Everything posted by Kevin Kenny
Haha, it caused some strife, but in the end she was very accommodating.
- 1,126 replies
Just returned from my New York trip. No modeling for some time now but lots of great additions to the shop.
- 1,126 replies
Replacement motor for Preac saw
Kevin Kenny replied to Kevin Kenny's topic in Modeling tools and Workshop Equipment
Email them directly with your request anchorbaymodels@gmail.com -
I just got on try typing “ ship ahoy model “ in google kevin -
- 1,126 replies
See that MicroMot transformer in the back ground there. A great set of tools.
- 257 replies
- pegasus
- Swan-class
Alan if you want to get a good finish you will need to place some temporary strakes inside the model. Use PVA which you can easily remove with 90% alcohol when you are finished and you will never know you put them there. The problem with sanding at this point is that there is too much movement in the frames. The temporary strakes solve this problem. When you are happy with the outside you reverse the process and temporary plank the outside and sand the inside. kevin
On another note Greg there seems to be some question on the use of bronze sheaves or wooden ones. The book seems to indicate that in some cases bronze was used.?
- 1,126 replies
Its an interesting response as in the Swan practium a number of the sheaves a number of the blocks contain Bronze sheaves.
I have been using a slight bevel to get a nice tight fit in some cases. In one case it resulted in my having to remake the piece 4 times. I do try to get the fit correct before using the bevel.
- 1,126 replies
Does anyone know when sheaves were changed from Lignum vitae to brass?
sorry but I had to remove the first time I uploaded this as I had a music copywriter problem. Now resolved. Video 94
- 1,126 replies
- 1,126 replies
Lighting upgrade to Proxxon band saw
This cost me $15 and I was able to hook it up to the saw switch so it comes on when the saw is turned on. -
- 1,126 replies
My iPad is giving trouble this morning. The answer is yes. The only thing is the time it takes the PVA to dry. I thought of using CA with the PVA to speed things up but so far have resisted. .
- 1,126 replies
The answer is yes. It just takes 30 minutes far have resisted.
- 1,126 replies
- 1,126 replies
- 1,126 replies
- 1,126 replies
