mikiek
Everything posted by mikiek
  1. With the kit supplied basswood you should be able to form a stick how you need it as you "nail" it to the frames. Just keep in mind that harder woods like walnut are not as user friendly and will often crack if you don't prebend them. You might give a thought to running white glue down the edge of the previous strake (maybe not all at once) and then using CA at the frame contact points. When it's all dry you get the best of both. Some of those hobby syringes with the big needles work well for the white glue. If you are going to stain the hull, do your best to get any glue off the outside. You can blot the CA with paper towels so it doesn't smear. White glue is best removed with a wet rag (rinsed out often). Even if you're going to paint it might be worth getting into the practice of doing this. Glue on wood (any glue) + stain =
  2. Sounds like a plan. Always looking for the proverbial "better mousetrap" Thanks for the feedback. Everything you're describing makes sense.
  3. Tom - I wouldn't worry about bending the bow planks too much. Yes they will wrap around the frame. They will also need a slight twist but you should be able to do that as you glue them. You shouldn't have to do that beforehand. I don't recall if you mentioned how you are gluing the planks or what glue(s) you are using. In those areas a dot of CA on a frame can hold the twist in the stick until white glue dries. Kind of like a nail. Basswood is easy to work with for tasks like that. The nice thing about CA is it dries quick so you can move on to the next plank, even while the white glue is drying. If you use just white glue and a clamp you may have to wait a while before continuing so that the glue can set. Of course if you don't like using CA then none of the above matters
  4. Allen - you are confirming the conclusion I am coming to. There are better choices for planking than walnut. THAT SAID - I do not want to start a debate about that here. I recognize that there are thousands of beautiful builds with walnut planks. Like a lot of what we do, it's just a personal preference thing. I love working with boxwood. Anyone who has followed one of my logs can attest to that. I used it to plank Niagara (and fell in love) but that hull is painted. IMHO it doesn't take a lot of stains very well and it's too lite colored for a walnut replacement. So for that walnut color we all love, I am still looking for an alternative. Kurt - I am going to give your "wet clamped" process a try. Can the drying time be reduced with a hair dryer or heat gun or does that cause too much shrinkage? I'm also curious about gluing while the stick is still wet. I've seen that CA works OK on damp objects. It was mentioned in this thread that PVA can too. Although I imagine the drying time is increased.
  5. Chris - I'm going thru my first experience with nails on another build. Although that one really doesn't need them. This build with the walnut is a single plank and I'm not sure nails are right for that. I've bunged up quite a few with the other build. Left a few marks. vaddoc - you're describing the breakage perfectly. Fibers on one side or one edge start to separate and that's all she wrote. Guess I need to try and understand the grain thing better. Will also be looking for a walnut replacement for future builds. I'm a boxwood biggot at heart, but I do realize there are situations where it doesn't fit well. Jagger - how true!
  6. Hello Mark - thanks for stopping in. This is going to sound strange but similar to what you said - I can feel the brittleness in the sticks. When I'm holding one tight in thumb & forefinger it's real obvious the stress I'm causing applying just a 1/8 rotation twist. With where I am in planking this build I've broken 5 out of 21 sticks. That seems high. Should we keep our wood in a humidor?
  7. Brian, Antony - thanks for the comments. I'm finding that it's not so much bending the sticks as it is twisting them. Mainly when gluing around the curve at the bow or stern. The sticks usually need a bit of a twist so they lay flat on the frames and that is where they are breaking. Of course you can steam a twist into a stick the same as steaming a bend. I'm assuming you let the stick dry out before gluing it?
  8. The wood I am using now is walnut. I can bend it just fine for the most part and if that's all it needs there's usually no problem. But if I'm planking a bow or stern and the stick (bent or unbent) needs some twist to lay flat on the frames, that's where I'm getting the breakage. Popeye's comment reminded me of something. Totally off topic but I was surprised to learn this - aquarists that maintain plant tanks often fasten plants to a piece of wood or a rock. The recommended way to do this is with CA. And the surfaces don't have to be dry for this to work. I was surprised about the dryness thing but it seems to be true. You just have to hold it in place for about a minute. I also would have figured CA to be toxic in an aquarium but apparently it isn't. FWIW.
  9. OK Chris - a couple of follow ups: 1. What style clamps do you use? 2. How do you manage multiple wet strakes? If leaving overnight is required (and I get that) I would definitely want to put down multiple strakes in one sitting. Otherwise it could be 4-6 weeks at one strake per evening.
