Everything posted by captgino
Thank you. Yes, I used an airbrush. Tough though to get a clean edge on wood. I had a few problems (paint bleeding) and had to fix with a paint brush here and there.
- 51 replies
- krabbenkutter
- billing boats
- 51 replies
- krabbenkutter
- billing boats
Yes. The deck is going to need some work. I think I found your build on Blogger. If it is you., you did a great job.
- 51 replies
- krabbenkutter
- billing boats
- 51 replies
- krabbenkutter
- billing boats
Some more painting... I did not glue the fish rack yet. It will be easier to work on the mast and rigging later.
- 131 replies
- finished
- artesania latina
- 51 replies
- krabbenkutter
- billing boats
Hello everyone, I was asked to finish this ship on behalf of a fellow shipbuilder who past a few years ago by his daughter. The Hull was completed with a few mistakes here and there. Some repairs were needed to get it as smooth as possible. The deck furnitures were also completed for the most part. They do need some love and attention. Here is a picture of the ship now. Started to work on the rails and discovered a few problems. Repaired Here is the result after the rails have been installed
- 51 replies
- krabbenkutter
- billing boats
Quick update. The holiday season brings a lot of projects around the house. Therefore, my progress are limited. Nothing is glued or painted yet.
- 131 replies
- finished
- artesania latina
Small update. Worked on the tiller. It still needs to be painted. I also have added a few attachments.
- 131 replies
- finished
- artesania latina
Great work. I am loving the aged look you achieve on her. 😊
- 67 replies
- philadelphia
- model shipways
- 131 replies
- finished
- artesania latina
- 131 replies
- finished
- artesania latina
Primed her with a coat of vallejo white primer. I will let it cure for 12 hours before starting the next stage of painting. 😊
- 131 replies
- finished
- artesania latina
- 131 replies
- finished
- artesania latina
Here is my first attempt to the extra piece of the anchor system. Thoughts? Deck furniture completed. They are ready to be primed and painted
- 131 replies
- finished
- artesania latina
Beautiful work on the sails. Terrific pictures. Going in my 'tutorial section'
- 653 replies
- trabakul
- marisstella
Anchor system in. I still have to do some additional sanding to ensure a smoother transition. The plan from the Association des Amis du musée de la marine (AAMM) also has an additional part that I need to build and fit.
- 131 replies
- finished
- artesania latina
I continued working on the bow and added the breakwaters. Drilled the hole for the water evacuation. Prepare the template for the anchor system to be set.
- 131 replies
- finished
- artesania latina
- 131 replies
- finished
- artesania latina
Continued to work on the stern. At this point, I am not longer using the plan from AL and switch to the plans from the Association des Amis du musée de la marine. Much better and accurate. Starting to do some testing with the pedestals. Added some timberheads Realized in the morning that they were too high. Cut and fixed that...
- 131 replies
- finished
- artesania latina
Completed the deck conditioning and treenailing. There is some damage to the deck due to the fun i had with the drill bit the other night I think it will be ok as I continue to add more details on the top of it. Worked on the rudder. Pretty easy to complete since the kit provides you everything.
- 131 replies
- finished
- artesania latina
thank you. there was a bit of nervous during the fix rollout.
- 131 replies
- finished
- artesania latina
Working on the rudder and the dumb accident... The drill bit took the wrong angle and ripped through the deck. 😠😠😠 Removed some decking plank. Patched the hole and replank.🤔 Repairing is always fun 😅. Here is the result.
- 131 replies
- finished
- artesania latina
