Ian_Grant
Everything posted by Ian_Grant
  1. No, it is not normal at all. It's going to be something silly. Can you take a photo of your wired connections out of the boat?
  2. Bob, Looking way back in your post #7, your original ESC model can be powered by 6-12 cell NiMH so the ESC input voltage (of those original ESCs, not the Viper, should not be a problem. I will let you know what I find out about the Viper. I've asked the guys in my RC club, and Harbour Models. Also, look at pg 19 of your GT3B manual "D/R Function". By any chance could you have set the channel 1 and 2 outputs to 0% ie no servo travel, while playing around with programming? The factory default is 100% which might explain why everything originally worked. ?? Similarly, pg 17 programs "end point adjustment" which if accidentally changed to 0% could also set servo travel to none.
  3. Bruce, A brushed ESC should be able to run two identical brushed motors in parallel as long as their combined current draw is within ESC limits. I still think the Viper ESC is a better part than those others. Did you follow the Viper ESC's calibration procedure? (given in the manual) Place voltmeter probes across the PWR/GND pins (centre pin and outer pin) of the Rcvr's BATT connector when the LED is on; do you read 6V supplied from the ESC? Your question about the 12V ESC range is interesting given that the NiMH packs will charge up to about 14.5V (hmmm). The ESC may be designed more for lead-acid batteries which are in fact 12V when charged. Try running with just one battery (6V) and see if it works. Meanwhile |I will do some more digging on this. Have you tried leaving the motors unconnected to see if the rudder works then? It bothers me that the ESC fan does not turn, unless it only runs when the ESC is getting warm, maybe? Again I urge you to try using a separate 6V battery to supply the Rcvr at the BATT terminal to see if the rudder then works. If so then pick one of your ESCs, cut the power wire on its Rcvr link, connect the motors, or just one motor at first if you like, and see if everything works now that RCVR supply is NOT the ESC.
  4. Paddlewheels like that strike me as an ideal candidate for 3D printing. Then again I have 3D printing on the brain now. 🤪
  5. Bob I wish I could help bit I have no idea why your rudder servo at least isn't working.
  6. Thanks Keith. Hadn't heard of polycrylic before. Will read up on it and see if it's suitable outdoors by chance.
  7. Routered a slot in each rudder blank for the square brass rudder post. This is a square tube into which a round rod is soldered; this rod passes through a brass tube at the steering platforms. Here is one left and one right rudder, with two little cover plates to be glued on. I roughed up the acrylic to give the glue some hook. Painted-on "scale" rudders and the linkages; they will be mounted with the cover plates on the inboard faces. I used "JB Weld" epoxy for the first time. Wow it really grabs stuff but it's a rather ugly dark grey when dry, not a worry here due to painting. I polished the acrylic cut edges down to 600 grit wet. We just pretend that the clear areas are not there. 🙂 Rudders mounted. By the way I clear-coated the hull paint in exterior UV satin finish. I could not find exterior in matt. I am thinking of applying an interior matt over that, above the waterline, and hoping that it will stick. A short video of the rudder action. P6270947.MOV Size comparison of the NiMH pack with the lantern battery. No contest. Then re-assemble the mechanisms. The sliding bases: The oar beams: After adding the oars I need to do a ballast test in the pool before taking her to the cottage tomorrow. It's supposed to rain all day Saturday so I will have more time to tweak it. Didn't have time to do much rigging, sadly. I will take the laptop too in case any software changes are needed. Video from on lake to follow............🤙👍
  8. Glen, Banshee is truly beautiful......going to be a magnificent display when bottled.
  9. "mil"? Do you mean mAh? If so a 3300 can deliver 3.3A for one hour, or 1.0A for 3.3 hours; the 5000 can deliver 1.0A for five hours; in theory. In reality you can't drain all that stored energy out because you must not let a cell drop below about 1.0V to be safe. You can expect to get about 65% of the total stored energy. Battery size doesn't matter to the motors or the ESC, apart from the fact that the 3300 runs out more quickly, but it might to the charger. If you have a fast-charge type the 5000 mAh can tolerate a higher charge current. If it's a slow type it doesn't matter; the 5000 just takes longer to charge.
