Posts posted by cobra1951
Lovely little cutter hanging there
- popeye the sailor, Mexspur, mtaylor and 1 other
- 4
Nice to see another build of this fine kit
Good luck with yours I shall follow along
- mtaylor, zoly99sask, bryanc and 2 others
- 5
Hi Bryan thanks for the nod
You seem to have come to the same conclusion as me about this. The difference being I cannot get up the inclination to start it, not finish it as in your case. In fact that I am very tempted to throw it on gumtree which is a pity because as you say the concept is very good and the finished kit looks great but the only finished one I have seen is by the maker who will not have had the problems they have created for the modeller at home. Such a shame really
Good luck with your section deck
Yes Jax is good but not as easy for me to get hold of here.
- Elijah, EJ_L and zoly99sask
- 3
Nah! Be grumpy leave the boat and hide the kids :)
- mtaylor, popeye the sailor, clearway and 1 other
- 4
That's a lot of ship for just over 2 weeks
1/54...this will be BIG...nice!
Robin
Thanks Robin
Not too big 815mm long, nowhere near as big as the Caldercraft Victory
- Robin Lous, Elijah and EJ_L
- 3
I too get the stray dog hairs on my work. Found one glued to a port lid the other night. Must have gotten right in there when I was installing and I overlooked it. I don't mind those as much as when I see one of mine and I start feeling feeling for that receding hairline that runs in my family.
As too the hatch covers, I would think that they would be rather heavy duty in order to both stay as water tight as possible and not to easily come unseated in rough seas. I could easily see two people having to lift them up and out of the way. Large rings would be a benefit here so that a sailor could get both hands into the ring to lift it.
Either way, hatch looks great!
Thanks EJ
Too big, or not i'm happy with them :)
Nice planking Bob!coming along nicely.
Thanks Zoltan
- zoly99sask and Elijah
- 2
Hi Rob
I could easily make them out of walnut but i don't want to be replacing all the wood in the kit (been there and done that) some times you replace it and the stuff that arrives in the post needs replacing too and you can easily double the price of the kit that way.
Occre kits are pretty cheap compared to others so i don't mind too much making bits from Lime and then painting them Walnut colour
The Occre Endeavour is cheaper than the other Endeavours but it is larger and has the sails included so a bit of painting is ok
- Elijah, popeye the sailor, cog and 4 others
- 7
The coverings I know from the barges on the IJssel and the Rhine. However, those don't have the rings, and look way lighter than the impression I get here. I know contemporary materials are lighter, and we can do much more with the power tools available to us, but it struck me to see it this heavy
The crew could probably have lifted them without rings as they are only planks over the hatchway to cover it. How accurate it is i do not know but i am just building it as the manual states with hardly any modifications. Historical accuracy is not that important to me
Nice touch, the dog's rope or is it one of the cat's tails ... a bit early to get that out of the red baize bag ...
I've always wondered, the planks on that main hatch cover must have been like beams if you need eyebolts like that on them to lift them ... what's the 1:1 size of them?
Probably the iron on those Hatch Boards is over scale, also every hatch board I have seen had the lifting rings recessed when not in use. Hatch Boards were used to seal up an opening in the deck from the elements and were usually covered with a water proofed hatch cover made of canvas. There should be provisions for a ring or Battens and wedges around these types of hatches, unless it is a fish hold and water getting in did not mater. Grates were used for ventilation and warships using black powder needed a lot of ventilation, merchant ships wanted water tight spaces below decks to protect their cargo, hence the differences in covers.
jud
Thanks for the comments guys
I agree they are oversize, but i don't really care i am building it OOB just for the fun of it. :)
With my AL San Francisco cross section kit, I tried to blacken the brass (supposedly) cannon with Birchwood Casey's Perma Blue and didn't work.
However, it succeeded with the steel cannonballs.
Brass is very difficult to blacken properly compared to other metals, and the Birchwood Casey stuff is mainly designed for blackening metal gun parts.
Others however have had great success with it
That hatch is excellent. I may have to give that blackening agent a try.
Thanks EJ
The Krick stuff works best if the solution is 50/50 agent to water and it is warm. I put whatever i am blackening in a plastic container and put just enough in to cover it then i float the container in a bowl etc filled with boiling water and keep topping the boiling water up periodically until the desired colour is acheived
Red Dragon by riverboat - Artesania Latina - 1:60 - Chinese Junk
in - Kit build logs for subjects built from 1851 - 1900
Those little doors are amazing
