really noticeable (to others) framing is being done, when I find I'm in the mood that is.
Cheers guys it's nice to know I'm on the right track with this, slow stuff on the way. Frames
HMS Victory by Paul0367 - Constructo - Scale 1:94 - First wooden ship build
Hi david
Please when fitting the canon back boards push them to there lowest point, there is some up and down movement, push them down, this prevented you having to add pieces through a canon port as I had to, see pics. And pay particular ATTN to the rear quarters and the lining up of the windows, I'm rectifying my issue, bottom windows no problem, its the two above. Enjoy your build and so glad I'm assisting especially as instructions are vauge at times.
