Everything posted by Chuck
Nice progress Mike. Ever-so-slightly, yes the planks are a bit oversized because everyone will need to make adjustments. It would pretty tough for everyone to place there planks exactly the same and with each strake that will open small gaps. Each builder will also fair the frames differently especially at the bow and stern. But with some care and adjustments you should get a really tight fit.
That looks beautiful Toni. It was a pleasure to follow you as you built it over the years.
- 1,449 replies
Thank You, Yes I did. I darkened the only one plank edge with a soft pencil. I usually darken the edge of the plank being installed against the one that is already on the hull if that makes sense. The plank edge already on the hull is left natural. But only after beveling it for a tight fit.
- 421 replies
- medway longboat
- Syren Ship Model Company
How are you coming along with this model. Havent seen you on the forum in a bit. Any progress? 😊
Making any progress on the project??? Any updates? 😃
- 57 replies
- rattlesnake
- model shipways
Excellent start Mike!!! 😄 You are the first unofficial member to start building the Medway LB. Hopefully there will be many more once it officially gets started. I asked mike to start building in Pear to see how it looks and maybe gauge some interest from others. I am not sure yet if I will offer it in Pear but lets see how it goes. Excellent use of those extra braces at the stern but remember you will need to snap those off after you finish planking so you can remove the model from the baseboard. So far the pear version looks very good!! Keep in mind that all of the frame parts are actually cherry (poor man's swiss pear)...but the keel and everything else will be swiss Pear. You would never know otherwise unless I mentioned that. Its a perfect match.
They are indeed very very different models!! I will post a photo of both side by side when I get bit further along
- 421 replies
- medway longboat
Thank You guys for kind words and support. Here is a quick look at some images of the plans as they are in development. Still lots of work to do on these but they are getting close. They wont be finalized until after I finish the hull but this will give you an idea of what this project will look like. And yes (before anyone asks) the images are altered and no parts shown will enable them to be pirated.....these are just pretty pictures at this point and all parts templates are on sep sheets.😊
- 421 replies
- medway longboat
Thank You!!! It will be all back to normal by Tuesday if all goes well.
- 421 replies
- medway longboat
I have no idea....I didnt stain and only used a poly finish. I am not sure how well cherry takes stain so make sure you experiment on scrap first.
- 421 replies
- medway longboat
Thanks Joe, Fulfillment will always be an issue. I make these kits because I want to build them myself and its just the logical next step to also want to make it available to everyone else. As a one man shop it will be tough in the beginning to fill orders but that is why I am making this an NRG/MSW exclusive. This project will only be available to MSW members. In fact, to buy any part of it you must enter your MSW username in my store. This will keep orders a bit more reasonable but maybe even drive up MSW membership. If most buy the starter package and just scratch the rest it wont be that bad to make all of these. I am actually already starting to laser cut the starter kits and keep them ready. They will be ready as soon as the plans and instructions are finalized. I will then work on the rigging plans and instructions after that. But the rigging plan including templates for all the sails will be available for free as a download here. Of course everyone can buy the material from me for the masting and rigging but this also gives folks an option to get that stuff anywhere....especially across the pond. So its a bit of a unique project for me that shouldnt be as difficult to produce as the barge. That frenzy has ended though and I can easily keep barge kits on the shelf now. Its just the first six months or so that is crazy. This isnt going to be a money maker for me.....its going to be a fun maker for me and I am eager to get a group started on our forum. I am excited to build this in a group with my local club where maybe a dozen of us will get together and actually work on it a few afternoons each month. If I could find a laser cutter with enough Cedar or swiss pear on hand that I didnt have to ship to them, I would probably outsource the laser cutting to lighten the load so I can immediately start work on the cross section and Winnie again. I guy can dream cant he?
- 421 replies
- medway longboat
I would probably use this size which is 10 lb but I wouldnt use black. I would get a brown color and experiment. I am not sure I would use this to simulate treenails though. I would only use the black stuff in various sizes to simulate bolts and nails.
- 421 replies
- medway longboat
Chuck...Titebond works really well for this. Remember that there is no tension on the filament. It is placed in a hole. Then after you apply Wipe on Poly it also seals the fishing line in. There is no issue at all as long as you wait for the glue to dry before you slice off the excess whiskers.
- 421 replies
- medway longboat
Thanks Dirk For nails I used 10lb black fishing line. Holes were drilled with a #77 drill bit. Then a sanded the holes lightly to remove any burrs from drilling. The fishing line was dipped in titebond and inserted into each hole. I worked on one frame at a time as shown. Once dry they were sliced clean away with a straight razor. Then some light sanding. Thats it. The port side is completed now and I am really hope to get the starboard side done quickly. We shall see. More pics below. Chuck
- 421 replies
- medway longboat
I just picked up a whole new load of Yellow Cedar. I am very happy to see that so many model builders have been trying it out and I think they will be quite surprised at how wonderful it is to work with. Especially with the price of boxwood going through the roof and so much poor quality boxwood on the market at the moment.
Its been a crazy two weeks. My Daughter is all set up at college and a room has opened up for my Mother In Law in assisted living. I will be moving her in this week so she is all settled by Friday....hopefully. Which one will get homesick and ask to come home first, LOL.😂 Anyway, its been a while since I had an update but I have fallen behind a bit understandably. I painted the cap rail and inboard sheer strake. I did this first before adding the knee at the bow below. I still have some touch up and repainting to do there but you can see the results so far. I have dozens of more coats of paint before I am going to be satisfied with the finish. I have also been creating and testing the frieze for the transom. Here is one such test where a sample is temporarily tacked into position. The size and shape is good and I am finalizing the color and design. Its getting close though even though this photo seems a bit washed out because of the lighting. Here is an image of the frieze on the contemporary model. I am not sure yet if I will paint the white border and the edges of the molding on this model. But we shall see as things develop. In addition i did start simulating the nails in the planking. I am using 10lb black mono filament (fishing line). Its going well but will take a good amount of time. I held the hull up to the light so I could accurately mark the locations for the frames. I couldnt start work on the interior with the floorboards and platforms until this is completed. Remember that these are nails and not wooden treenails. I wouldnt have been able to see the frames through the planking with those installed. So once this is completed I will move to the interior details. So this project is moving along even though it slowed down getting the two girls set up in their dormitories...LOL. I will post more details when I get some time to breath.....
- 421 replies
- medway longboat
Honestly though I didnt see any reason for a need to clamp the planking at the stern at all. I pre twist off the model and then just glue the strakes on with CA. No clamping or rubber bands needed. Clamping causing more issues than it helps on a delicate model like this. Its not as sturdy as a POB or large frigate. You dont need to use a hair dryer like I do but any heat source or mold will do the trick. Chuck
It was very nice....bitter sweet because its always tough dropping off your only daughter at college. Having said that......she wants me to drive down and bring her back home for labor day..... Nice clamping system...very hi tech. But be careful as the frames are still quite fragile. Too much force on those and the frames will break. Chuck
Looking very nice. You are making some great progress. Hope you are enjoying the project. Chuck
- 574 replies
- cheerful
