IgorSky
Everything posted by IgorSky
  1. I again disassembled the entire structure to continue working with the hull of the boat. Here the mast with sails is almost complete.
  2. Hi Nils! Many thank for your fedback! Yes, and boat and figures are in scale 1:72.
  3. First, for the assembly of the model, I glued a double-sided scotch to the boat support onto the timber bar. Then I realized that it's easier to make another normal slipway
  4. Deadeyes I made round blanks. Glued them in pairs. Then I sanded them with the sandpaper and attached the guys. Then I drilled holes.
  5. The next stage is the making of the mast attachment to the bench. Staples of thin sheet brass. Pins made of wire with glued washers.
  6. Then I painted the boat and the mast with a diluted bitumen lacquer. I also use it for tinting sails and rigging yarns, if necessary.
  7. Masting and sails. Masting of bamboo, sails made of percale with imitation of seams.
  8. Between the matter I cut a couple of oars and tried the figurines :). Because my bottle does not allow to make a version with oars, the oars will just lie in the boat, but I will have to make a mast with a sail.
  9. Hello to all! One of my current projects is a boat in a bottle. As a basis, I took a set for the construction of a boat from LAK-Design. This boat is on the 91st scale, but I plan to place a crew there, so it will be adapted to the 72nd scale. So, a pair of keel frames from the pear 0.7-0.8 mm was prepared in advance and I proceeded to assemble this kit. First I prepared a "skeleton" from a double keel frame, frames and conductor.
  10. Hi Nenad! Several years ago I visited this village of Kusturica Kustendorf (Drevengrad) too. This place is just amazing!
  11. Hi Carl! I added a few new items in the rigging of this model. This leads to complicating the process of assembling the model in a bottle.
  12. Yes, Carl, I'm trying to understand, but I do not have confidence yet...
  13. Many thanks Carl! I'm starting to worry about HOW I'm going to assemble this model in a bottle...
