Jack12477
Everything posted by Jack12477
  1. I hope the Finance Minister approves all this Military Spending 😁😁😁😁😇
  2. Have you looked at Badger's In bottle filter I've used on for years
  3. It's simple ! Get a 15x15 piece of 1/2 inch plywood, coat it with Gesso, before that dries sift some backyard dirt over the whole surface. Let dry! (Use the finest mesh kitchen shifter/strainer you can find. Lay the Gesso on rather thick). Then lay the matt on to that base.
  4. Actually I didn't! I started out building model HO scale train car kits with my Dad when I was 10 or 11, got my first 35mm Kodak camera in 8th grade. After that it was both modeling and photography.
  5. I guess when they did my cataract surgery they sucked a few extra brain cells along with the cataract debris. 😉🤔 I was thinking I could avoid taping all the windows by not installing them till later. But I realized they are installed in their own frames which are then installed in the door frames. So matching the camo patterns across the frames would be a bear. So after coating the clear plastic windows, headlamps, in two coats of Pledge, I glued them into their frames using Gator's Grip Acrylic Hobby Glue, then glued the frames into the doors and windshield, glued the doors, except driver's door, into place (driver's door got taped in place from inside because the drivers right arm has to be glue to his body after the top is glue to chassis.) Then came the tedious task of taping all the windows, headlights, tail lights et al. Results look like this I think I will re-spray the green coat since it got a little mucked up in the process, then spray the camo coats. And this time I will try the Vallejo Model Air paints. Question for all you users of the Tamiya stands shown above: how do you keep them so new looking while spray painting? 🤔 Do you have two stands, one for spray painting and one for decaling etc? Sorry for the fuzziness in photos, the cellphone camera doesn't focus close and neither do my eyes at the moment. 😁😆
  6. Growing up as a wee lad post WWII, we had a neighbor across the street from us who had flown with the Lafayette Escadrille. I remember him telling Dad about their flight instructions/training. Basically classroom instructions using those airplanes on a stick, then out to the airfield for some static instruction on controls, then you took off solo, flew around then landed. If you landed with both you and the plane in one piece, they pinned your wings on and pronounced you an aviator/pilot. And yes he did talk about the castor oil and the post flight (sometimes in-flight) oopsies. I heard the same comments from Cole Palen, founder of the Olde Rhinebeck Aerodrome here, and got a whiff of the castor oil from his planes.
  7. Andy, seems Canada Post, UPS, and FedEx all use the same tracking software, I get those same kind of updates here, except here they mark it as "in transit" .
  8. I placed an order with Scale Hobbyist on 10/12, they shipped it out on 10/13 via UPS. UPS picked the package up in Nashua NH, transported it to Bristol RI, then to East Syracuse NY, then to Kingston NY to deliver to me. It traveled approximately 606 land miles to reach me. A car leaving Nashua NH would only need to drive 215 miles in 3 hours 45 minutes to reach me. UPS could have shipped it thru Albany NY a more direct route. But it did arrive in 2 days time on Saturday 10/15. Don't know how it was transported from Bristol RI to East Syracuse NY (air or road) but they passed right by me enroute to Syracuse. Don't feel bad Andy !
  9. While waiting for my eyes to heal and settle down, I ordered a resupply of Vallejo paints, thinners etc, and this new kit to add to the stash.
  10. I recommend using Hydrocal casting plaster, it’s lightweight, strong and easy to use. Woodland Scenics makes it. ScaleHobbyist is a good source for Woodland Scenics products including the rubber rock molds.
  11. Thanks! The 2 ruins are old Verlinden cast plaster kits I had. The 3rd dio is freelanced scenery using rubber rock molds from Woodland Scenics. Oops my bad ! The other Verlinden diorama is in my M16 Multi-gun Motor Carriage Diorama
  12. Yes, you're right Mark, but at 1:35 scale. Alan is right they are bulky, mine are about 12x12x12. Link is in my signature under Sherman tank dioramas I'm in too, Alan.
  13. I still have mine. But after several failed attempts at developing and printing color film, decided it was cheaper to let Kodak do the color and concentrated on doing B&W in the home darkroom.
  14. Yea, took the family on a 3 week drive from NY to Colorado, Wyoming, South Dakota and back visiting, Mesa Verde, Rocky Mountain National Park, Estes, Yellowstone, Tetons, Rushmore, Badlands et al. Left with 36 rolls of 36 exposure Kodachrome 200, ran out midway thru Yellowstone, had to buy 10 rolls of 36 exposure Ektachrome 200. Ran out of that too by the time we go home. Of course back then film & processing was cheapest part of trip. Sorting thru them was a fun time.
  15. That does look sharper and more depth. BTW Some camera terms ISO ( or ASA in the old days) is a measure of film speed or sensitivity to light. The higher the number the more sensitivity or as we used to say "speed". F-stop is the ratio of the cross sectional diameter of the aperture to the focal length of lens, expressed as f/nn , e.g. f/16, f/22, as the number goes up, the diameter decreases allowing less light to pass thru, as the number go down the diameter increases allowing more light to pass thru. As you go from one F-stop to another the amount of light passing thru increases/decreases by a factor of 2. So going from f/8 to f/11 ( or from f/16 to f/22) you let in 1/2 the light, reversing and going from f/22 to f/16 (or from f/11 to f/8) you let in 2x the light. So f/8 on a 50mm lens is the same as f/8 on a 300 mm lens, only difference is the aperature diameter. Aperature - think Iris of your eye. Same factor applies to shutter speed. f/8 at 1/250 sec is the same exposure as f/11 at 1/125 sec. Feel free to PM me with questions. I cut my teeth on mechanical manual cameras with hand-held light meters. 😅
  16. Nice looking model, nice photos. Great job as usual! 👍👍 Suggestion: For greater depth of field aka depth of focus, take the camera out of Auto mode and select Aperture Preferred mode, designated as Av on most camera dials. Choose an aperture of f/16 or higher, e.g., f/22, f/32, (my Pentax DSLR will go to f/32), leave the ISO setting on Auto, it might select ISO 3200, make sure the shutter speed it selects is 1/50 sec or higher, if you are not using a tripod or the deck railing, e.g., 1/125, 1/250, etc. I think your camera has Center Weighted and Spot metering and Center Weighted and Spot focus, if so select them also. Experiment a little, it's digital so no wasted film to worry about. Just delete the bad ones. 😉 You're shooting in bright sunlight so plenty of light. Remember the higher the f/nn value, the smaller the diameter of the aperture and the greater the depth of field/focus, the lower the value the bigger the diameter and shorter depth of field.
  17. And the Insurance on a aircraft is Marine Insurance. (It was one of Dad's trick questions.)
  18. At least it's not United Parcel Smashers or US Pony Express. 😁😁😁
  19. Modeling is on hold till my eyes readjust to cataract surgery. Right now even with cheaters I can’t see what I'm doing.
  20. Modeling is on hold till my eyes readjust to cataract surgery. Right now even with cheaters I can’t see what I'm doing.
  21. EG what scale are your F4 kits ? 1:48 or 1:32 ?
  22. Yes, Doris lives in the Czech Republic. Her husband died just before she completed her last build, she finished it as a tribute to him. Outstanding artistry.
