mikiek
Everything posted by mikiek
  1. Scott - castyouranchor.com had the figures. I've seen a lot of places that have them but this was the only one I found that claimed to be 1:64. I don't have plans to mount them permanently, but I do like them for photos. It really helps to give me some perspective. For instance, I never really realized the bulwarks were so tall - they come up to around your chin.
  2. Did I stump the band? I was mostly just thinking out loud as I don't plan on having them (other than the eyebolt in the deck). For a build it probably doesn't make much sense to have extra tackles hanging around.
  3. I picked up a couple of scale figurines that I would like to use in photos of my Niagara build. They're pewter so they need some paint. Can anyone point me to some info regarding U.S. naval uniforms preferably circa 1812? As a matter of fact just uniforms in general might be interesting. Thanks.....
  4. Question regarding the gun outhaul tackles. I've read that these were not usually installed during normal operation. Makes perfect sense - a real safety hazard. In theory they would be needed only before loading the first round and there was usually no rush in getting that load ready. There have also been some suggestions that there may not have been individual tackles for each gun. Possibly they were shared by neighboring gun crews. So my question is if the tackle is not hooked up where would it be? Stowed below? Draped over the gun? Elsewhere?
  5. Thank you Don. It may be a while. I used up my stash of parts & pieces for the port battery. It is now back to the grindstone to make enough for starboard.
  6. Glad someone is making progress. Lead on brother! Not sure if Niagara had this and I don't have plans in front of me. On a lot of ships the pintles are mounted to the rudder in a recess. This has the effect of bringing the rudder closer to the sternpost and making the tail end of the ship a little more hydro-dynamic - the wash from the hull runs over the rudder cleaner. Looks like Eagle had it. If you have that practicum check page 69. Probably never would have noticed it but I was just reading about rudders a few nites ago. Other than that your wood work is impeccable!
  7. I have said this before - I realize as a percentage, casualties were usually not overly high (although Lawrence was an exception). But I believe the injury and maiming caused during these battles - especially with carronades - may have been some of the most brutal in history.
  8. When I was young I used to be very interested in WWII and the fight in the Pacific. Carriers and the planes they carried was a hot topic and I read all I could about it. I remember a general description of the fighter planes as "a huge engine and just enough of a plane to get it and some ordinances off the ground". Don't know how true that was but it always stuck with me. Arming Niagara is giving me the same sort of reaction. No real crew quarter, no real stowage area, no galley, no room. Just enough of a ship to load a lot of guns on. That's all the main deck is going to be - guns. The main deck is half way armed now. The figurine is 1:64 so it matches the build scale. It's interesting to get a feel for the size of things.
  9. Sounds like you need to get into hard soldering. When done correctly the joints are much more solid. It's not that difficult or expensive. I've had a few suggestions/reminders to add pins to the channel edge, drill matching holes in the hull where the channel will be mounted and insert the pins as you glue the channel to the hull. Apparently the channels will get a lot of stress as you tighten shrouds, etc. Keep up the good work!
  10. I'm with you on that. It didn't make sense - seemed like a safety hazard.
  11. Elijah - did you ever decide if you were going to make the cockpit recessed?
  12. I've made a few comments already in this thread, but I will say again - this is so exciting Chuck!! I've never seen a kit developed before. When I open up the box I'll feel like I already know the boat.
  13. Just ordered a hi-intensity LED lamp. I think you're right about the shadows. They will play tricks. I have grabbed for rope with tweezers and literally missed 5-6 time in a row. A good excuse for some primitive vocabulary. I apologize for getting off topic.
  14. Sometimes I wish I could. I am looking into some additional lighting. Thinking maybe I am not seeing things well enough. What do you light your area with?
  15. Back to the assembly line My biggest problem recently is that eyes, hands (and brain) are not working together. I've done more than my usual share of stupid things during this process. Lots of rework....
  16. I've done what you're planning with the pump (kept in a drawer). It gets beat up and broken that way too. I'm still in admiration of you putting your nose down and grinding out all those carronades. The process is taking an incredible amount of time. I'm not even getting one per day.
  17. Nice pump! What else would you have done in those 2 nites? You didn't show the backside, did you paint and/or drill the water exit holes in the 2 columns?
  18. Time to break out the torch? Julie, what you discovered may well be, but you still have a beautiful build in hand! The ultimate decision is yours, but if it was me I would stay on the same path.
  19. Such an interesting design. So different than the square riggers that we usually build. Your build is coming along great cor_f !! Thanks for posting.
  20. Hope he's still out there. I'm curious as well Paul. Got this one on the shelf. Keep us posted when you start yours.
  21. I can't remember where but recently I read that these parts were set in a recessed notch-like area. So when mounted they were flush with the surrounding surface. I'll see if I can find that. Everyone seems to say don't glue to painted or charred (laser) surfaces. I haven't had problems with either.
  22. Wow. Looks better than before. Hope you were able to reuse your metalwork on the new piece. What do you use to glue the metal to wood?
  23. I hear ya E.J. - I probably have more kits than I could build in my lifetime. And I have no doubt there will be more. Elijah - close your ears La la la LA LA la LA la la.... Just counting down the days to retirement.
