Jsk
Everything posted by Jsk
  1. Thanks for the likes and checking in, everyone. OK, ignoring the two steps back of the crushed cabin I proceeded with the pivot gun. Thanks to @modeller_masa's tip above I was able to strop and reeve the blocks for the pivot gun. Actually, using masking tape to hold things in place was key to being able to do it. So simple but it totally escaped me! Thank you! I did decide to go with only two lines, though, and rather than have the falls coiled on deck I decided to place them out of the way inside the pivot ring. With the pivot gun finished I just couldn't let the dented cabin remain. Part of this was to see if I could fix the issue--This is a learning project after all (Aren't they all?). I was able to deconstruct the cabin by using isopropyl alcohol applied with a cotton swab. Once the glue had softened I was able to gently separate the cabin from the deck and then the roof from the cabin walls to get to the internal 1mm thick structural pieces. It takes patience to let the alcohol work its magic but it is possible. I did, however, break down and use of the duplicate wall and roof from the extra copy of the model that came when I purchased it. Looks like new. With that finished it was time to move on to the bow sprit and jib boom. I hadn't sized these pieces correctly. They remain more robust than the plans call for but I was afraid that taking them down to the specified diameter would make them too fragile for my clumsy, inexperienced hands. I fudged it. No one will know but me. (And everyone who reads this!) I then finished the various spars by adding cleats, etc., and painting. While I have assembled the mast tops I've not yet glued them in place and the masts themselves are only dry-fitted to the hull. I need to decide how I'm going to handle the main sail hoops before permanently attaching the top masts. A couple weeks ago I had ordered an extra set of blocks and dead eyes from @0Seahorse as well as some rigging material. They took a bit longer than normal to arrive but arrive they did. Today. Between ordering and arrival, though, I spent a fair amount of time reading up on rigging here on the forum and looking for suitable material. Oh, the wonderful world of (non)standardized thread sizes! It seems that in the modeling world thread (and miniature rope) is usually identified by diameter--a totally practical way of indicating size. But outside the modeling world (for example in the fly-tying world) there seem to be two systems commonly used. The first is the 'ought' system where the thickness of thread is indicated by the number of 'oughts' or zeroes. But the standard 'ought' seems to differ among manufactures. What is consistent is that the greater the number of 'oughts', the thinner the thread. I chose to get a spool of 8/0 (eight oughts) fly tying thread to use as seizing material. It is almost microscopically thin. The second 'real-world' system of thread 'standards' is the 'denier' system. IIRC, the 'denier' score of a thread is the weight of 9000 yards of the thread. I noticed that the spool of thread that I had on hand (which was somewhat too thick to use for the pivot gun rigging) was 210D... (the label was damaged). So I figured if I could acquire a spool of say, 120 denier thread then it should be approximately half as thick. This turned out to be true when I received a spool of 120D embroidery thread. And I just noticed that the 8/0 thread is also marked 72D on the spool. Some manufacturers indicate both systems, some only one. So I now have three different threads to compare. The first is the Syren miniature rope. Very nice stuff. I have four spools of polyester thread, two in tan (210D and 120D), one black (210D) and the fly tying thread (72D). I'll probably use these for most of this project. And finally I have the Seahorse rigging thread in 0.3 and 1.0 millimeter. This appears to be cotton thread and while perfectly fine, it does exhibit a bit of fuzziness which is reduced to almost nil with a little waxing. (I keep a tube of Bert's Bees lip balm on the desk for just that purpose!) I'll probably use it for the heavier lines of the standing rigging as well as the anchor cable. So that's how things stand for now.
  2. Wow, the Mendota photo is great at high resolution. Details that strike me is that the gun carriage appears unpainted, natural wood and how bright the metal work is. I also notice that the inside of the vent appears unpainted. (Only model builders and war gamers notice these types of things!)
  3. Congratulations, MM! She looks great! I love the color of the sails. Did you dip them in tea to get that color? Regardless of the scale she's a graceful vessel. At 31 tonnes it does look a bit cramped. It's a shame the construction records are so scarce and and the number of each class built is speculative. It seems like (according to Chapelle) the two larger classes were favored and only the name 'Alert' is tenuously associated with the 31 tonne class. Still, it looks like the small cutters were useful up to the 1830s when larger builds seem to become the norm for the Revenue Service. I agree, too, that this card model is more complex than one would think.
