72Nova
Everything posted by 72Nova
  1. Hi Waldemar, Thank you for the compliment, I went with McKay's measurement of 37"-7" and your right it seems a bit too long, so I looked closer into the hull construction section and McKay lists half breadth at 23'-6" so 47'. Lee's mentions the davit is 7/9 the breadth of the ship which equates to 36'-5", better than a foot shorter, here's a comparison, original one is 68mm and the revised version is 66mm, visually not a whole of difference and still extends out further than the one on Victory 1737, I suppose I could shorten it still? Thanks for pointing that out, Waldemar, all the best. Michael D.
  2. Thank you, Patrick, it means a lot coming from you! The staircase and gangway are finally completed, all in all I'm happy with it and now on to the port side. Michael D.
  3. Thank you so much Ian, I used .20mm rope and 100wt thread for knots which are just overhand knots as to not look too bulky. A few progress pics, the stair railings are about complete minus the post caps, I wrapped the stairs with paper, glued in the balusters, coated both sides with CA and glued in placed, the cap railing is 0.38mm x 0.50mm. Thanks for looking. Michael D.
  4. With the fish davit about 90% complete, I started work on the short gangway and stairs leading to the forecastle, I highly doubt they were in use early on especially with the grating covering the main deck, maybe a bit later? but I like the look of them, still a lot of work left to do regarding the railings. Michael D.
  5. Hi John, It is a bit maddening working at this scale, my first attempt was the airfix vasa and currently working on the SOS and I'm actually enjoying working at this scale, check out my build logs, maybe you might something that may be of use to you? At scale those dead eyes would be around 13" in diameter, so less than 2mm at this scale, minuscule I know, my suggestion to you if you want to use those dead eyes would be to simply strop them with black thread, form a simple knot with and leave a pigtail, coat the knot and pigtail with CA to secure and stiffen the thread and feed into a hole in the hull, it'll look pretty convincing at this scale. I love those cannons by the way, I'll have to order some for my build. Michael D. '
  6. Shipman and Marc, I've always wondered about this also, but found no info regarding storage of the fish davit other than what Lee's mentions that It's placed athwartship on the forecastle, also both HMS Victory of 1737 and HMS medway of 1742 show the fish davit placed across the forecastle, I followed suit on my Victory of 1765, I know these are much later, but some things didn't really change much in a 100 years. I think it wasn't until after 1773 the fish davit was reduced in size and placed on the fore channels or thereabout? Michael D.
  7. Forecastle deck is starting to get a little crowded, with one cannon left do I started fabricating the fish davit, I know this piece is usually never displayed, but I like the detail..... this measures out at 37'-7" and about 18" square, at this scale it's 68mm in length and 2.7mm square, also have one span shackle fabricated and I suspect these could be rotated out of the way or removed when not in use to clear the deck around the cannon? anyways everything is looking presentable at this stage. Michael D.
  8. Now that the masts are completed, I shifted my focus back the forecastle by finishing up the cannons, fabricating the fore bitts and adding misc. cleats, still aways to go though. The armless crew member is there for double checking the scale, he stands around 5'-9". Thanks for looking. Michael D.
  9. Somewhat of a crowning moment with the completion of all the tops, masts and flagpoles, the Mizen top gallant masthead measures out to 0.75mm with the Mizen flagpole a mere 0.40mm at the truck. The masts are dry fitted showing their approximate rake. Michael D.
  10. Work continues on the masts and I'm quite happy so far with the results, as they line up true in the dry fit stage. Next, I had to calculate what size lines to use for the Fore shrouds and dead eyes, lower shrouds will be .35mm, topmast .25mm, top gallant 50wt thread and the royal shrouds are 60wt thread. Top mast dead eyes are 1.40mm, top gallant are 1.20 and the royal measure out to 1.10mm, these are just a tad overscale but look okay to my eye, I still may try to reduce them still, we'll see....at this scale the dead eye strops/plates are the futtock shrouds, I will use CA glue in the plate area of the thread so I can flatten it once it's dried to simulate the plates followed by some creative painting. The main royal mast is just about completed with the hounds still left to do, trestle tree, cap and flagpole. I also added the battens to the fore lower masthead. Michael D.
  11. A small update regarding the installation of the fore course buntline blocks, I used 1.5mm single blocks which are 12" at scale, simulated toggles to follow, also working on the main masts and tops. Thanks for looking. Michael D.
  12. That's for sure Ian, I'll definatley be testing the limits of detail I can add, with some quite frankly impossible at this scale. Michael D.
  13. With the completion of the royal mast, royal trestle tree, flagpole and all required eye bolts in the tops I can now focus on attaching all the necessary blocks. Cheers. Michael D.
  14. I can't believe I forgot about your wonderful Reale De France build, glad to hear you're on the mend. Sounds like a scratch build project that will be a pleasure to follow, I doubt I'll ever get to that stage. Michael D
  15. About 90% of the fore mast tops are complete with some detail sanding still left to do along with dead eyes, eye bolts and painting. On top of all this I still need to fabricate the trestle tree and flagpole, considering the scale I'm working at I think they look pretty good. Michael D.
  16. Happy New Year to you too Frank, it does feel good. Have you started another project after your Vasa? All the likes are much appreciated. Michael D.
  17. I've completed the fabrication of the topgallant and royal masts along with the associated top bases, these measurements are taken out of John McKay's book, this is all still in a very rough in stage at this point, fabricating the rest of the topgallant top will be especially challenging as the base only measures out to 8mm in dia = to approx. 4-1/2 ft at scale. Michael D.
  18. Hi all, after a short break I'm back on my S.O.S. In the last couple of days, I have completed the remaining port Fore lower dead eyes and chains, most of open gun port lids where the lower shrouds would hinder their installation afterwards, forecastle cannons in various stages with 2 of them completed, fabricated the 4 knightheads along the bulwarks and currently working the fore top and topmast with the goal of setting the fore mast assembly into the deck permanently real soon. Thanks for looking. Michael D.
  19. Looks every bit as convincing as if it were made of wood, well done!!. Michael D.
  20. The starboard channels and lower dead eyes are completed along with the port Mizen chains and few cannon port lid ropes. Thanks for looking. Michael D.
  21. With other projects under way, time has been limited on S.O.S but I was able to finish the main starboard channel, chains and dead eyes. Currently working the Mizen chains, I used a combination of flattened 24g copper and 28g copper to fabricate the chain, the dead eye measures out to 1.72mm, since there are no channels getting it so the shrouds clear the railing was a little tricky but I was able to make it work. Michael D.
  22. The runner is hooked to an eye bolt and you are correct regarding the tackle. Michael D.
  23. Merci Beaucoup for the compliments Ian and Marc. Michael D.
  24. The installation process for the tackle chain plates are different, I gave an explanation earlier but here's a visual to go along with it, the chain plate is led through a slot in the channel from above and the bolt fed through the hole and glued, then feed the bolt into the hull, as with the other chain plates I find no need to glue into the hull as the hole is drilled in a upward angle, the bolt is usually 1/4" to 3/8", snip off the extra with a cuticle cutter and touch up. Michael D. '
