michael mott
Everything posted by michael mott
  1. I just finished a project to get an art show open my poster.pdf On the way home dropped into the fabric store looking for the right fabric and ended up in the wedding fabrics section and found a cloth that looked good but I'm not 100% on it yet mostly I want to do some experiments on the seams and eyelets or grommets. First I used some rubber cement to glue the tabling Then trimmed the edge the rubber cement stopped the material from fraying. Then folded the tabling, I will also do one with the added tabling this will keep the cloth weave aligned. The grommets are a little large these being 3/16 diameter which scale out to 1 1/2 inch, I will locate some smaller ones I know that smaller ones are made. I might end up making the ones I need. These grommets were for a canvas cover on a 7/8ths scale model and worked well so I will have a go at making some with the backing ring, one of the issues with the tiny commercial grommets is that they do not have a backing ring. neither do the ones I made, however for the sail to function well I want to ensure that the grommets are well seated through the layers of the tabling. By making my own I can also set up any diameter that I need. the eyelets for traditional and cruising sailboats under 45 feet being size 3 or 1/2 inch diameter and for boats over 45 feet being size 4 or 5 5/8 to 3/4 diameter. these diameters are listed in the "Sailmaker's Apprentice" by Emiliano Marino ISBN 0-07-137642-9. summer's coming and I do want to get the cutter sailing before summer is over. Michael
  2. Wow! seeing all of them they look huge, they look almost too big. I can see why they would look cluttered on the baseboard. OK so if this were my problem which it isn't I would do the following, Make a new base large enough to cover the area that the sweeps reach I would tone down the colour of the main field of colour to a softer pale greenish grey maintaining a border of the rich colours of the existing base, on the outside of a dust cover of some sort. I believe this would better highlight the nature of this type of vessel, and display would look integrated with a clear intent. regards Michael
  3. I think that both of these thoughts are worth considering. I seem to recall a number of models that had spars and the like displayed alongside and carefully arranged to compliment the overall presentation, bundling them just feels a little coarse given the exquisite nature of the model. If the model is to be cased then depending on the size of the case, the display base could sit inside the cover centered in a more simple flat base inside the glass then perhaps a single set of oars as you have shown, with the rest appropriately set up alongside. If the case were not to be wide enough then perhaps a fine drawing similar to the original rendering showing the oars in situ next to the oars on blocks. Oh its mush too complex a decision. You will figure it out I'm sure. Michael
  4. One of my issues with the foot to hold down the work from lifting was that it was just far too large and cumbersome, so I machined up a new one from Bronze and polished it I realized that i did not need it to be sprung like the original. I wanted to be able to control the area more tightly and might even make a couple of different feet I am now able to cut a close edge all I need to do now is practice using the saw. Michael
  5. Johan I would like to know how you cut these pieces with those snips Your work continues to amaze me is is so clean and precise. Michael
  6. Just checking in Ian, what a lovely job you have done on the planking and your solution for the transom worked out very well. I also like your deck planking. Hopefully one of these days I will get some of my own projects back on the bench to get finished. Michael
  7. Glen looking at the last picture brought to mind two model-makers of great renown Dr Bradbury Winter, and Donald McNarry. I do so enjoy your updates. Michael
  8. Jon the same goes for us out here. Normally the ice leaves the lake around the end of April this year the ice vanished on the 9th of April just twelve days earlier on March 28th there were still trucks on the south side of the lake with folk still Ice fishing. on February 19th the ice was 28 inches thick. We will be putting the docks in on April 30 and launching Maria May 7th Very nice work on all the fittings, the models look like they are waiting very patiently for launch day. We will need lots of pictures. Michael
  9. Druxey looking at these pictures is very inspirational. Michael
  10. Druxey, your work is such a delight to watch, exquisite work with the triple zero, the boats not too shabby either. Michael
  11. Good to hear that the health issues are sorted John, the model looks fantastic. Michael
  12. Thanks for the info Bob this scroll saw 101 was interesting The into music was a bit lame, but the chap was clear and demonstrated some great tips. Michael
