Chuck
Administrators
Everything posted by Chuck
  1. It depends on the sheet actually.....but a few weeks. It doesnt ever entirely go away. It will stay yellowish as opposed to tan. The finish you use is important. Sanding sealer keeps it the lightest and less intense. Then wipe-on-poly makes it a bit deeper. Oil based finishes really bring out the deepest color. I have not tried any waxes however.
  2. I have been talking with the other guys and they want to keep it at this scale also....So I will. Since the Barge is 1/2" scale it just makes more sense. My new wood guy said it wont be a problem to cut and thickness the cedar on wider sheets either which I was worried about. I need cedar sheets that are 5 1/2" wide to fit these these frames on. So I am good to go.
  3. By the way....this is a big boat....16" longish. Is it too big? Should it be 3/8" scale instead. I cant do both. But this is the time to decide. If I get any further it will be too late and require too much redrafting. Maybe not....I will see what the fellas say when they see it in person Tuesday night at my club meeting. And getting back to the discussion about me having way too much on my plate to do this project. Let me fill you in on the timeline so far. My club met last month in my shop and we discussed a group project. It was decided that the long boat was the best subject. I was super busy working on making parts to restock. But a week ago I started drafting this from the new contemporary draft I had on file. Over the last week I spent only about 12 -15 hours drafting this model electronically and laser cutting the parts. I also built several prototype attempts as I tweaked those designs and also arrived finally at the image you see in my last post. Actually I am a little further along actually. But all included the project has only taken me about 12-15 hours thus far with most of that time being at my computer drafting. Maybe I have about 2-3 hours of actual build time. Thats it. This will be a very quick build....hopefully, if nothing comes up to ruin it.
  4. I hope this level of detail in the log will be good enough for the group build....please dont hesitate to ask any questions. Yes, I will also write something which will be available in PDF but it will pretty much just be this.....and whatever additions might come up during our conversations.
  5. Continuing along.... For those familiar with this design concept from my Queen Anne Barge kit, you will recognize the two-piece build board. I have however, tried to make some improvements with each new project based on watching others build them. In this case, I have added some slots for bracing blocks. Two for the transom and two for the bow/stem to stabilize them while planking. These pieces can be seen below. But do NOT glue them into the slots. These will need to be removed at some point in the build. It will be easier to remove the boat after planking without these in position. They are a press fit. If they are too snug....sand them a bit thinner because remember you will be removing them after a few planking strakes are completed. So make sure they are loose enough for that. There are two types of frames on contemporary models like this and the barge. One piece frames and two piece frames. Th etwo piece frames have floors and top timbers. We will be doing the one piece frames first and there are 5 of them. Another tip I was given by an individual can be seen below. You can see thin strips of packaging tape along the inner cut line. I used heavy and sticky packaging tape. You can fold over the end to make a tab and place the tape so it spans across the seam. This will give it added (temporary) strength while fairing and planking. The tape is put on both sides. The tabs will make it easier to remove the tape before breaking the inside of each frame free when it comes time to do so. Then once this is finished you must test the frames in their slots on the build board. They will be very snug by design initially. You dont want these loose and falling out of the build board. But you dont want them too tight either. You want to be able to easily remove them at any time. The best way to achieve the best fit is to sand the two tabs that fit into each slot just a little at a time until they are the perfect thickness. You will know when they are good because they will be firmly seated and yet be somewhat easy to remove. Be careful not to break the small tabs that hold the frame centers in the frames. No need to clean any laser char. In addition, test the fit of the bottom of the frame so it fits the same in its notch on the keel. Not too tight and not too loose. The three single piece frames at the stern are shown below being test fit. and the two at the bow should be as well. Dont glue these into the build board. That would be a huge mistake. With this completed, lets test the keel assembly on the build board atop the frames. Carefully place the keel assembly into the stern half of the build board first. This is a bit tricky if you havent done it before but once you do it a couple of times you figure out the little nuances. Slip the stern post between the two braces first as you carefully guide the keel onto each frame. Dont push to hard in each notch of the keel. You have have tested and filed those so they slide into each notch easily but dont fall out because they are too loose. NOTE the two small additional braces waiting to be installed next. The two transom blocks in the slots can be moved forward or aft so you can get a good fit against the transom. Remember that they are not glued in. The slots for them are longer than needed so they can be adjusted to best advantage. But once in a good position, you can add the two smaller brace blocks. These can and should be glued onto the build board. Use a little glue and push them into position against the transom. But DONT glue them to the transom. Just glue them to the build board. These will stabilize the transom even more while planking. Also use the laser etched lines on the build board to help make sure the transom is straight and not askew. This method differs from the one I used on the barge kit but I think its an improvement. Time will tell. Then repeat the test fitting of the keel in the bow half of the build board. Do it the same way except there are no additional stabilizing blocks. These two will do the job and keep the stem from wandering while you add the first few strakes up there. How it all looks at this stage. You will be removing and testing the keel many times before its time to glue the keel in position for good. Now to do the two piece frames. I also want to point out to those interested....look at the laser char edges of the frames. You will see how they are not dark and black. Yellow Cedar is very forgiving thanks to the oil present. It doesnt effect the gluing either and I am using Titebond II for all my joints. The build board is just basswood and you can see how dark that gets when laser cutting. I find it very enjoyable to work in Cedar and removing the char is much easier in my opinion....as Cherry and Basswood burn like crazy.
