Posts posted by peveka
BeerBear in mind that we are talking 2%-3% alcohol here. Tops. The alcohol works as a natural preservative. Because it didn't keep that long -at least not all the way to India- the Brits invented IPA for export: more hops (preserves too) and more alc. This beer wasn't meant for consumption en route, it was meant for the Brits in India.Cheers!
Pieter
Hi Gan Do
Welcome to the sawdustsniffers and enjoy Bellona!
Cheers
Pieter
- mtaylor and thibaultron
- 2
On 1/22/2020 at 2:15 AM, Gan Do said:
Any ideas. G.
Hi Gan
24 is a small piece of plywood 5mm thick that comes on 6 behind the metal part 74 to reinforce this part in the middle. You have to shape the sides of 24 at a 45° angle first. You "fold" 74 over this plywood piece so that the middle part of the metal with the 2 "doors" protrudes said 5mm and the side parts next to the doors (= 75) stand at an angle of about 45° when viewed from above. Put this piece into place before adding the deck (22)! You'll want to paint 74 first and add the doorknobs before you glue it in place.
Does this make sense?
Cheers
Pieter
Hi Carl
I know I know, too busy with other stuff ... I promise to pick up building soon!
Hope your ok, cheers!
Pieter
Will follow ;o)
Good start, best of luck!
Cheers
Pieter
I burn about this much wood every year (well mainly from October til April). And that in a part of France where winters don't happen... when we have half a day of snowfall once a year that leaves 1 cm of snow on the street everybody panics ;o) I guess it's a bit different in your part of the world!
- mtaylor and GrandpaPhil
- 2
10 hours ago, CPDDET said:
to buy a 77mm circular polarizer for my wide angle lens
Hi Dave
100 dollars minus the bender and some clamps plus hammer won't leave you much for a decent filter ... someone once gave me two cheapo pol filters and they didn't make me happy: blurry pictures and a non-uniform pol effect (I use an "ancient" Nikon D300S). I've bought a B&W Käsemann MRC Nano which is brilliant but it cost me about 140 Euros.
Just a quick heads up.
Cheers
Pieter
2 hours ago, Ferit said:
It would be problematic even if you step from #1 to #2 because the position of the knee doesn't allow easily to do that due to contacting with #3.
Hi Ferit
Maybe they just turned the lower part of their body to one side?
Source: me. I'm a retired physio, I've seen all sorts of "funny walks" ;o)
Cheers
Pieter
On 6/2/2019 at 3:26 PM, Henke said:
I nowadays spend more time with Aggy than I do paying attention to her. I did not know what to answer....
Don't worry, just don't start calling her (your wife) Aggy ...
Cheers
Pieter
- Henke and FrankWouts
- 2
Hi Jan
As you have probably read between the lines I don't really like these boxes but I'm going to do my very best to get a decent result. I may have to increase the dosage of my betablockers temporary.
As to drilling the holes: I used quite a lot of glue and the boxes are also held in place by the planks on the sides so I'm not really afraid of drilling. But, now you mention it: I am going to drill NOW before the hull is completely closed. Thanks for the tip!
I plan to leave the gunport doors on one side of Bellone closed. So what I'm going to do (that's the plan at this stage, we'll see what happens) is that I continue placing the faux carriages on the other side and depending on the result I'll either close one side completely or leave a couple ports open.
It's early days, 2nd planking is far away with beautiful weather arriving at top speed in la Bretagne! Beach bbq time!
I'll try not to keep you waiting too long for an update next time!
Cheers
Pieter
Ahoi Suomesta
in New member Introductions
Hi Noramatilda
Welcome to the forum.
Have you ever tried DeepL in stead of Google translate? Works great!
Cheers
Pieter
