Posts posted by cobra1951
That is one delicate bit of construction, must be scary touching it to work on it
- Elijah, zoly99sask, EJ_L and 2 others
5
Hi Dave
Yes I there is room for the rudder etc. I think the construction of yours and mine will be different as they are from different manufacturers. Mine called for two strengthening pieces to be fitted either side of the keel at the stern end. Then they tell you to file out the space in between the strengtheners. I did it differently be cutting the piece out of the keel then fitting the strengtheners with the appropriate gap in between them. Awkward as most of the stern is built before it's mentioned.You can just see the slot in between the two center strengthening pieces in the center of where the transom will be
- popeye the sailor, Elijah, EJ_L and 7 others
10
Hi Paul
There probably is but as i do not mind waiting to be supplied with what i have already paid for and i am in no rush to finish it (in fact i'm happy for the delay as it stretches out the sanding job lol) i'm not going to bother looking
I could get on with other jobs on the build but i want to build it in the manual order (unless as sometimes happens the manual is being silly) because in the past i have ended up forgetting to do stuff and then having to go back later and do it
- EJ_L, zoly99sask, Seventynet and 2 others
5
Nice cockpit you have created
Strange design for it though, (not you, the boat designers i mean
- Elijah, Seventynet, EJ_L and 4 others
7
That's ok Bob, it's the weekend relax, sit back and have a couple of refreshments
6 tubes of pringles should sort it
:D
- EJ_L, popeye the sailor, Elijah and 2 others
5
Ever been looking for model wood in Rotterdam ... it's not as easy as it used to be ... quite a few modelshops are gone ... long live the shop killer ... internet ... but it has it's own advantages ... you can enjoy your build much longer Bob
Couldn't you start with what you've got on one side ... at least you will have something to do whilst you wait for the missing pieces
Wouldn't want you to go cold turkey
Yes the internet has killed off a lot of businesses.
It would be nice to be able to go and choose your own woods without having to put up with what your given
I could do one side out of the 4 pieces but i don't fancy patch working them plus i would have to wait until i did the other side to do the final sanding anyway.
The more i can delay the sanding process the happier i am
:D
so i will wait
Nice planking!!do you need some wood filler job?
Or straight to sanding??
Thanks Zoltan
Just a little bit of filling needed to be applied
- Elijah, EJ_L and zoly99sask
3
Liverpool...once the centre of the shipping universe...and no decent model shop.
What has become of this world
You got that right
:huh:
- Elijah, Robin Lous and EJ_L
3
Hi Robin
There is no model shop in Liverpool anymore, the one that used to be did not stock wood etc only plastic kits and train sets.
Also my supplier has no stock of the required size according to their website
So i will have to wait anyway
- Robin Lous, Elijah and EJ_L
3
First thank you for all the like and remarks and input, much appreciated
I was waiting for the first problem to pop up and here it is.
4 blocks of Balsa to make the shape of the bluff bow
2 blocks to be fitted each side into the space at the bow
The problem is Occre have supplied blocks meant for a smaller kit
They measure 15mm x 80mm x 100mm
But they should be 23mm x 80mm x 115mm
So no chance of filling the spaces at the bow.
I will contact my supplier on Monday to get replacements, So there will be a delay in the build until they arrive
Extra beams good decision
- cog, mtaylor, Robin Lous and 2 others
5
Hi Don
I noticed the way they have of fixing their bulkheads in alignment looks pretty solid. Makes a nice change to see a manufacturer taking a different approach to designs
- Eddie, zoly99sask, Seventynet and 3 others
6
0,5 mm...that's indeed very thin
Robin
Sure is so i better get it right first time
:huh:
- Robin Lous, EJ_L and Elijah
3
Nice Job
I like the way occre provide the bluff hull instead of having you first plank it , makes the first planking less tedious. The bends on the Caldercraft were interesting to say the least. Bluff kits are "Character builders "if nothing else.
Good luck on the second Layer. if the Occre 2nd layer wood i have used in the past is any indication , it should come up a treat when sealed and it bends nicely.
Thanks Paul
The bluff hull makes it a lot easier to do the first planking as you can just lay the planks in straight lines rather than follow any curves on the hull.
The second planking will be a bit more traditional but i suspect easier than the normal shaped hulls
Second planking strakes consists of 0.5 mm x 5mm limewood (same as the decking) for the upper hull and 0.5mm x 5mm Sapelli for the lower hull.
As you say very easy to bend but a lot less room for errors as there's not a lot of thickness to sand down
3
Looks real good Bob, will make for a great base for next layer. Looks like there is a piece of planking missing at the stern, is that left open for a reason?
Thanks Don
I only left it open because i was checking out a few builds of this kit and one showed it like that in his pictures so i did the same just in case there was a reason for it. Turns out there was no reason
so i will patch in a little piece before i go any further.
- EJ_L, Elijah and popeye the sailor
3
Looks smooth!
Robin
Thanks Robin
Still needs a lot of sanding yuk
3
La Couronne by EJ_L - FINISHED - Corel - 1:100 - 1637 Version
I know the problem with magnification. It gets very disorientating when you work under a magnifying glass