  6. This is 1/2" scale. I am slowly catching up with my inventory. In fact other than a few sizes of blocks everything is in good shape. I have 175 products now or SKU numbers. Three weeks ago I was either out of stock or nearly out of stock with 70 of them. But over the last three weeks I have been working like a dog and its now down to just ten items. Unfortunately these last ten will take a while.....they are mostly blocks which I purposely ignored working on so that I would be able do quickly attend to all of the other stuff. Now that the other stuff is good to go I am busy knocking off the blocks now. Aside from that....I am nearly finished working on the Stern Mini Kit for the admiralty workshop as well. That should be done this week. That will leave me with plenty of time to go back and forth between the Winnie and the longboat. The Pegasus Xsection will sit idle until this is completed because I think its important to get another group project going here and also in my local club. I anticipate this longboat will be a very quick project. It is NOT a very complex model to design or build at all. I have set a personal and probable deadline of September to get the longboat all finished up. Then I will get back to Pegasus. I have another update on this project coming today which will show you just how quickly this will come together. Chuck
  7. Oh Jeez!!! Thats bad. Hopefully I wont get hit by a truck any time soon.
  8. It also laser cuts like a dream Mark so if you can create the shape and laser cut it....it would be the way to go if its a complex curve. The beauty for Yellow Cedar in my opinion is that it takes very low power to cut through even 1/4" thick sheets. I set my cutter for low speed and lowest power to just cut through it so the kerf is the smallest I can get it. Because of the natural oils in the cedar it doesnt burn all that much so it works out great.
  9. You can still start a build log and join the online group. It will be available to everyone however when I start cutting the first kits, they will be reserved for those in the group. I wont even list them on my site until everyone in the group project has received their kit or starter package.
  10. You can almost tie planking strips into a knot. Its very very flexible. And really strong as well.
  11. Not a problem...I am very busy doing research on the rig as we speak.. I have made contact with the builders and crew of an 18th century longboat replica out of Halifax. They are preparing a long journey in 2020 and I am discussing some details about their rig and how they developed it. I am sure they have it rigged fairly consistent with early practice although this replica is a bit later from 1770's. Contemporary drawing of rigged longboat....useful for number of reef points and panels circa 1760-70.
  12. To better explain my dilemma... Here is a look at the cont model rudder. Its original. Here is the other cont model rigged. This is NOT the original rudder and was made as a restoration following the other model. This is the way it should be in actuality. Like my barge kit. Note the indent in the stern post which draws the rudder closer to the stern post. Its a very simple fix....but really does have a different look than the contemporary models. Should I just present the problem and allow the builder to choose which arrangement they want. By the way...that is the original rigging on that contemporary model. And the sheet and horse arrangement is 100% correct. So to change that would be to change it to something very wrong for this boat. A very different issue than the rudder hinge which is modeled that way as modelling convention that the contemporary builder used. The third possibility and probably the best one as it is less of a departure maybe. This is an original draft from around the same time that shows a way that I can keep the hull and stern post the same as the contemporary models but then change the shape of the rudder to have the indents instead. These are for the pintles and gudgeons and will also draw the rudder closer to the stern post. This would be my compromise if I decided to make the change and deviate from the contemporary models. I hope I fleshed out an example of one dilemma that I face among dozens on all my projects like this. Damned if you do...damned if you dont. So in the end as long as I explain the situation, you guys would know where I am coming from and can use any of the above to suit your fancy.
