Ian_Grant
Everything posted by Ian_Grant
  1. Bob, that Tamiya ESC does not go up to 12V input like you have. You can't use it with your 12V batteries and motors. Since your Rcvr LED is going out, it is not getting power, as you say. The LED flashes mean that it is briefly powered but sees no signal from the Transmitter, which you mentioned was "off". I think the ESC(s) are shutting down for some internal reason. Are your batteries fully charged? Hard to believe you have two faulty ESCs; maybe it is the wrong model for your application and some alarm (voltage, current, temperature etc) comes on and triggers a shutdown. Could connecting to two motors be affecting it? Don't know; it shouldn't. Have you tried measuring the ESC "6V" output just with batteries and ESC connected? By the way, that "320A" spec is BS from China. If only we had the specs and manual for it........ Try connecting the battery direct to motors for a minute just to verify that they're ok. "Viper" brushed marine ESCs have a good reputation around our RC boat club. They are reversible and have failsafes built in so you won't kill them with one mistaken connection. Don't know what you paid for yours but I expect Vipers cost more. See below link to one supplier. Since your motors are brushed and identical you can power both from one ESC. Since they draw a combined 9A max I would suggest the 25A model, or even the 40A ($10 more) if you want more margin on power and temperature heating. https://www.harbormodels.com/speedcontrol.html
  2. Bob, A little confused about your sequence of events. Have a look at the video below which shows what should happen and how the Rcvr can be powered from any of its connectors and how an ESC can power it. Also the second video about programming the GT3B. 1) Are your batteries charged? Is the polarity into the ESC correct? 2) Is your ESC connector into the Rcvr the right way around? 3) Are the Tx and Rcvr actually bound? 4) Again, try powering the Rcvr from a separate battery WITHOUT the ESC being plugged in. If it was plugged in you'd have two separate sources fighting each other to power the Rcvr Sometimes people want a separate Rcvr battery for safety, in which case they have to remove the power lead from the ESC to Rcvr cable and just use SIGNAL and GND. https://www.youtube.com/watch?v=9KPu9mZ4bas
  3. Black GND wire nearest the outside of the case is the usual standard, yes. There was no connection diagram with the ESC? Ridiculous. 👎 Bob (not Bruce; sorry about that!), can you tell us the link where you ordered it from?
  4. ???? 🤔 Perhaps you could download the pdf manual for the ESC from the seller? Or else wait for it to arrive, presumably with at least some instructions.
  5. Bruce, that's the servo reversing function. It allows you to, on a per-channel basis, reverse the direction a servo will rotate with a given signal from the transmitter. For example, if you found that your rudder turned left when you turned the transmitter wheel right, instead of changing the physical linkage from servo to rudder you can just servo-reverse that channel. I had a look at the manual for your FS-GT3B and here are a few things to note: Pg 7 - in Chinglish they seem to tell you to have the receiver antenna oriented vertically, not lying along the boat's keel. Pg 21 - ABS brake function: you don't want it for a boat so turn it to OFF. Pg 23 -shows how fwd/reverse is controlled by the trigger which can be pulled OR pushed. Now I understand; I assumed the trigger could only be pulled like on a firearm or a slot-car racing set. If the motors go backward when you want forward, you can servo-reverse the throttle channel instead of swapping physical wires. It's a pretty terse manual but that's common in RC where prior knowledge is assumed. You need to read the ESC manual to find out to properly set it up for fwd/off/rev control at power-up. By the way, what's the model number of the new ESC? I'd like to look through its manual too, to be able to help you.
  6. OK. To augment my knowledge, how does one put the boat into reverse with these land sets? 🤔
  7. If it was me, I would step one power the receiver from some other 6V battery if I could (you can buy servo cable extensions and cut one connector off to connect the red and black wires to battery) and test that the Tx and Rx bind according to whatever LED flashes the receiver should display. Then plug in your rudder servo and see that it works. Power on and off several times to ensure the binding holds and see that the rudder servo behaves as you turn it. You really shouldn't have to do the above; this brand new stuff should all work. Now you know that the RC set and servo work properly. Then remove the external battery and plug in the ESC to the receiver with your 12V battery packs connected. Turn the ESC on and manipulate your throttle according to whatever ESC start-up sequence the manual specifies (which calibrates it for min/max throttle). I'm not familiar with that "land" type transmitter you have; for an aircraft transmitter used with a boat one usually powers up with the throttle stick in the centre (for "off") perhaps waits for the ESC to beep, then moves the stick to "full ahead" (wait for the beep if applicable) then moves the stick to "full reverse" and you're done. For your land transmitter I presume the trigger is just "min to max" and direction is specified by a separate switch? Or is this "brake/reverse" function I've seen mentioned something the trigger can do? I don't know. You need to consult the manuals. The ESC should now supply 6V to the receiver. The cable connecting the ESC and receiver carries the throttle signal to the receiver and also supplies the 6V to it. Test that the rudder servo still works. If not, unplug it and put two small wires into the receiver's rudder connector and measure the voltage across the 6V/GND pins. If it does then connect the motors to the ESC and test. Again if there are problems phone BIg Rich and he'll talk you through it. I wish I could drive over and help. Good luck!
