Everything posted by Garward
Another Rope Walk
Garward replied to michael mott's topic in Rope Making/Ropewalks's Rope Materials and parts resources
Carl, thanks for the link, excellent design! -
MONTANES by Garward - OcCre
Garward replied to Garward's topic in - Kit build logs for subjects built from 1751 - 1800
Continuation Replacement of grating The grating made originally from materials of a set are replaced with grating from a pear. -
Hi, Theo, many thanks for an assessment of my work! -
Having tried some known ways of manufacturing of masts and yards (a plane-drill-file-emery paper and etc.), I have come to a conclusion that for qualitative manufacturing of round preparations in diameter 3; 4 both 6 mm and length more than 100 mm (for a booms and the top yards Montanes) it is necessary to do any adaptation. Having spent about 2 hours of time, I have made the hollow milling heads similar applied at manufacturing of round sites on axes of gun carriages. Heads are made of round steel preparations in diameter 10; 12 and 15 mm, length 30 mm with through apertures in diameter 3,2; 4,2 and 6,2 mm. At end faces of preparations the diamond circle makes crosswise prosaws, and then the file and конусным a pine forest generates a cutting teeth. Then heads are truncated till the length of 12-15 mm for reduction of a friction of the processed part of wooden preparation. The head is inserted into a cartridge of the lathe and on small turns through it rectangular preparation from a pear is passed. On an exit from a head preparation has in section the form of a correct circle, stable diameter on all length and a qualitative surface with an allowance on polishing to 0,2 mm on diameter. Final polishing is carried out by means of rather known simple adaptation from 2 plates which, however, allows to avoid substantially "excavation of holes" on a preparation surface.
ancre Le Fleuron by cabrapente - FINISHED
Garward replied to cabrapente's topic in - Build logs for subjects built 1501 - 1750
- 332 replies
- le fleuron
- 64 gun
Using a drill press for other operations.
Garward replied to Modeler12's topic in Modeling tools and Workshop Equipment
What kind of glue do you use on your seizings?
Garward replied to bigcreekdad's topic in Masting, rigging and sails
I use cian ZAP PT-30 and PT-20 glue and glue like PVA of various producers. -
The interesting design, allowing to apply various external drives - electric drills, screw guns etc.
For cutting of laths of a secondary covering in width 3-5 mm and thickness of 0,5-0,6 mm (wood - a pear, padauk, ebone) I have made "minifactory" for cutting and calibration of the laths, consisting of a circular saw (on the basis of FBS 12E) with the device for exact installation of width of a cut off lath, and also a surface gauge (on the basis of MICROMOT 50E) for calibration of laths on width (including in a package till 10-12 pieces).