  13. Thank for all the feedback and likes. The saw works as well as it probably can. and is smooth. The bottom line is that I prefer to use the hand jewelers saw, I did a number of cuts this afternoon the same shape using both types of saw, and with different materials. For me the hand saw works better, and faster plus I can feel the cutting. Metal is much easier with the hand saw. So this experiment is concluded for now. I have always preferred a band saw for long curved cuts. I can put a 1/4 inch blade on the big 20 inch band saw but a smaller saw would be good . the three wheel type are good for a small bench. We all learn to use different tools and also have our preferences. This was a good learning experience and taught me quite a bit about the pluses and minuses of scroll saws. Michael
  14. Smooth as silk I fabricated a strong lightweight arm from some 1/2inch aluminum plate I did not have anything wider than 5 1/4inches so had to make do with a slightly narrower height that the 6 that would have been optimum. I made it as light as I could, I probably could have made it a bit lighter but this arm is lighter than the original steel one and is much more rigid. it is clamped to the bottom slide bar with a couple of 4x40 cap screws. There is about 1/8th adjustment fore and aft on the top slide both for the blade and for the guide block. The cut through some 1/4 inch maple was very smooth and I felt that I had good control. Now to polish it all up and finish off the clamps for the top arm. Michael
  15. I just got back for an overnight in the city, Bob your comment about the rope versus the solid link makes so much sense, The other comment about a large coping saw is basically where i was going next with the top guide to keep the top of the saw in line without the spring. I'm off out to the shop now to sort this next part out. Michael
  16. Thanks for all the likes and feedback. I have read that one has to fail a number of times before the final device/tool/modification/invention works well. I can attest to that comment. The geometry of our human ability to use a hand tool efficiently and skillfully belies just how difficult it is to replicate those movements to accomplish the same work in a different way. The ongoing work on the saw has given me pause to think about the actual motion of the saw blade when fixed into a mechanical device that is mechanically operated versus the action imparted by the human arm and hand. I can now understand why the manufactures have used parallel arms, it allows for a consistent tension on the blade, which the sprung loaded top spring does not, at least in the configuration where the blade is tensioned with a compression spring. If the bottom slide comes up and the top slide is unable to pull up the blade..... yes it bends and snaps I did this a few times with older blades, increasing the tension on the top spring which I tried does not work either just as many blades snapped. I have used the top blade capture device from the original saw and fitted it to some 3/8 rod with a 4x40 screw sleeved to fill the larger hole in the original arm. I have also fitted a linked arm to the bottom slide that ensures a smooth up and down that is a constant and positive motion. I am now going to fit a new U arm between the top and bottom slides keeping the top slide housed in the top arm above the new U arm this will allow for a constant tension on the blade which needs to be set so that there is a slight angle forward from the bottom to the top the combination of these two conditions will improve the action I think. Teh top slide will also keep the top part of the U arm in a more guided position with no wobble. Tomorrow we will see. Michael
  17. A new direction is under way. First I cut off the top part of the U arm this will be the foundation of a new deep hand held jewelers saw this left the slide bar with the clamp for the blade for the bottom of the blade this will be fixed to the foot pedal with a solid arm link to keep the bottom slide with a positive motion both up and down I put the frame part for the arms of the original saw back on the base. and will add in a piece of aluminum u channel 1 1/2 x 3/4 with 1/2th inch wall section inside this is a piece of birds eye maple that will be fixed with the ability to slide forward and backward with a micro adjustment to ensure the blade is vertical. The top of the blade will clamp to a slide inside a metal support that will be sprung loaded to pull the blade up. Michael
  18. Having said that I am now rethinking a couple of things I feel that a new design evolving looking at the proxxon design, and the contents of my various scrap boxes. Michael
  19. Moxis I think that for the model ship work the saw that Mark linked to would be a good bet for the price. It looks like a good tool I wonder how many of the forum members have one and what they think of it? Michael
  20. Hi Bob and Mark, Yes a bit outside the box so to speak. Mark you are correct the whole U shaped piece moves up and down vertically the trick is to make sure that the blade is set vertical as well I am still working on that The use of the saw feels a lot different than a regular jewelers saw so I am unfamiliar with the fell of it , I will probably stick to the hand one for metal but I think that for some of the woodwork there is definite potential. Still a few kinks to work out but it feels quite promising. Tomorrow is another day. Oh yes and thank you all for looking in and the likes Michael
