Everything posted by _SalD_
Sorry for the long period between posts but it’s been a busy summer. I finally started the first layer of planking and for the most part I have been following the procedure outlined in the manual for placing the planks and dummy gun ports behind them. I made a little jig to pre-bend the planks to fit the sharp bend at the bow. I used a hand held steamer to soften the wood as I bent them. I order to make it easier to glue the planks in place I pre-positioned the planking along the bulkheads after steaming them and allowed them to dry overnight.
It's been a while since my last post but I've been working on my Father's Day's present that I treated myself to (it's always a good excuse for a new toy ). This is something I always wanted to try and it only took a few weeks. I won't go into a lot of detail just a few pictures. Started with this Finished product Now back to the ship.
Started to do some prep work prior to starting the planking. There is channel shaped wood stock that is to be cut and used for the dummy cannon ports. These pieces are installed behind the first layer of planking as the hull is planked. The ports are to be painted black so I gave the strips a few coats of black paint prior to cutting them and then I will just touch them up once they're installed. The directions also say to pre-drill the back of the dummy ports for the installation of the dummy cannon half's prior to installing them. I was wondering if it would be better to drill them after they're glued in place otherwise how can I ensure that all the holes will be in the right place. The directions also recommended covering the #6 and #12 bulkheads above the decks prior to installing the hull planking. #12 bulkhead, rubber band helped keep the pieces in place while installing. #6 bulkhead, this one was a little challenging, did it with the ship vertical.
Jan, I had thought about cutting in a rabbet at the stern and bow to make installing the planking easier. I should have done it first thing prior to setting the bulkheads which would have made it a lot easier but I wasn't confident enough about cutting the rabbet in before I knew exactly where it was located. Why make it easy when complicated works just as well I do plan on painting the bling. As of right now I'm thinking of making them look weathered and not brand new.
Duff thanks for the offer but I think I can use google to help with the translating Jay, the #2 fillers are actually a little over sanded. I thought it would be easier to form those fillers if I sanded them down a little prior to installing them. In hindsight I should not have done that. I plan to fill the gaps with wood filler and reshape the bulkheads and filler #2, I was just waiting for the mailman to bring my filler which, by the way, arrived today. Thank you for checking my work too, I appreciate any and all comments or questions.
Getting the ship ready for her first planking I started to fair the bulkheads. I also decided to put a filler at the bow to help with the bending and securing of the planks. I used some scrap balsa wood I had and shaped it with my sanding sticks. The hardest part about fairing the bulkheads is telling myself... 'don't rush and when you think you're done, do it again'
All decks installed along with the stern upper transom. I found and downloaded a .pdf copy of Herman Ketting's book 'Prins Willem' which appears to contain quite a bit of useful information on the construction of the ship. My only problem is that it's written in Dutch! There are some nice pictures though that might come in handy.
Starting to reassemble the bulkheads for their final placement on the BF using clamps and my trusty Legos. More clamps and legos Setting the main deck. Reminds me of something out of Gulliver's Travels. The rubber bands worked out nicely because they pulled the deck down along the curvature on the bulkheads.
I had mentioned before how lacking the instruction manual is but I had to laugh because although this is an advance kit the manual states and I quote, ‘… model may be constructed with a few standard tools, a hammer, a few small files, pliers, a pair of scissors, a knife cutter, sand paper and some glue…’ Hope the wife doesn’t see this or there go all the tools I was going to buy. Unlike the Syren model bulkheads which came laser cut but still on large sheets this kit’s bulkheads are all cut out for you. The bulkhead former (BF) was also pre-cut and had no warpage at all. The directions recommended to dry assemble all the bulkheads and decks prior to gluing anything in place. I’m glad I did this because there are some bulkheads that can’t be installed without installing the decks along with them. The decks are loosely installed so they appear a little crooked. All the slots in the bulkheads needed some sanding for them to fit properly on the BF. I decided to do some preliminary shaping of the two bow fillers before permanently attaching them to the BF. This is done so the hull planking runs smoothly to the bow. The last task to be done prior to reassembling everything and gluing in place is to cut the gun ports from the stern bulkheads. Making a copy of the bulkheads from the drawings, I cut them out to use as patterns to locate the gun ports. The ports were cut using an x-acto knife with a #11 blade and then filing the edges.
Hello all. I had debated back and forth as to whether or not I would do another build log and I guess you can tell what I decided. This will be my third kit built ship and decided on the Prins Willem by Corel. Prior to this I had attempted a scratch build of a sidewheeler steamboat but came to the realization that I’m not quite ready for that leap. A little background information on the ship for those interested. Owner: Dutch East India Company Built: 1649-1650 Maiden voyage: May 5, 1651 Sank near Madagascar 1662 due to violent weather Crew of 276 Displaced: 700 tons Length: ~137 ft Armament: 32 guns A replica was built in 1985, but was destroyed by fire in 2009. The kit was purchased through Model Expo and although it was back ordered it only could two weeks to receive. The model scale is 1:100, with a finished length of 29-1/2” and a height of 23". The kit is POB with laser cut wooden frames and the hull is double planked. There are quite a few parts to this kit and even though I know I should do an inventory of them I am forgoing that task and will check for the required pieces as I proceed. Fingers crossed. Obligatory exterior and interior box pictures. There are ten sheets of drawings which appear to be quite good, the instruction manual however is a little lacking.
Nathan, For the style of text it will depend on what font's are available with the cad software you are using. I use Autocad and use their 'simplex' font for the majority for the dimensions and text. As far as text height I prefer text that is 3/32" high for dimensions and text, for titles I scale the 3/32" text up by 1.5 or 2 times. For drafting the ship I've found using a scanned drawing as an overlay works well. It's also easier to pull dimensions off the scanned drawing than the hard copy. these are just my opinions and seem to work well for most cases.
Corel Venetian Galleon Ship (Galeone Veneto) - kit recommendation
_SalD_ replied to _SalD_'s topic in Wood ship model kits
vossiewulf, That's quite the visualization... pointy wood dowels leaping out of the box and repeatedly stabbing you in the face I had thought I was ready to try a scratch built model but I think I need to fine tune my skills a bit more before jumping onto that band wagon. Also while building a case for my U.S.S. Syren and really taking some time to look at all the work I had done on her I sort of got bit by the rigging bug again and decided to build another sailing ship. I'm basically looking for a masted sailing ship that's somewhat different than the one I just finished. I'll take a look at the Revenge. -
Harmstronginga and cathead, thanks so much for your comments. I haven't purchased the kit yet and am seriously reconsidering it now.