  13. It depends....sometimes they are not errors. Like the rigging plan. In other instances they are not errors either....for example the rudder. Its just a modeling convention they used. You see this a lot in contemporary models. They used certain model conventions and I think they are just fine in most instances. The contemporary builder didnt do it wrong because he didnt know how to do it. He probably could have literally walked down the street and taken a look at the original. It makes for a model that is less sterile in my opinion, and to me has a different look.....artistic value. But others who want to "kitchen sink" a model with every last historically accurate detail even though you wouldnt commonly see them on contemporary models...it tends to make some projects very sterile and busy....clinical. I wrestle with this all the time. I ask myself all the time, if I change this or that to make it appeal to the purist of clinical naval architects among us...will the model I am building loose what I love so much about the contemporary model I use as inspiration. I hope that makes sense. My time in art school has trained me to look at things differently than say an engineer would. I know many many engineers who model and they love to insist on adding every doodad and detail just like it should be....That is awesome for them. But its not my cup of tea. We have hearty debates over it all the time. But who knows, maybe I will continue to match those beautiful models because they are works of art in my opinion...but talk about and create an alternative drawing or notation for folks that are more like my engineer friends....its just a bit clinical for me.
  14. We shall see when the time comes. I may stick with the same rigging plan though as it is what they used back then. But I am talking to some folks and will see how horrible it would be to deviate from the contemporary models since this is actually a model of a model. But since they dont have sails maybe I have some wiggle room. There are a few things that are off on the contemporary models and one is the way the rudder is attached on both models. There are no notches in the rudder or the stern post to accept the hinges. Now do I correct that or shall I be faitful to the contemporary models....or just see how folks bash it and deviate based on their own desires. Lots of questions and deliberations as I design a new kit.
  15. No sorry Alan....too much redrafting to switch scales. It would just be too small to do accurately also. To keep it in scale the frames would need to be 1/32" thick if not thinner. Thats why I wanted to do this larger version. I had to compromise on that older 1:48 ME kit. Using basswod as is done in that kit the frames needed to be made 1/16" thick which is huge so they wouldnt break immediately. At full size that would be 4" thick. Did you ever see a long boat with 4 x 4 lumber for frames?
  16. I actually just caught a small error in my first go-around. More like an omission. If you examine the contemporary examples, you will notice that the unrigged model doesnt have holes on the top of the stem for rigging the stay. But the rigged version does. So rather than start over....I will use that first model I started as my unrigged version. I will add the holes on both moving forward however...and I am glad I didnnt start building my other version yet. But maybe tomorrow.
  17. I am going to build both as well. I think that having an unrigged partially planked version like the NMM photo would make a nice presentation. The partially planked version will remain unrigged so displaying them both together might be very interesting. When my local club starts building it together as a group I will have build a second one anyway.....to show folks up close how I did this-or-that. Chuck
  18. Both ways....there will be a version that is completely planked also. But I figured making one that compliments the barge was also a good idea.
  19. That is exactly why I left the char in place on all of those scarf joints. Since the parts were all designed to fit tightly its also good to not sand them at all so the fit remains tight.