  8. I think she looks great with furniture and crew of models aboard!
  9. Glen, she's a thing of beauty........the ship, and Dimples. 🙂 By the way, that video about eating Pringles the "engineering" way was hilarious.
  10. I have to comment as clicking "wow" just doesn't do your work justice. Incredible skill on this intricate network of piping. She'll be a sight to see afloat!
  11. Yes, that is certainly odd ....... must have relied mainly on the men pushing at maindeck level below?
  12. Great job Glen! I'd have been sorely tempted to 3D print those wheels and covers; maybe the whole ship. 😉 Cheating perhaps......
  13. Thank you Steven. No, she won't be under sail but I do want to have the mast and artemon up, with the sails furled ie what we'd call buntlines all hauled, as if they are rowing and hoping for a fair wind soon. I think their sails went up like Roman blinds, nestled within the loops of the buntlines; at least, that's what I intend to do.
  14. Steven, looks great! Fine work with the thread. This has reminded me that many yards were depicted as two-piece in ancient ships. For my galley I just tapered a dowel down to form the yard. Should I make it two-piece too? It would be an interesting detail. I'm surprised at how little overlap there is between the two sections, though.
  15. I can just make out the "P" at the edge of the port signboard. It is indeed smaller than the front lettering.
  16. Just another thought - you said there's no hobby shop near you; what if you call the guy at Big Rich Models who curated your electronics? He'd probably be happy to talk you through debugging the boat.
  17. Off topic but to continue about Italy; we spent some time in Venice and Florence on our 8 week (!) Europe-wandering honeymoon before departing for Corfu. Venice was good (we still remember the tour at the Doge's Palace, walking up to our ankles in water in St Mark's square, and the ornate bed in our room) but I liked Florence better, apart from all the scooters zooming around. My wife chuckled at the reverent look on my face when I saw Galileo's tomb. 🙂 We didn't get to spend any time in Rome but next time we will go there and again to Florence, and obviously around Amalfi & Naples to hike Vesuvius and see Pompeii. Plus some time relaxing in Northern Italy.
  18. Bob, your model 3150 motors are definitely brushed; if they were brushless they would have three leads. Your post #7 shows your ESC is the "brushed" type, ie for brushed motors. Interesting that everything works with the deck off. All components are therefore good. Sounds like possibly RF interference. I see from your pictures that the leads from ESC to motors are pretty long and loopy. Brushed motors generate a lot of electrical noise as the brushes pass from one coil to another via the commutator; this electrical noise can then be radiated by the long motor leads. I recommend you try soldering small capacitors, say ceramic 0.1uF leaded, right at the motor terminals. This is a classic configuration to reduce noise from brushed motors; one capacitor from each motor power pin to GND (the motor metal case) and a third capacitor between the two motor pins. See this pololu description: https://www.pololu.com/docs/0J15/9 As they say, it will also help to twist each pair of motor leads together in a spiral from ESC to motor, so the two wires "cancel" each other's radiated emissions. Finally, and I realize this would affect your trim and ballast, try moving the rear battery up forward beside the other one so its noisy lead isn't near the Receiver and ESC. You could then twist the leads from batteries to ESC for the same reasons. You're very close........eyes on the prize!! 👍
  19. If the motors are acting like that, it sounds like the ESC turns them on, has an internal protection alarm of some sort (short? overcurrent? temperature? other?), shuts motors off, and waits the "reset period" before trying again. Check the motors are actually 12V not 6V, maybe. Later Edit: I found a photo on pg1 of your log. The motors are clearly labelled 12V 4.5A; the ESC is quoted as 30A continuous. Are you starting up with throttle at high? Try turning on with throttle at neutral then slowly increase speed and see if motors are ok up to a certain point where problem occurs again. I'm not familiar with those "land" Transmit units with the wheel and trigger which I always associated with cars; I always use aircraft Transmitters. There must be a separate switch for fwd/reverse then trigger goes from zero to full speed in selected direction?
  20. George, to put this in perspective, what size are those cannon carriages? Or, what is the major grid on your mat?
  21. Steven, thank you! Those Pompeii frescoes are in Pitassi's book but somehow the b/w reproduction is nowhere near as clear as that. I see they really did use red and blue! 😊 That "Naval Encyclopedia" similarly shows some very tall awnings reaching the fantail but I don't think I want one like that; too much windage and I want to leave open the possibility of a flickering LED lantern dangling from it. I did drill a hole and glue in a copper eye before attaching it to the stern. We're thinking of booking a trip to Italy which definitely will include time at Pompeii/Herculaneum.
  22. Sad to see these donated kits crumbling.....