  4. Speaking of paper and sails... Has anyone experimented using coffee filter paper for sails? Somewhere on the interwebs I read that silk span was originally used to filter coffee before it was adopted by model airplane enthusiasts (in the 40s?). I'm not sure that's true but being a 'build with what you have on hand guy' I like the idea. I snagged a filter from the Admiral and found that it was surprisingly strong paper. But I went no further as we only had unbleached filters and I did not then have a need to make a sail. BTW, Phil, thanks again for your wonderfully detailed posts and research. I'm about to embark on my first rigging job on the Seahorse Revenue Cutter so I've been intently studying your build log.
  5. I use several in three different sizes. The smallest is 5x7in and is convenient when I don't want to clean off the big mat to cut small pieces. I also use a hard plastic cutting board from the kitchen that the Admiral replace and was going to throw away.
  6. Thanks everyone for the likes and comments. They really help keep the motivation going. I needed that today. I had one goal this weekend: rig the pivot gun. Ugh! The week started out well. I ordered an extra set of blocks and various standing rigging line from Seahorse and some hooks and 0.3mm rope from Syren for the running rigging. The masts and spars were mostly shaped over the weekday evenings so they're about ready. Syren's stuff arrived within two days and I really like it. Comparing the good rope to what I had on hand was instructive. Looks like what I have is slightly smaller than the 0.3mm stuff. Syren on the right. My generic stuff on the left. Since I knew the tiny size of the holes in the blocks was going to be an issue (and since I'm loath to use the good stuff on my very first kit build) I decided to use the generic stuff for the pivot gun rigging--at least as a learning exercise. The real challenge is the size of the blocks. These 2mm things are tiny, tiny, tiny. Tying the line to the Syren hooks was not a problem. But stropping the block? Let's just say it's taken me two days to reeve two lines through a total of four blocks. While the plan calls for four lines for the pivot gun I think I'll follow @Dr PR's lead and stop at two. I may need to experiment with the paper blocks to see if they might be easier to work with. But the worst part of the day was when I picked up the hull in order to drill holes in the deck for the eyebolts I've been making. I noticed that the cabin has been crushed! How that happened I have no idea. It had to be me when I was dry-fitting the masts. We have no pets, no kids, no visitors and the Admiral rarely visits my lair. Time to walk it off. Maybe a way to fix the new issue will come to me in the sunshine. Where did I leave the schnapps?
  7. Well, the vendor (Plastic Model Company, not Paper Model Company as I typed in the OP) came through. The HMS Captain kit arrived March 2nd. So not bad timing. The Captain has got to be one of the ugliest ships in history. That's part of the charm of these late Victorian, transitional ships. They always remind me of over exuberant Gothic Revival architectural styles. Still, I think the kit's a bit beyond my skill level for now. Certainly a nice addition to the stash, though.
  8. Thanks @Ian_Grant. You should try it. It's almost mess free modelling! Thanks for the links @modeller_masa. I see quite a bit of variety in rigging. But, yes, it does appear that the jib boom was offset.
  9. I didn't have a dowel handy so I used a bottle of schnapps. Came out to 111 inches so the thread must be 11.1 inches. Who knew it was so easy to find the length! 😉
  10. Jerry, First off, Hi! Took me awhile to make the association but you and I used to fly together in RB3D when I went by the nom de guerre Kugelfang. There's a trip down nostalgia road! If you don't already have it Warren Ripley's 'Artillery and Ammunition of The Civil War' needs to be in your library. I see a couple copies on ABE books. On page 218 there is a photograph of Mendota's 9" on a pivot carriage. Just below that is a line drawing of what appears to be the same carriage. There's an appendix of statistics covering a lot of carriages but I don't see Navy carriages specifically identified there. Sadly, my scanner is kaput, but I could take a photo of the Mendota photo if it would be helpful. --jeff
  11. Does anyone know the status of Orel in Ukraine? I think I saw somewhere that they were not fulfilling orders due to the current situation. However, on February 13th I impulsively ordered HMS Captain off Amazon. I thought I was buying it directly from Orel but upon digging a little deeper it looks like Paper Model Company (also in Ukraine) was the vendor. There's a long delivery window (March 5 - March 27) which is fine since I'm in no hurry. But I keep going back to the Orel site and finding more and shiny things I need. Just curious.
