mtdoramike
Everything posted by mtdoramike
  1. When I purchased this kit of the Hellen, 3 of the frames were broken, I had to fix those, which was no big deal. One of the previous owners had put the hull framing together, but unfortunately they didn't do a very good job, which is why I think the work stopped at that point. I found that the frames were not properly seated on the keel, which caused them to protrude considerably higher than the lip in the inside of the hull that the deck has to sit in. I also found that this caused a ripple effect by not putting enough pressure on the sides of the hull to expend the plastic hull enough to allow the deck to set on the hull step without really forcing it. So I took me old Dremel tool, with a mini saw blade and began to cut the tops of the frames off even with the step in the hull for the deck some of which was 1/4" off. I then shimmed the frames, which puts additional pressure on the sides of the hull, which allows the deck to sit inside the hull a bit easier and allows the frames to stay in contact with the hull sides. What surprises me is how easy people give up on something that is so simple to fix if they just think about it and learn to adapt and overcome adversity.
  2. Any 500 series brushed motor will work. The guy I got this kit from already had a 540 brushed motor for it, which is what I'll use.
  3. I can't believe there was never much of an interest in this kit considering the plastic hull. A lot of R/C folks like the plastic hulls.
  4. Beautiful job on her. Latina has great instructions usually, but sometimes the translation can get in the way causing confusion. I have built a number of Latina kits so I'm quite aware of these pitfalls. So I try and read several steps ahead on the instructions, double and triple check before final glue up. I usually build mainly by the plans and rarely build a model exactly as instructed. I will change things, especially if I find something that just doesn't make sense and do it my way. Sailor, is your Jenny R/C or did you go static? If so, what electronics did you use?
  5. Yeah Bob, it will be fully R/C ready to go. It came with a geared 540 brushed motor. When I'm finished it will be what I call receiver ready. All the new owner will have to add is their radio, receiver and battery in order to go trawling. I'm going to make the mast removeable in order to make it easier to pack and ship it. If not mistaken, this kit was later re-released as the Elena by Latina, which I believe is also out of production as well. I'm not a fan of preformed and plastic hulls, but this is one of the nicest plastic hulls I have seen, so it might win me over. Also, this hull is quite large at about 36" and about 9" wide, which will make for a very stable boat on the water and should have plenty of room for the electrics in the hull.
  6. I pulled the contents out of the box to get a look at it. The hull is some really thick plastic at least 1/16" thick. The hull is about 36" inches. couple of the ribs were broke, but no biggie. I also found the original receipt in the box from the original owner. The kit came from Model Expo in 1998. So this is one of those kicked around kits hopping to get built. I will give it a little love and fulfill it's destiny.
  7. Man I'm so far in the deficit I would have to live another life to score brownie points
  8. Thanks Mike. I'm preparing the Typhoon for shipment to it's new home, which will be upstate New York.
  9. Yep and yep, she is receiver ready all they have to do is add their own radio and receiver and she is ready to dance.
  10. The Typhoon will be going to a fellow in up state New York. The same fellow that received the 1930 mahogany runabout named Ratlin Rita that I finished late last year. Even though im not thrilled with the design of the Typhoon, i will still hate to see it go. It kind of grew on me while i was finishing up the build.
  11. Thanks CD & Chris, It was a pleasure to get the opportunity to build it. I had been looking at the Typhoon for some time and I didn't know if I would ever get the chance to build one. I just hope I did her justice. The biggest issue I saw from the git go were those windshields and they didn't disappoint in that aspect. I even made templates of the windshields front and rear before I did any work to them just in case I messed them up. I consider myself an average modeler at best. I think everyone should know their limitations and I'm fully aware of mine hahahahaha. Fortunately I didn't need the templates to make new windshields.
  12. Thanks, like I tell my wife, you can always dress up ugly, slap a suit on me, cut my hair, give me a shave and I don't turn out half bad. She will be taken out to give her a trail run, but yes, she will have a new owner.
  13. Finished, I used some of the blue and white rope I had left over from a previous build just to dress up the display base a little. I has been a fun ride and a great adventure, but all good things must come to an end.
  14. I wouldn't call you a traitor, but more like a thief for only paying $20.00 for this kit hahahahaha. I would have at least given her $40.00 for it. Now if you start feeling those pangs of guilt, I will be more than happy to ease your pain. You can send me the kit.
  15. Popeye, that PT would be a humdinger to build.
  16. I'm going to get a Artesania Latina Hellen kit from a friend. The hull as been put together, but that is as far as they got on it. I'm thrilled to get this kit, it's been out of production for a while and it peaks my interest, so I said what the heck, I get it and finish it. I comes with a 540 geared drive motor, speed control and a few extras. I'm not fond of plastic hulls, so I will see how it goes.
  17. You got that right, nothing like a pressed wood panel or better yet printed on wood. Better have a sharp knife.
  18. Thanks Chris, I picked up this kit for about $50.00. I wasn't really looking for one at the time, but when the opportunity arose, I figured what the heck I'll give it a try. I hated to see it getting kicked around and as you can tell from the looks of the box, it's been around the block a few times. I think I'm like the third or possibly the fourth owner of the kit and not much has been done to it other than missing a few parts. I have built a few Dumas kits and this is one of their old, old kits, no pictorials, limited instructions and basic building diagrams on the plan sheets themselves.
  19. Here is another orphaned kit that I came across where the original owner with all good intentions I'm sure started the build by taking most of the parts off of the parts trees and that is about where they stopped their efforts. At least from what I can tell is that they numbered all the pieces so no harm I guess. Upon inspection, I noticed the rudders and drive shaft struts are missing, which is easily replaced. This is an old kit, which has been bounced around from pillar to post. I hate seeing this, but I can't save them all. But as long as I'm able, I will finish it. The USS Crockett is a Vietnam area gun boat: is one of seventeen gunboats in the Ashville Class. This is the first group of US Navy ships to be powered by gas turbine. The Crockett was designed for Coastal patrol, blockade reconnaissance and support missions in South Vietnam. Scale 5/16" = 1 foot Length 51" Beam 7 1/2" Draft 4"
  20. The Typhoon is quickly coming to an end, a few things to tidy up, install the windshields and such. I will be a bit saddened to see her go. It is turning out to be a beautiful boat eventhough I don't particularly like the design.
  21. The Latina kit had very good rigging plans, I also subbed with Anatomy of the Ship Victory. Since you are in the UK, it might be easier for you to get some actual Victory wood from one of their refits. I was able to locate a piece and had it shipped to me over here in the States. It cost me around $100.00 shipped for the wood, but I used it to make anchor collars, mast heads, davits and a few other things on the ship. I then took the left over wood and mounted it in the display stand next to the Victory display base with a letter of authenticity and a note explaining the areas in which the Victory wood was used. It's a really nice touch to a magnificent ship and model.
  22. Im enjoying your build of the Victory Keith. I have admired Billings kits for years and felt their kit would make into a beautiful representation and you are doing a fabulous job on her. I built the Atesiana Latina Victory about 3 years ago now, which was donated to my local library. I visit her often.
  23. But, if Blue Jacket wanted to send me a kit to build as a comparison, I would be more than happy to do so.
  24. Thanks Mark, I was hesitant to mention the Blue Jacket Connie, which is also an excellent kit, but unfortunately solid hull if not mistaken, which is not to my liking.
