Posts posted by cobra1951
If those planks are plywood be careful when you soak them because the layers will come apart. Bending should not be too bad as it looks like the planks are already shaped to allow for the curvature of the hull
- foxy, popeye the sailor, Elijah and 1 other
- 4
So the end is in sight, but the list of jobs usually gets a bit bigger lol
- foxy, Robin Lous, clearway and 1 other
- 4
Thanks Frank
Progress was faster than normal for two reasons, 1, i had more time to get on with it and 2, i used CA for all the planking which means the one you just laid is dry before you put the simulated caulking mark on the next one. I find with PVA i need to hold the plank down for a bit till it grabs
Colour blindness must be a great problem for you with parts of this hobby. However you seem to overcome it and do a really good job with your painting. Remember it's your build and as long as you are happy with it then that's the main thing. Keep up your good work
- marktiedens, WackoWolf, EJ_L and 3 others
- 6
And very welcome you are, did you bring any pringles ?
- Seventynet, EJ_L and Elijah
- 3
Hi Ian
Having double checked you are indeed correct, my bad interpretation of the planking rule
Still my favorite one though
- EJ_L, Elijah and Seventynet
- 3
Good start Bob,just kee it coming,I am watching it!
Thanks Zoltan
- Elijah and zoly99sask
- 2
Nice work Bob! That 4 butt shift pattern looks sweet.
Ian
Thanks Ian
Count again though it's a 5 butt . I use 5 butt shifts because it doesn't make the deck look overloaded with joints
- EJ_L, Seventynet, Elijah and 1 other
- 4
Nice Work on the aft castle
I see some very fiddly work coming up
- popeye the sailor, Torbogdan, Elijah and 1 other
- 4
Thanks Don
It's 0.6mm x 5mm Lime wood but it has a good amount of grain in it
The bottom deck is the same wood but with no visible grain to it, as the bottom deck is not visible later on i though i would plank it with some Lime i had lying about and save the grainy kit supplied stuff for later in the build
- zoly99sask, EJ_L and Elijah
- 3
- Seventynet, Captain Slog, riverboat and 5 others
- 8
Looks great Frank Are you fitting sails or just leaving her rigged as if in port ?
- Seventynet and mtaylor
- 2
Nice as usual Don . The Colours really compliment each other
- Seventynet, Canute, EJ_L and 3 others
- 6
Greek Bireme by Robin Lous - FINISHED - Dusek - Scale 1:72 - First wooden ship build
in - Kit subjects built Up to and including 1500 AD
Very nice work on the oar holes. Thanks for the colour insert, looks almost the same as the light teak I have