  12. I could use some assistance from the rigging gurus. There's no key for the drawings with this kit so help in deciphering the rigging diagram would be appreciated. Also, I haven't quite mastered the terminology so please bear with me if I use incorrect names. Are my notes correct regarding these belaying points in the drawing above? I'm fairly certain 'a' represent eyebolts in the deck. I think 'b' represents cleats in the deck and on the bulwarks (for line '26'). 'C' has me puzzled. Is that a block attached to an eyebolt in the deck? Next: Are blocks a - e attached to eyebolts in the masts? Though 'd' may be seized to the mast above the top? Are 'f' and 'g' seized to the masts just below the caps? And finally, with parts 78a and 78b it looks to me that the jib boom is positioned off-center of the bowsprit. If you were looking straight at the bow and the bowsprit was a clock face, then the jib boom would be around 10pm? Thanks in advance.
  13. I thought I discovered a solution to eye-bolts. Fishhooks! Actually, I saw the idea in an old post by @DrPR and jumped on board. Not knowing anything about fishhooks I bought a variety pack of various sizes thinking clipping eyelets off the smallest would probably work for 1/72 scale eye-bolts. Hmmm... no. Too big. So I surprised myself and was able to make a few passable rings by wrapping 23 gauge wire around the tip of a new set of fine point tweezers. After attaching them to the pivot gun sled and the deck the next step was to start rigging the gun. Using what I had on hand didn't work so well. I don't know anything about the thread I have. I purchased a spool of black and a spool of tan (really more of a gold) for rigging 1/600 scale wargaming ships (My COVID lockdown project of 2020). While I was able to attach the breech rope I was not able to seize it decently. Two reasons for this: 1) I used CA to tack it to the eye-bolt which made folding it back almost impossible; 2) I don't have any 'small stuff' to seize with. I ended up with something of a stiff overhand knot which, to be frank, looks horrible. For now I think I'll leave it, though. Since the next step is to rig the gun tackle I wanted to see if my thread would even work. Since the Cutter model mostly uses 2 and 3mm blocks my spool of nondescript thread was clearly too thick. It took me almost an hour to tease the thread through the sheave of a single block. It was a snug fit. Even using CA or PVA to stiffen the string made the thread too thick to fit. It might work for stropping the blocks, though I haven't tried it yet. I wish I had some way to measure the diameter of what I have but I don't have anything that sensitive. Frankly, I can't even see the measurement on my little brass caliper when I try to measure the thread. The model plans call for thread in 0.2, 0.3, 0.4, 0.5 and 0.6 mm diameters for various parts of the standing rigging. I think 0.3 mm is used for the running rigging. I feel like I need to start accumulating rigging supplies (since I've been stashing 1/72 and 1/100 scale models), but I'm not sure I need that much variety. It think I might buy some 0.3 and 0.6 (and some small stuff) from 'Ropes of Scale' and use what I have for the other sizes. Meanwhile, I'm almost finished shaping the masts and spars. My next exercise is going to be stropping. Wish me luck! Better yet, any suggestions for a far sighted, one-eyed model shipbuilder struggling with his first rigging job? Tools? Techniques? I wish I'd used some foresight and ordered an extra set of blocks (or two) for this kit. Goodness knows, I expect to lose half of 'em to the floor gods! Perhaps another order to Seahorse is in the not too distant future. @0Seahorse, thanks for checking in with my build log, Tomeck! And thanks for the tip about fairing the framework. I considered it but wasn't sure if it was standard practice for card models. I got conflicting information off the web. Sometimes my motto is 'When it doubt, take the lazy way out!' But it makes sense and fits what I was experiencing with the build. I'll know for the next one. One thing I am learning from this build is that card models can be very precise and if your work isn't as precise as the design... well, you're in for a challenge!
  14. Phil, I just wanted to pop into your log and say how much I've learned from it. As a new modeler working on a similar model (though in card, not wood) you've answered many of my basic rigging questions. Thanks again, --jeff
  15. Dude! You're killing me! I can only keep up with so many build logs! 😉
  16. Thanks, all. Sounds like I'm going to have to experiment.
  17. I've got most of the deck fittings done now. While it looks sort of sloppy in the close-up pictures I'm please with the build--even if I won't get high marks for symmetry. In fact, I've been able to construct some of the small bits that I thought would be beyond my abilities. I'm particularly fond of the galley stack. Rolled and butt joined. I could not for the life of me construct the posts for the pin rails, though. So the rail is the laser cut part but the posts are carved down from a match stick. The belaying pins are short lengths of 28 gauge wire about 3/16 of an inch long. Oddly enough, I had no problems with the other posts. I'm now studying the drawings on how to rig the pivot gun and trying to find a way to make bolt rings. This will be my first time working with blocks and 'serious' rigging. A little bit of trepidation setting in! I've found a couple of the build logs for this model on other sites. From what I can tell using Google Translate, I'm not the only one who found minor problems with the stern pieces and skinning. Nothing major, just something to be aware of when building.
