Kevin Kenny
Everything posted by Kevin Kenny
  1. Ken you can get bits from you dental supply for the turbo carver. I got a gift from my dentist of about 50 bits that he was not using, the equivalent of three dental visits in value. They were unused and in perfect condition. photo below shows the gratings cut out to be framed on the upper deck, Lots of extras for later on. I am glad that i made so many, as you can find so many imperfections in the ones i made even though i was so careful. And the truth be told it takes very little extra time to make more at the same time.
  2. Hi Tom the short answer is yes, i actually have 4 table saws, large Dewalt which i use to prepare bulk lumber, an old Proxxon which i use to bring stuff down to modeling size but not happy with the quality. A Preac which has all the accessories and one that i use every day and the Jim Byrnes, the best made saw in the world. I also have a Proxxon ban saw which i use daily but not happy with it but it is the perfect size. A large Dewalt cross cut saw and the Proxxon chop saw. Do i need them all? No. But they sure make life easy.
  3. I completed 17 gratings from which we will need 8. Just waiting on the termite fluid to dry and cover with rub on poly and then cut and fit with the respective frames.
  4. Allan I actually have a feather board but it only works with absolutely square stock. it was not as close as it looks. I always end up with a large piece at the end because of the risk of cutting my finger. I keep the end pieces and if I need additional stock I do use a piece of wood to push it close to the fence.
  5. I will do as you suggest Greg but I have been bending wood this way for some years now with little or no spring back. Most wood contains moisture in it. Even dried wood. Here in the tropics there is a great deal of moisture in dried wood as compared to very little if you lived in a desert. My experience has shown me that it’s of no benefit to wet or steam wood because of the relative thickness of the wood we use. The heat gun works wonders and almost 99,999% of the pieces I have bent hold their shape. I’ll be away for two weeks and will check it when I return.
  6. I Have removed that emotional video and replaced it with a more balance one.
  7. The problem was also on the starboard end which was out to much. After getting the port end sorted i beefed up the support on the port side by adding a stiffener, then used a clamp to pull in the starboard end to the correct position on the plan, then i took out the blow dryer and heated the starboard end back into the correct position based on the plan. After it cooled, it held its position. Leaving the clamp in place i restuck the stern. It worked. Thank you Greg. Please continue to keep an eye on the Thorn.
  8. I fixed the YouTube problem. Seems it made a change to key setting on its own. Not sure how that happened but I have corrected the feed. Back to the correction on the stern, I will have completed reinstalling the stern this evening. This time it is PERFECT. thank goodness. The inners are installed. once the glue dries I will instal the middle counter timbers.
  9. The error was on the port stern end that had come in too much. I have since sanded it down so both ends are now equi distance. Ill take a breath. Remake the transom piece. Establish the center line and then cut the mortises. Yea, that Greg fella is a pain. Thank goodness. This would have been horrible to fix later on. Thanks. K
  10. Somewhere during this time frame i will get the training on casting the cannons by my friend Bruce.
  11. Just termite treated the frames. I plan to work on the stern next, then plank the upper deck, then mover to the external planks. .
  12. I Just checked Greg and i have the old model mill. . Next time i go up to the US ill bring the piece up and get it reamed. Looks like a nice attachment. k
