Everything posted by Kevin Kenny
I am not sure of the type as it is a local guava that we grew up with but i will investigate and get back to you. The reason i decided to try is that it is a very bendy wood particually when dry. In my youth it was a favourite stick uaed to keep us in line. If your wood blanks are splitting do you paint the end grain? If you do not seal the ends of the planks it will split as the ends dry out before the center. This happens with most hard woods
Here is another wonderful video on the history of the Royal Navy from 1806-1918
The Caribbean remains a fantastic place to spend your vacation. I have spent almost all of my sundays from age 10 in a sailing boat with the exception of my time in University. I have also been fortunate to sail up and down the Caribbean literally 100’s of times, each time it always feels new and special. I would have made a very happy pirate in the 16th and 17th centuries.
- 163 replies
- america
- constructo
She looks great. I have found that applying heat off the model is the best way to induce bend. I have a Monocote blower but the truth is any hair dryer will work. Usually i make up a bend form off the model because bending on the model can cause something else to bend. I have to say all your paint lines look crisp and straignt. You have given your self a wonderful Christmas present. Enjoy the season. kevin
- 421 replies
- caldercraft
- granado
- 163 replies
- america
- constructo
- 163 replies
- america
- constructo
- 163 replies
- america
- constructo
CA adhesive, which one do you use?
Kevin Kenny replied to Modeler12's topic in Masting, rigging and sails
There is a CA remover that can be purchased. Most of us use CA and 5bere is not enough history to know the long term life of this glue. Having said that its such a wonderful and helpful product i would not stop using it myself. I tend to mix use all sorts of glues, PVA, EPOXY, 5 minute to 24 hours, CA thinand thick. Changes in humidity are probabely more of a risk than the glue you se. perhaps the best advice was given in an earlier post to make sure you have a rough surface and no a polished surface so you get a good bond no matter what glue you use. If you need to remove a piece that is already stuch there is usually a referance in the glue speck that tells you how to remove the particular glue. enjoy your modeling and do not over think it too much. Cheers -
Water on a ducks back
I am goig to suggest you look at Tom Lauria YouTube. Ideo. I feel its a but late for your model but its worth thinking about for the next project. He also has some hints on folding sails. best regards kevin
Go to Tom Lauria on you Tube and all will be revealed. I just completed my first Silkspan sails and it was not to painful. Toms video is excellent.
Finial thought on the build of the America of 1851.
- 163 replies
- america
- constructo
I was check some of my models. One has a knot preventing the line from going through the block another goes through the block and is tied to the mast
- 163 replies
- america
- constructo
That’s correct I just have to finish the two cases
- 163 replies
- america
- constructo
- 163 replies
- america
- constructo
- 163 replies
- america
- constructo
- 163 replies
- america
- constructo
- 163 replies
- america
- constructo
Finial pieces to the scratch built. I decided to use one of the anchors on each boat. I excuse myself.
- 163 replies
- america
- constructo
