Everything posted by Canute
On metals and resins, a swipe with acetone or denatured alcohol should clean most of that. I've washed resin boxcar kits in Dawn and warm water (not sealed up though) to remove mold release, plastic/resin dust and finger prints. Dry the kit, but don't touch it with bare hands after that. Rubber gloves are fine. Sometimes you may need to etch brass. Usually some kind of mild acid, such as white vinegar, does the trick. A short bath should do (5 min). Again, don't touch with your bare hands after you've cleaned it.
1/48 Italeri Hawk T.1A (On Hold)
Canute replied to Old Collingwood's topic in Non-ship/categorised builds
Guys who used the "silk let down" say it hurt for several days. Neck, butt, some times arms. Like Denis says, assume the proper position. -
Yeah, you could get hurt, but that was/is true of many of those seats. All depends on body position when you fire the seat. -
Good old M-B seats. They work. (Not that I personally experienced them). -
OC, no, it's a realistic view. Thankfully, you cared enough to roust his neighbors. Has to be a scary proposition lately with the lockdowns and such for some folks living alone. People need a focus outside of the day to day doings. We on MSW have such interests to keep our gray matter working designing, building and coloring. Model on.
They were the model for all aerodynamic study. They invented or better developed a model wind tunnel and pushed the engineering of smaller, higher horsepower engines. And they used wing warping to turn the a/c. I remember NASA doing tests in the 80s or so, investigating adaptive wings which weer essentially warped wings. Glenn Curtis and co developed the ailerons, which were easier to adapt to the wings back in the day. The Wrights were geniuses.
Coming along nicely there, Mike. Keep them coming. If they were using mechanical locks on the flight controls, the ailerons would line up with the wing tips and I'd expect the elevators to remain level with the horizontal tail planes. The lock was put in place in the cockpit around/through the stick. Not sure on the flaps; they were probably mechanical linkages, too. Mine were hydraulic, so they drooped when the pressure dropped.
