Chuck
Administrators
Posts posted by Chuck
  1.
    Searching for inspiration, I came across some models for 18th century pinnaces. There were large 32 foot pinnaces and many smaller examples to look at. I was particularly fond of a model from the NMM in Greenwich. It was a model of a 21 foot long single banked pinnace from around 1750. It would make an excellent subject for this mini project. It has a paneled interior and some decorative merits. I found an original draft on the NMM website that was almost identical to this small 4 oared pinnace. Things were started to come together nicely.
    I wasn’t necessarily thrilled with the color scheme shown on this model (pictured above) so I continued looking for some decorative alternatives. The pinnace was used a means of transport for a ship’s captain or other officers. It was not intended to be used to perform any other task. Tasks such as transporting water and other stores were normally left for the larger and heavier built boats like the longboat or launch. It was basically an officer’s private transport. It was designed to be rowed although larger pinnaces could be sailed. It wasn’t very seaworthy and was designed for primarily shore duties. After all, the officers did need a stylish way to get from their anchored ship to the dockyard. As such, the decorations were usually added much later at the officer’s and captain’s own expense.
    So here is my journey in creating this scratch built model.   The frames are basswood and everything else will be Boxwood.
    You can download this full set of instructions below as a PDF.  This was the prototype for the new Model Shipways kit.
    Chuck
  2. Two reminders ... The two Completed ship model gallery categories are for photos of completed models only. That's why they are named as such.
    Second ... you must include the name of your model in the title of your gallery folder! Think about this one, folks -- when people search for a model in the gallery, what search term are they most likely going to use? That's right -- they're going to search for the name of a ship!
    BTW, you don't have to put your name in the gallery title, since your folder and each of its images is stamped with your username.
    PLEASE do not post albums of your work in progress!  This gallery is meant to display the finished models and not become a second redundant build log.  It just wont work!!!
    Thanks in advance!  :)  :)
    If you have photos of your models in progress please post them in a build log or other appropriate forum category.
    Chuck
  3. This area is intended for your build logs of any scratch-built models you are working.  Whether they are wood, plastic, card, or RC kits.  This is the place where you can document your step-by-step progress.  Post images of your work and share your techniques and ideas with your fellow Model Ship World members.
    How to set up your log?
    Create a new topic for each individual model you are working on.  As you make more progress on it,  reply within that topic to post updates on it.  Please keep all such posts on topic with regard to the log you are working on and all replies within your one log.  Do not create another topic each time you want to make an update.  If you are only posting images of your completed model...please do so in the gallery.  This forum is for works in progress so we can follow along with your step-by-step explanations.
    How to Name your build log?
    We have a "Build Log Naming Convention" to enable the Search Engine to sort them Alphabetically by "Ship's Name" and/or "Builder's Name".
    We urge you to follow the guidelines below to make this work properly. If you don't, a Moderator will do it for you anyway - so you may as well get it right first time and save us the trouble.
    This is how your Build Log Title must be set up for Static Wooden Ships :
    HMS Victory by Fred Bloggs - Scale 1: 75 - 1805 as she appeared after Trafalger - First wooden ship build
    The first section in RED is MANDATORY and must be done EXACTLY as shown to enable correct Sorting by the Search facility. Note there are SPACES either side of the dash following your Username.
    Check other Build Logs for an existing one to see whether the "HMS" (or other prefix) is used before the Ship's Name.
    DO NOT Re-Title the RED section if it has been done by a Moderator.
    The second section in GREEN is OPTIONAL - you may add any further information you like. There is a much larger Character Limit than previously - 150 characters compared to the old one of about 40.
    (Note that the colors above are only for this demonstration - you can't Format a Title like you can with other Text)
    For Plastic, Card, Ships in Bottles and Radio Controlled the following (in PURPLE) will need to be added :
    USS New Jersey by giblets - PLASTIC - Superdetailed with PE
    HMAS Sydney by ship ahoy - CARD - 1: 100
    HMS Victory by Simmo - BOTTLE - 1/700 scale
    Vosper PT Boat by whereami - RADIO - A nice model to build
    Instructions on how to use the Search to find a Build Log list of the Ship you are looking for are in a pinned Topic in "Questions/instructions on how to use and post to this forum/Site Problems or suggestions".