  10. We all have to bend planks once in a while. While there are several ways to do it the common denominator seems to be adding moisture to the wood. Soaking it, steaming it, whatever. The wood softens up from moisture, we bend it, let it dry out, then glue it. At least that's what I've always done. While this will shape the stick, once it dries you've got a bent stick that is just about as brittle as it was before bending it. If you still have to put a little twist in it while gluing it is about as likely to break as before. Lately I've read a few comments that almost sound like the builder does the soaking and bending and then glues the strake while it is still damp. Am I totally misunderstanding or is this possible? If it is possible what glue is used? I suppose you would now have to wait for the glue and the stick to dry before moving on. How do you manage shrinkage?
  11. The reason I brought it up is you have to paint some very thin strips around the ports. To make it worse the colors you will use have a high contrast so ANY little overage or spot really stands out. I noted to a friend here that the masking (for just one side) is about 90 minutes of work and the painting is about 5 minutes. After a coat or two you'll tear it all off and likely have to mask the painted part so you can paint the rest. Another 90 minutes. When you do mask, be sure to seal the tape edges up with some clear paint. It'll keep the real paint from wicking up under the tape. Tamiya (maybe others) makes some good tape in several different widths. Get some really thin - I think it's 1/8" - some medium and some wide.
  12. I think the worst thing about planking is there seems so little to show for it. Not a lot of bang for the effort - until it is almost done. Then there's the challenge of making the last 2-3 strakes fit in the remaining space. Well I have a way to go for that. I laid the garboards first. Then for some reason kept planking up from the bottom half way finishing the bottom band. Then I realized this band is usually where you fill in those last few strakes. If things get too hosed up at least they're not in plain sight. So I stopped there and started top down. Top band is finished, I'm not overly wild about the outcome. I'm starting to think I don't like planking with walnut. The sticks always look so good in the bundle, fresh from the saw. But after you sand them they lose a lot of the luster. It also seems like they are always on the edge of breaking when they are bent. As a matter of fact in what you see in the pics, I have had 5 break. Here's how she looks right now: As you can see, I'm beginning to get below the 2nd & 3rd filler blocks. Not sure if I'll have to extend them or if the strakes will play nice. One or two more rows and I'll find out.
  13. The purple stuff sands very well and you can even wipe it down with a fairly damp rag to smooth it even after it dries. I really like being able to thin it a little and apply it with a paint brush instead of a knife. If you work at it you can put down a coat that is thin enough to still show some wood grain. You can paint over it just fine. As with any filler be sure you put down at least one coat of primer. I've found it best to match the primer shade with your paint color. Use white for light colors like under the yellow you will be using. Use gray under the green. Use black under browns & blacks. Speaking of yellow & green (your bulwark colors), think about how you are going to paint the bulwarks when you have the 1/32 strips glued in. It's going to take some serious masking to keep the yellow & green off the strips which will be red.
  14. Glad the air brush is working out for you. One suggestion there - get yourself some spare parts. The needles can get bent in a heartbeat and are useless after that. Depending on the brand parts can be a long time coming. Other parts - that little crown looking thing that screws on the tip, a brush cleaning set, inline moisture remover. Don't know if you have had to take it apart yet but when you do, count every screw turn and write it down. Great as they are, they can be very finicky when not adjusted just right.
  15. Floyd I have built the T37, the T24 Tug and I have their T50 Trimaran on the shelf. Looking forward to seeing that one on the water. Rumor has it there is nothing else like it for speed. Will does a great job with his products at Tippiecanoe. I really like the idea of a nice build that you can do something with when you're done.
  16. OK - I like the concept. So I have a laser line on the hull. Then what? Do you still need a stand of some sort to hold a marker to actually draw the line?
  17. Doug - you are correct and I forgot to add my usual disclaimer about the curvature. That's the main reason for using the string to get the initial surface measurement. It will wrap around the curves. When I walked the dividers down the frames today I was left with about 1/16 - 1/32 extra after the last step. That's easily made up when shaping the planks. My dividers have thin metal points on the end. When shaping planks rather than pencil marks I just stab the point into the plank. The hole becomes my mark. My problem is trying to whittle/cut/sand/file the plank edge down to the stab marks. Cutting with a knife (even with a straight edge) is problematic for me. A lot of times I use a mini hand planer to remove material. Other uses? Transferring measurements. I've used them in the opposite way a few times when an inset in a plan was blown up and I needed to shrink to scale.
