mrcc
Posts posted by mrcc
  1. There has been a change in the browser experience when scrolling on MSW for me and my IPad. I noticed in the last 5-6 days when scrolling, the page is constantly refreshing and not loading the page in its entirety (at once) when first on the page. Quite irritating and it is only with MSW’s website on my Safari browser.
    Not sure why and if anyone else has this problem?
  2. Here is some wider perspective shots should anyone be interested.
    Deck fittings and railing is now done... which was easy work.
    PS I had to cut some strip wood from some darker walnut stock I have in order to get all the deck fitting matching to a darker walnut
    The last picture is the included boats with the kit.  I will try and "pump" them up a bit but if that fails I reached out to Kolderstock models in Holland as they have a scaled replacement boat that looks very good!
    I will be taking a little break now as I have a ton of fall yard work to do at this time and also to get ready for the winter tires on the vehicles.
    Plus perhaps pay a little more attention to my wife 😊
  3. Not as much fiddly work as I thought...
    Sanded back  the wood portion in joint B and C in the referenced picture in the preceding post and achieved a decent fit.
    In the end I put a little filler piece in joint A to complete the piece.
    The Mamoli instructions reference gluing the stem post at the bow at this time but I will glue the lion figurehead in first in the slot and glue to the keel and bow afterwards.
  4. Have a challenge here...
    Trying to get this fit perfect prior to gluing the bow stem post to the bow otherwise it will be very difficult later.
    My vintage kit was missing one item when I received it... it was the bow figurehead - a fairly important item in a finished model.
    I was so lucky my brother was vacationing in Prague last year and was able to get Daniel Dusek of Dusek Models, who now carries the license of Mamoli, to forward to him/me a new lion figurehead with minimal cost.
    Obviously from the picture posted that there is not a great fit... is it the vintage stem post or is the problem with the newer casting working with a vintage piece?
    I looked at lots of build logs and only in a couple did they comment about the ill fitting of the ornament... one of which had a solution listed in the log. I know I have to drop the figurehead further into the slot in order to allow the bowsprit (once placed at its correct angle) to clear the head/ornament.
    Solution: Cut back the wood portion of the B joint and the question is should I further open the C joint by filing back the wood portion or perhaps more difficult is opening the cast ornament (a slit the width of the wooden stem) between the outstretched legs at the bottom, and then sliding the ornament down until the two portion are aligned and tight at Joint A?
    The simplest solution of just filling the A joint would not work as it needs the clearance above for the bowsprit to be added at a later stage of the build... thus I need to make sure the ornament slides down further into the slot.
  5.
    Had to cut back some of the side gallery planking profiles in order to accommodate the side gallery ornamentation and then I focused on some of the stern decorations... she is surely starting to look pretty!
    Lots of reading ahead, looking at other peoples build logs on MSW and some dutch forums.
    A person always has to pay attention to the fittings, the corners of the fittings, as future fittings of these ornaments are sometimes laid on top of each other. Luckily these pot metal ornaments are easy to bend and mold with reason into the spaces they are required to go into.
    The color scheme I used is of course personal but I am always looking at historical accuracy.
