Canute
Everything posted by Canute
  1. Another good one, Denis. A different paint scheme to be sure. I like it on the pad, too.
  2. In Jersey or New York, that's a nuisance snow. Here in the Carolinas, it's a major storm.
  3. I don't wanna grow up and have to be a responsible adult.
  4. I'd be interested, too. I have one on the way; just biding my time due to my eye issues. Should be good in 6 weeks or so.
  5. Nicely done Denis. There are just so many different configurations for lighthouses. Yours is a beauty. The lighting will really enhance it.
  6. Dan, good looking bird. I remember building a number of the old Airfix ones. learned a lot about fixing them.
  7. Good job, Denis. Decals can be a bear to find/acquire the ones you really want.
  8. Cheap is good and it will get other use, too. Good deal.
  9. The Chopper in its various iterations works great on thin plastic and wood. I have 3 and like the one Ryland showed, since I can replace the cutting surface. Older ones were more likely to get gouged out under the blade. Cutting much over 1/8 inch thick stock, the razor blade deforms, marring the cut. I've done better with a low sided miter box, in conjunction with a razor saw, to make good standard angle cuts. If you need different angles, you may have to cut those angles into your miter box or make up separate cutting fixtures to cut those special angles. We're all tool junkies to a lesser or a greater degree, but sometimes KISS comes into play, too.
  10. I'm in, too. IMSA/SCCA cars are sweet.
  11. Just spotted your log. very interesting subject.
  12. Very nice work, Michael. Those dinky engines are a fascinating study. PS. I do hope the engineer/Engine driver in that last is drinking some sarsaparilla. Else, he'd be violating Rule G of almost any railroad about intoxicants.
  13. Yeah, with snow like that, corners can be adventures. They usually make them 4 way stops, at least in the places I've been, like Anchorage, AK and Goose Bay, Newfoundland.
  14. Quite the looker, Craig. I think I'd like a bit more stability of 4 wheels versus 2 if I'm smokin along at 200.
  15. Rye Field Models. After you and, I think it was Craig (CDW), showed their kits, I was sold. Read a few reviews on some armor sites, too. I can do research, just not able to see well enough to do the fine bits and bobs you're working on. Got another month before my first op on right eye, then 2 more weeks for the left one. I'm already cranky from the lockdown and it's too darn cold outside with the wind event we've had going on around here. Most of the white stuff Jack and Denis got up north was a swing and a miss down here. We got a bare inch of mostly slush. It's -2C right now with a wind chill making it -9C.
  16. I have the TUSK II inbound. I think it does any one of 3 versions.
  17. They also had howitzers which could lob shell and shot. As already stated, fusing was hit or miss, although they preferred air-burst shells for antipersonnel use. For direct fire against attackers, they had grape shot, rather large lead balls. As we neared the American Civil War, case and canister were developed for antipersonnel use, with better fuses. Like General Sherman said, was is hell.
  18. Hmm, could be an issue. How thick is the MDF?
  19. I have a Tamiya He 219 with a weight that the cockpit and nose gear are built around. If you are lucky, the kit instructions may tell you about how much to add, but most, especially older ones, don't.
  20. OC, assuming you plan to go ahead with this vignette, you'd need a hole in the roof big enough to show the framework the slates were attached to inside the roof. Then, scorch the exposed wood framing and scatter the slates about, suitably broken in places.
  21. Was part of the roof thatched? The French may have set fire in the eaves. I think Ekis' first solution would be the one to go with. You could open a hole and make a wood lattice under the hole. Paint black, dark brown and dry brush some gray (for ashy parts of the rafters).