  20. Unfortunately my best recommendation would be to start over and just use some strips glued across the tops of the frames.....it works the best and the blocks are overkill. More trouble than its worth as you will no doubt see when it comes time to remove them. I would also make a more general recommendation....try not to over think it and over complicate it. Sometimes the simpler solutions already tried do the trick just fine. There are over 50 longboat build logs I think....I dont think any of them approached it like this so you are in new territory here. As you are trying to find methods for a beginner and new builder....using those blocks creates a situation that will no doubt be frustrating and very tough to rectify once the hull is completely planked over. There will be very little room to get tools inbetween the frames or even get alcohol deep enough to soften the bond. Then one must pry up and out.....to try and avoid breaking the thin and fragile basswood frames because you wont be able to use any fore-aft motion to remove them. At least not initially. It will be very interesting to see how they are removed after planking, but again "I fully recommend that a beginner stay clear of this approach to stabilizing the frames"
  21. Not including bowsprit about 15" so it is NOT a small model. Should look very good indeed fully rigged and about 23" or so. I will know exactly once I develop the rigging plan. I am very fond of 220 grit sandpaper to remove char. I dont scrape. It is really not that much of a chore if you are willing to discard your sandpaper the moment it gets clogged and "muddied" with char. Otherwise you are just pushing the char dust into the wood grain of your pieces and it makes a mess. I always do a preliminary sanding with the paper to remove most of it along an edge and then switch to a clean piece of sandpaper to finish it up. Different woods react differently to laser cutting. Cherry and Pear being among the worst. They burn really bad and deep. The yellow cedar on the other hand is really good. There are natural oild that help prevent deep burning. Only a light amber residue on most thinner pieces and the thicker ones are still not that bad to clean up. Look at the notches in the last photo that the frames will sit in. You can get a good idea. I didnt remove any char from those at all and you can see the color is light and it is pretty clean from the start. Chuck
  22. This new larger longboat model will be build just like the Queen Anne Barge. All parts whenever possible will be laser cut including the planking which will be pre-spiled. Below is the plan in progress as compared to the actual contemporary model. Below are the initial parts that make up the keel assembly. There will be a more simplified version of the keel assembly and another that is lightly more chalenging. As is done on the contemporary model, lap joints will be used to connect the stem and stern post to the keel. The simplified version will just utilize a butt joint and laser cut scarph joint to attach the stem to the keel. I have started building the simplified version first shown on top of the photo below. Before removing the laser cut parts from the sheet, they were sanded down with 220 grit sandpaper on both sides to remove the char. Its easier to do while they are still contained in the sheet. Then the three main (5/32" thick) parts that comprise the stem, the keel and stern post were assembled. I used yellow glue to assemble them prior to sanding the char from the edges of each piece. In fact I purposely didnt remove it from the joints...they are laser cut fairly precise and fit together very well. Using tite-bond works great and the joint is very strong as long as you let it fully dry. Once dry I sanded the char from all of the edges and prepared to add the other (3/32" thick) cedar parts that make up the keel assembly. These were treated the same way. I didnt remove any char from the edges util after they were glued into position. They are very delicate and it is safer and easier to do after they are glued into position. These thinner pieces were centered along the keel leaving 1/32" on each side to form a rabbet or "lip" for the external planking. Next up I added the transom...it has a laser etched groove down the inside to help position it properly. It helps a lot but I was also very careful to also square up the transom properly in relation to the keel. Thats it for now....I have one last part to add to this stem assembly before I start assembling the frames. I will post that very soon.
  23. This is the start of my build for the Medway Longboat. There are two really special contemporary models in the NMM. This is a totally revamped and completely new longboat project with actually little in common with my earlier design for Model Shipways. It is based on an entirely different original draft and more closely resembles the contemporary models. In fact its almost identical as far as I can tell. It will be a true POF model with floors and top timbers. This model will be made from Alaskan Yellow Cedar with boxwood accents and molding. This model will be made both partially planked and fully planked eventually just like the two contemporary models. The fully planked version will show all rigging and also sails. Hopefully. A little about the contemporary models shown below. Scale 1:48. A contemporary full hull model of a ship's longboat, said to be from the 'Medway' (1742) (SLR0328), built plank on frame in the Navy Board style. The model is partially planked and equipped with a large windlass amidships for use when handling the anchors. It is mounted on its original veneered baseboard. Another model, SLR0330, shows the ‘Medway’ longboat rigged and fully planked. The longboat was generally the largest boat carried on board ship and could either be pulled or sailed. It was used for carrying personnel and stores as well as mooring and anchors work. When carried on board, the longboat was stowed in the waist between the fore and main masts lashed on the spare topmasts and spars. It was hoisted in and out by means of the large block and tackles rigged to the lower fore and main yards. A contemporary full hull model of the 'Medway' (1742), shown below - 60-gun two-decker ship of the line
  24. If you click on the topic below it contains links to indexes of every build log on our forum for kits. These are downloadable PDF indexes with links to every build log in alpha order. There are six revenge kit logs but no Sao Miguel which should probably tell you something right there.
