skipper1947
Posts posted by skipper1947
  1. Thanks for the replies guys. Chuck, I am afraid your Winchelsea  looks a little above my pay grade. I guess when I said higher end, I was thinking along the lines of high quality components ready to be finished and installed. My tool set amounts to little more than a couple files and some xacto blades, which is in keeping with my manual dexterity.
    As for what I would be looking for, perhaps a yacht from the early 1900s such as the Bluebird of Chelsea, and since I am fantasizing; with high end wood and fittings. I don't see myself tying any more ratlines any time soon.
  2. I am kind of having that old itch to build a ship model kit. But it seems all the ones I look at, I have looked at a dozen times in the past and none get me excited. Does anybody know of any newly released kits? Preferably higher end. Sorry if this has been discussed, I tried a search for "new kits" but didn't turn up anything.
  3. On 8/4/2019 at 4:40 PM, JJT said:
    Check out Okumoto ship models. Not sure where to buy them though.
    Their web site is ec.en.ship-model.net but all their models say they are sold out. It has said this for the past while. Not sure what that means. Maybe they just don't ship outside of Japan?
  4. Has anybody had experience with the Krick Serius Shrimp Cutter? I realize it is intended for RC, with an ABS hull, but the deck furniture and fittings look to be top rate woods and metal, with a very attractive net, etc. I was thinking it might make a nice display model, but have not been able to find any build logs or reviews on-line.
    Thanks for any info. 🙂
  5. Just FYI, the corsaro II called for using the smallest diameter wire for the hand rails (among other things). I found it pretty easy to work with (probably easier than the larger diameter). To secure it, I re-purposed some small brass sleeves from a previous model build, fed the end of the wire through them, then crimped them with needle nosed pliers. I added a drop of zap-a-gap for good measure, then clipped the excess off as close as I could with wire cutters. They seem pretty secure.
    I will likely look into this jewelers wire for the larger diameters (my wife is familiar with the topic). One advantage I can see with this instead of thread (assuming you can solve the other aspects of it's use), is that if used as a slack line, it would lie in a more natural curve than lose tied string. (hope that thought makes sense).
  6. I hope this is the correct forum about this. The Corel Corsaro II comes with 3 sizes of steel braided lines. I have not worked with this material before. It is "springy" and wants to spring back if you try to fold it back on itself (like to tie off the ends). Also it appears the ends might want to unravel if not careful. Then too, I am uncertain how well it will "purchase" on a spar (i.e. not slide). Does anybody have suggestions for working with this material while rigging the model?
    Thanks. :)
  7. 3 hours ago, puckotred said:
    Anyone know if there is anywhere in europe one can get these kits?
    Search on http://www.amazon.co.uk  for Woody Joe, I just did and got 20 pages of hits. At least some were ship kits though there are lots of pagodas and such. Be careful of the prices though. I bought one from amazon in the U.S. and paid too much, it would have been cheaper to order directly from http://www.zootoyz.jp/
  8. I used some years ago, I think I still have a few laying around. At least your photo looks like the same thing. I think I just screwed them into the bulkhead- assuming it is thick enough to take them. The problem I had was that the clamping part was some sort of soft metal that did not stand up very long before they were bent back (looking more like the 'plastic clamp' in the left had picture of your post). Eventually, they broke (after being straightened out a few times).
    Can you tell if the metal ones look like they are made of a more sturdy metal?
    SKip
  9.  I was using the disc sander sanding both pieces at once and did not realise one had moved forward,
    Don't you hate when that happens? Something similar happened when I was gluing a hull/frame panel for my
    Woody Joe's HIGAKIKAISEN (with it's unusual hull construction). I was so focused on the gluing, I didn't notice that one side slide a little, making the entire thing just a little kitty-wumpus.
