CDW
Everything posted by CDW
  1. I agree about repetition. I also wonder about the design of this particular kit. Something tells me this one is not based on a CAD design. I am sure there are modelers who could build this kit better than I, but I am in no position to make a silk purse from a sows ear at this stage. Looking ahead at the cowl, I see seven or more parts on the printed page that probably make up the finished cowl, but the plans show just one single part number, not two not three and sure as heck not seven.
  2. I put on the first two skins on the outer fuselage after putting on the inner ones. The fuselage outer skins go on in seven pieces. There is no way in heck I am going to get seamless joins. I used acrylic putty on the first join then touched it up with a silver sharpie marker. Not perfect by any stretch but it will have to do. Not going to be too much you can see inside that cockpit when it’s all said and done.
  3. They remind me of the Classic Airframe and Special Hobby kits from that era. Nice, limited run kits. Do you have the PCM Spitfire Mk IX?
  4. I think I was buying PCM kits in the late 90’s or maybe early 2000’s. I bought a few but never built one. They came out with stuff no one else did. Glad to see you are building this one. Mine are long gone, traded away for something else.
  5. 51st reunion of my old football team last night. Lots of laughter, sharing memories, and the type of interaction only a group of old athlete buddies can have.
  6. This guy right here has helped steer me towards Halinski card kits. As his first card model, he did a very respectable job on this Halinski P-51D Mustang kit. I very much like the way the kit build sequence went down and at how detailed it all was. Beautiful model. I have a few on order now, although not the P-51D. My First Cardboard Model (Halinski P-51D Mustang) (sympatico.ca)
  7. Thanks EG, but I might easily mess this one up. After paying a grand total of $16 for this kit including shipping and sales tax, I am not stressing at all if a blunder happens here or there, or even if I need to throw it in the bin. It's a learning experience and there is a lot I am not sure about. It's going to be quite a while before I can turn out a great piece of work in this medium, not the least of which is learning which company/designer produces the most accurate kits. Not to be too critical, but there is a lot about this kit that seems less than optimal IMO, but hey, since it's my first I could be WAY off base.
  8. Thanks Chris. Mine are crossed too. I can’t tell yet but should know soon.
  9. Interesting tank. Now I want to read up on its service record. Glad to see you doing this Alan.
  10. The kit plans call for structural wire bracing along the sides and top of the fuselage. Since the top can not be seen once the inner skins are in place, decided to include it only on the sides. The kit instrument panel needed some trimming relocating and cutting to fit. Fuselage formers were added and now it’s ready for the inner skins.
  11. Outstanding! I’ll be following along. Love the F.2B. Excellent choice. Where did you acquire your kit and frames?
  12. Everything looks excellent. Your attention to a working crew bring life to the model. Details are extraordinary here. Looking forward to following your future projects.
  13. Thanks for the encouraging words. I feel all thumbs on this, but it's something new. I am beginning to see where a few new tools could come in handy, like a small dapping set. Also, I need to work out a tool similar to something I used when doing auto body work. It's used to create an offset lip where new sheet metal can be welded on to old sheet metal so as not to cause a raised edge. Maybe that's an adaptation of the dapping tool, although they are round on the ends?
  14. Thanks to EG, got the throttle assembly sorted out and installed. Almost ready to put on the inner skins, then the outer skins will follow. Going to find out soon what building the engine is going to be like. Quite a few small pieces per cylinder.
  15. Great reference photo there AJ. Full color too, makes it all the better. Love your model paint and finish. The enamel laid down very smooth.
  16. What a menacing-looking bomb, that Fritz X. A fitting photograph for your model. Until you presented this thread, I never knew how she met her end.
  17. That makes sense but it wasn’t intuitive to me. Thanks for pointing it out. Maybe once I’ve seen this sort of thing a time or two it will become more obvious. Two sets of eyeballs are better than one.
  18. Is this typical of card model plans and instructions? In the following photos, the diagrams illustrate a throttle assembly located on the port side of the cockpit, however the illustrations are vague and do not give detail part numbers or any detail sufficient for the modeler recreate this assembly. I can guess and probably get close, but I can foresee this sort of lack of detail could become a problem with more complex assemblies. I found what appear to be the parts for the throttle assembly on the printed parts page. How the heck do you sort out this kind of situation? It’s not apparent to me what the folds are intended to be or exactly how to cut out the parts. I am going to “wing it”. Kentucky windage. I have added a few more parts to the assembly. Last thing added are the rudder controls.
  19. What a super project. Great subject to immerse yourself in paint, weathering, and fun. Is there any photo etch or turned brass included? Glad that sandpaper trick worked for you. It gives the clamps some bite.
  20. Thanks OC, but it's some very basic stuff and not up to a standard I will be happy with. I have a lot to learn to begin mastering this aspect of the hobby. One thing I know for sure: at this time, I will refuse to buy a card model unless there is also a laser cut frame set available for purchase at the same time. Cutting these parts out is a pain, but cutting thick card is much worse.
  21. I remember now that I bought these when first considering card modeling years ago. I have never used them before but will now have a reason. How often do you use the dapping set and what do you use them for?
  22. After I saw the photo Chris posted, I started to recall that I had bought a set of those tools some years back, Probably after reading where Danny was using them. I found them stashed away. 🤓
  23. Thanks again. Did not know about the dashed vs solid fold lines although I have seen both on my kit.
  24. Thanks Chris. Does it make a difference which side of the card you score? Intuition tells me to score the side where the fold goes up, regardless of if it's printed or blank.
