Everything posted by Kevin Kenny
Alan if you want to get a good finish you will need to place some temporary strakes inside the model. Use PVA which you can easily remove with 90% alcohol when you are finished and you will never know you put them there. The problem with sanding at this point is that there is too much movement in the frames. The temporary strakes solve this problem. When you are happy with the outside you reverse the process and temporary plank the outside and sand the inside. kevin
On another note Greg there seems to be some question on the use of bronze sheaves or wooden ones. The book seems to indicate that in some cases bronze was used.?
- 1,079 replies
Its an interesting response as in the Swan practium a number of the sheaves a number of the blocks contain Bronze sheaves.
I have been using a slight bevel to get a nice tight fit in some cases. In one case it resulted in my having to remake the piece 4 times. I do try to get the fit correct before using the bevel.
- 1,079 replies
Does anyone know when sheaves were changed from Lignum vitae to brass?
sorry but I had to remove the first time I uploaded this as I had a music copywriter problem. Now resolved. Video 94
- 1,079 replies
- 1,079 replies
Lighting upgrade to Proxxon band saw
Kevin Kenny replied to Kevin Kenny's topic in Modeling tools and Workshop Equipment
This cost me $15 and I was able to hook it up to the saw switch so it comes on when the saw is turned on. -
- 1,079 replies
My iPad is giving trouble this morning. The answer is yes. The only thing is the time it takes the PVA to dry. I thought of using CA with the PVA to speed things up but so far have resisted. .
- 1,079 replies
The answer is yes. It just takes 30 minutes far have resisted.
- 1,079 replies
- 1,079 replies
- 1,079 replies
- 1,079 replies
Looks great. I took two attempts to get it right. Made everything out of wood except the flute
- 475 replies
- 1,079 replies
The plank layout is not written in stone, it is simply a suggestion as to how it was probably laid out. It looks great so i would not take it out. kevin
- 475 replies
Just completed mounting my Proxxon shaper and band saw on Apple mac pro base. Jsut waiting on two more to complete my collection.
- 1,079 replies
Hi Yves No it has no smell. Coffee is grown on a tree and very old plantations produce a trunk that can be 6” wide. when the trees become old and tall they are usually felled and the coffee grove replanted. The wood was i]usually discarded. One of the biggest challenges in building scale wooden models is seeing grain in the wood used to make the models. Coffee woods grain is almost invisible and the colour is as white as you are going to get. It has turned out to be a fantastic deck board or strake which gives great contrast to other woods used on the model . The deck of the Thorn is coffee wood.
- 1,079 replies