  18. Shoulda looked at the pic closer. I thought it had something to do with the plastic on the deck. Something new and revolutionary guaranteed to change our hobby for generations to come.
  19. Getting preped for hull planking. I have laid the garboards (well almost) and they seem to have come out OK. It's been a while since I worked with walnut sticks and I forgot they don't like bending & twisting very well. Yeah I know to soak them but they still but up a fight. As I mentioned earlier there is no rabbet in this design so placement of the garboard leaves a little guesswork at both ends of the hull. So I glued a stick to the easy frames in the middle first. Got them situated and let the glue dry overnight before I started wrestling at the bow & stern. Next evening I did the rest. Here's what I got: Like I said these sticks aren't bending well. This one cracked while I was heat bending it. I tried to beef it up with some thin CA but it broke as soon as I tried to twist it at the stern. I hope this replacement piece will hold Next up was marking the plank bands. It's not really stated in the plans to do this but it's what I know. The challenge was to come up with the number of bands for the available space. Trying to figure with the actual measurements wasn't working out. Looks like a case for the dividers! I've preached about them before but never for this step in the process. While trying the actual calculations, 4 bands came the closest to working out so that's what I am going with. To get that marked on the frames here's what I did. Measure the surface length of a frame. I use a piece of string but paper or tape can work too. Set the dividers to 4 (4 bands) Lay the string flat and spread the long end of the dividers across the determined length. The short end now has that measurement evenly divided by 4 so that's the width of the band on that frame. Place the short end on the frame up against the garboard and walk it to the other end of the frame making a mark at each step. And there you have it. As the measurement will be different, do this for each frame. The cool thing about this I don't really care what the actual measurements are. I just know I have some length and I need to divide it by 4 and transfer that result (whatever it is) to the frame. In my Niagara build I show how to actually use the dividers to shape each individual plank to fit within it's band. This method is almost fool proof.
  20. Thanks Don - it appears that the bow is a somewhat narrower than midship. I think the strakes at the bow will be pretty narrow so that should make it easier to get them trimmed uniformly. I'm in the middle of laying the garboards now. I glued the sticks to the easy frames last night - waiting for the glue to dry. Tonight I will do the bow & stern. For the rest of the planking I am planning on working with 3-4 plank bands. The proportional dividers should make an easy task of that. I can already see that I "over-faired" some of the frames. I didn't take too much away, but the angle on some of the bow frames I made too sharp. I'll have to see if I need to add some shims to correct this, but I'll do that strake by strake. I've always said don't kill yourself on the first fairing. Wait and do it when you lay each strake. Guess I wasn't listening to myself
  21. Good call on the clamps Doug. I like that idea.
  22. I'm with you on the filler Tom. Our builds are not supposed to be finished like a show car. If you do have to fill: 1. Over paint is fine. Good luck if you plan on staining. It takes stain differently than wood. 2. Just put it where you need it. Not over the whole bulwark. 3. A trick I learned. Using Elmers Purple wood filler (probably others too) you can thin it out with some water. Not runny, more like molasses. Then you can apply it with a paint brush. For me it was easier to get it into the cracks and you can spread it very thin. Of course practice a little first.
  23. One ramification of no rabbet is that it makes the laying of the garboard a challenge. For most of the middle frames a garboard lays nicely and even butts up to the keel OK. But the last bulkhead on either end is going to require a serious twist to the plank so it will lay flat. I've also got a decision to make about how far forward to let the garboard run. Both ends of the stick will require some carving so it ends cleanly and I'll have to make sure the ends are actually glued down. Normally I would just cram the ends of the stick into the rabbet. I think this is going to make planking the entire bow a challenge as there will be nothing to grab and cover the end of the stick.
  24. Tom I use Titebond for Trim & Moulding. It gets tacky and sets a little quicker and it doesn't run even on a vertical surface or upside down. Regarding dividers, yes you can do the entire hull with them. As a matter of fact if you're planning on using them you probably should use them from the start. Get your bands from the hull planking plan and mark the frames. Use only the drawing that shows a half view from the bow and a half view from the stern. The other views distort the distances between bands. I always recommend getting some with thin metal points rather than the thick plastic points. There's some things you can do with the metal points that you can't with thicker points. They need to be able to stick into a plank easily.
