Posts posted by juansystem05
Nice boat, really pretty result, I was actually looking for paint schemes and liked the same you did, great work, I was thinking about making this boat from plans (from where that paint scheme comes) but decided I am going to wait for a kit to show up on Ebay, meanwhile I have the endeavour 1/80 and 1/35 and the rainbow is still available in 1/80 scale as well
thanks for sharing- Dave_E and David Lester
2
- Yarr McNarr, Altduck and GrandpaPhil
3
Any progress?
I have this exact same kit and this is the only build log I have found so far. Great work btw hope you can make some more progress son
the lady nelson looks great and also I found some video logs which will be very helpful!
some filler and sanding did the trick, at least it looks decent now
Deck planking is complete too!
This newer version of the kit is low quality, plywood is not genuine, I mean is the chinese version of the real deal. Only looks good, it is weaker and only outer layer is made out of the actual wood it is trying to imitate. The inner layers are made probably of scrap wood. Instructions are also not good. I am sad for AL this is probably why they went to bankruptcy , their previous kits (I own some of them) where a good deal for the price and had nice quality wood. Also the availability of the kits was great.- ccoyle and GrandpaPhil
2
I know I shouldn't be thinking about that at this stage of the build but It could be helpful if I get tired of building this boat and feel like starting a second one
so the question is, What kit do you recommend as second build?
I really like the occre endeavour but it looks very complex so I think it is not a good idea
thanks
Planking done!
The result is definitely not the best but still I hope that some filler will help to get a good result.
I am not sure how the edges should look like. Instructions only say to leave edges clear but not the shape they should have. The keel will be installed there and its thickness is the same as the false keel so the planks will not be covered. I dont know if I explain myself properly. My idea is to sand the planks at the edge so that they meet the edge smoothly and when the keel is installed no edge of the plank will be visible.
See the little diagram I made, the red line is what I understand from the instructions, just leave the edge clear. The Blue lines is my idea of how the planks should be shape so that the keel fits smoothly.
- GrandpaPhil and chris watton
2
- GrandpaPhil and ccoyle
2
Been very busy for a while (got married, have a son now) but I intent to continue with this model. Any help would be appreciated, specially some helps for the bulkheads as they didn't fit quite well the other parts from the kit. Perhaps I can try trial an error this time.
I was just about to buy this kit again Brand New, but the one I have is only missing the bulkheads and keel so I don't feel like having too many extra parts.
Hi Sam! Did you ever finished this model?
Bought one from Ebay, unfortunately it is very incomplete , missing almost all wood parts and Sheet 2 of plans
Any chance you could help me with sheet 2 of plans?
I can buy more wood and see if I am able to cut my own parts
The few pieces I have are being very useful, I am taking measurement from them, the rest is estimated, hope it will work. Perhaps my plans can help someone else in the future
Thanks folks:
Your help will be very useful.
I have some basswood and birch plywood which I intent to use for the missing parts
Hi:
This is going to be my first build. However it will be a challenging one, my skills will be put to the test immediately and that is because the kit is incomplete. It is missing all the hull parts, keel and bulkheads are not present.
It might not be the best idea to start this hobby with an incomplete kit (I have a few others complete) but I like challenges. Wish me luck.
Hi folks:
I have this same kit and I see it is older than me (I'm 26) but my question is:
Do you recommend me to work in this kit as my first plank on bulkhead model? Should I start with something easier?
I also have the latina swift but unfortunately it is incomplete
no bulkheads, no keel, everything else is there.
Anyway, thanks in advance for your help
Juan
Sailing Fishing Trawler by juansystem05 - 1:38
There are some boats like this available from manufacturers like billing boats or AL, however not in the size that I like, something a little bit larger. This is intended to be around 80cm long. Image is just for reference, this will be a fictional boat but based on boats from that era. I have found some plans of similar boats of that era and will use them as reference. This boat could also be scaled for RC conversion, perhaps adding more bulkheads and a motor.
The intention of this thread is not only to create a bigger model of very known type of vessel but to show my designing skills. It has always been my dream to design model sailboats, both static and RC, ever since I was a little child this was my motivation to learn about technical drawings and later in life about CAD, CAM, CAE. Nowadays I find myself being an engineer and professional 3D mechanical designer though I am more in the automation and electrical business.
However my love for model ships is stronger than ever and I want to put my skills to the test in this specific field. Over the years I have design all kind of devices, machines, robots and decorations for laser cutting but only a few RC boats, some from 0, some others based on plans and some just to correct errors in plans using 3D modeling as a tool.
My building skills are not the best but I have built kits from various manufacturers, including AL, amati and occre. I have found occre kits particularly well engineered, some kits from amati were decent, some others left a lot to be desired like parts not fitting properly and having to modify the pieces. AL all kind of good and bad experiences being that they were the first kit I had and I have a lot of them, some very old some recent so I think it is normal to find inconsistency.
I do not intend to to open a company to manufacture model kits as I already have a business that takes most of my time but hopefully some of the already existing manufactures could be interested in my work, my biggest asset is my love for sailing ships, from galleons to modern sailing yachts. If not, I just simply love to do this.
I know all the process involved in creating parts for laser cutting, tolerances, material thickness, kerf, etc.. and this is especially critical with non flat parts. I will start the process by creating a 3D model.
Thanks for looking