  18. Yeah, I chose not to scan because I'd have to disconnect my new laser printer and reconnect my old inkjet scanner printer (which no longer prints). Plus, there was an extra set of printed parts included in the kit due to Seahorse being displeased with the original print job. But when it came down to it I didn't want to cut up the spare sheets!
  19. Huh! I'm impressed that the stiffened thread spokes actually support the plane. Looks good.
  20. I'm not terribly concerned about longevity of my card models. A five to ten year lifespan is really all I desire (for the models!). I'm sure by that time I'll want the space for some other project and--at least for now--my skill level is not so advanced that anyone else would want them. To be honest, the build is more enjoyable to me than the end product. Would shellac work the same way as varnish to stiffen card? I tend to avoid CA, too, and anything with strong fumes is going to be an issue in my home (The Admiral has respiratory issues). I've been looking for some way to seal the card models that is not aerosol or water based. I was looking at 'Clear, dewaxed' shellac flakes and wondering if it would be worth experimenting. I think the alcohol base should evaporate quickly enough to avoid problems and I don't think it would affect the paper. Since I just purchased a cheap laser printer I don't think ink bleed due to the alcohol will be an issue, either. But I'm not sure there would be any real advantage.
  21. Welcome, Shipific! Are you familiar with Warlord Games' Black Seas 1/700 scale ships of the Napoleonic wars? They're gaming pieces rather than models but I've seen much worse.
  22. No judgement here! We all enjoy our hobbies in our own way. I'm enjoying watching your build so I know what's coming up in mine!
  23. One of my favorite early aircrafts. It's looking charming! The engine bears a remarkable resemblance to a Wright 4-40 4-cylinder engine c. 1911, without the flywheel, of course. (see https://wright-brothers.org/Information_Desk/Just_the_Facts/Engines_&_Props/440_Engine.htm). If so, there was not a lot of wiring involved.
  24. Wow, you are really zipping through this build! It's looking great. Having not seen one of your builds before I thought the beginning was looking a little rough-and-ready. But she's turning into a beauty!
  25. Progress has been a bit slower lately but I'm happy with the way the cutter is turning out. Forging ahead, the next task was adding the copper plating to the bottom. The kit provided some copper paper printed with strakes on one side or individual plates on the other giving the builder the option of fast or detailed. I chose fast and used the strakes. No complaint. I did notice that the copper strakes, like the hull strakes, seemed a bit short for the the hull. While I normally attribute these types of shortcomings (!) to my lack of experience I'm beginning to think there might be a small glitch in the design. It's almost as if the laser cut parts are just a bit longer than they should be. I've come across issues with the strakes, the coppering, the bulwarks and even the deck. Nothing that can't be overcome--I've adopted the practice of leaving extra material on the ends of long pieces to allow some extra and then cut them to length once I've determined how much extra is needed. I also discovered that I have the perfect shade of copper paint in my hobby supplies! After coppering both sides I added the white wale which hid a number of blemished I introduced with the planking. Then I had to do some fixing of the stern. I ended up installing the transom and a pair of knees that support it and then decided I wasn't happy with the slight gap where the deck planking ended before the transom. Unfortunately, I ended up destroying the transom and knees when I removed them so I had to scratch build replacements. I was not successful in recreating the knees out of card so I ended up carving them out of plastic. They might be a bit too large but I'm OK with it. I also made a new counter piece since the original seemed too small and I was unhappy with the way it fit. I also learned that cheap thin CA glue has potent fumes! I normally use Gorilla brand gel superglue and have never had a reaction to it. I wanted to try thin CA to stiffen up the counter piece and boy did I get a reaction! My eyes watered for a full hour. I think I'll pitch the cheap stuff and see if Gorilla makes a thin CA and if I react to that. The inside of the gunwales were the next pieces where the chronic shortness bit me. I worked from the back forward and probably should have started at the front. Consequently, I'll have to do some fixing when I install the bow sprit. The rudder was next on the agenda. While the model has small, rolled pintles I knew I was never going to be able to make something so small. So I fudged it. Again, the rudder straps may be a bit oversized but... it works for me. The most recent work was installing the cap rails and the tiller. That's where she stands at this point. I'll start the deck fittings during the next week.