  10. Looks like it. Harbour Models allows download of the ESC instructions, including the simple calibrate sequence to set up forward/reverse. They also mention blowing air over the cooling fins - it doesn't have a built-in fan like those others. First time run the motors for a few minutes and see if it's getting hot. The FET transistors they use have very low on-resistance so in theory they dissipate little power. If it is getting hot you might add a small external 12V fan also powered by the battery.
  11. Here's what I've been working on........ Drew two patterns of shield motifs in CAD and 3D printed ten of each. Painted them up and attached to bulwarks. Drew some cleats and cut them out from 1/8" plywood using the laser cutter. Here are the cleat boards which will be inside the bulwarks to anchor the mast shrouds. Haven't yet painted the cleats. Lashing and halyard cleat at the mast foot. Recall that the part of the tabernacle lashed to the mast comes off with it. Cleats at base of artemon for yard inhaul/outhaul. While I had a laser cutter booking, I cut out two rudder blanks from 1/4" clear cast acrylic sheet. The etched stripes are where I need to cut a notch for the brass rudder posts. Idea is to paint a scale rudder blade and leave the oversized portions clear. Started work on the commander's shelter. It will be the handle for the rear hatch, bolted to it. Hoping that stretching fabric over it will show the "tentpole" arches. One more pole to add, in its slots. It crossed my mind to 3D print the end arches and slotted sides, but then I gave my head a shake; "How lazy am I getting?". 🙄 It would have taken a good while to print, too. Long weekend at the cottage a week tomorrow. I plan to debut it to all the inlaws and some friends, most of whom don't know I've been building it. It just never came up, HaHa......I'm the only one interested in building models or in RC.......Hope to have some rigging done, definitely the rudders, and of course use the new battery pack.
  12. Bob, that Tamiya ESC does not go up to 12V input like you have. You can't use it with your 12V batteries and motors. Since your Rcvr LED is going out, it is not getting power, as you say. The LED flashes mean that it is briefly powered but sees no signal from the Transmitter, which you mentioned was "off". I think the ESC(s) are shutting down for some internal reason. Are your batteries fully charged? Hard to believe you have two faulty ESCs; maybe it is the wrong model for your application and some alarm (voltage, current, temperature etc) comes on and triggers a shutdown. Could connecting to two motors be affecting it? Don't know; it shouldn't. Have you tried measuring the ESC "6V" output just with batteries and ESC connected? By the way, that "320A" spec is BS from China. If only we had the specs and manual for it........ Try connecting the battery direct to motors for a minute just to verify that they're ok. "Viper" brushed marine ESCs have a good reputation around our RC boat club. They are reversible and have failsafes built in so you won't kill them with one mistaken connection. Don't know what you paid for yours but I expect Vipers cost more. See below link to one supplier. Since your motors are brushed and identical you can power both from one ESC. Since they draw a combined 9A max I would suggest the 25A model, or even the 40A ($10 more) if you want more margin on power and temperature heating. https://www.harbormodels.com/speedcontrol.html
  13. Bob, A little confused about your sequence of events. Have a look at the video below which shows what should happen and how the Rcvr can be powered from any of its connectors and how an ESC can power it. Also the second video about programming the GT3B. 1) Are your batteries charged? Is the polarity into the ESC correct? 2) Is your ESC connector into the Rcvr the right way around? 3) Are the Tx and Rcvr actually bound? 4) Again, try powering the Rcvr from a separate battery WITHOUT the ESC being plugged in. If it was plugged in you'd have two separate sources fighting each other to power the Rcvr Sometimes people want a separate Rcvr battery for safety, in which case they have to remove the power lead from the ESC to Rcvr cable and just use SIGNAL and GND. https://www.youtube.com/watch?v=9KPu9mZ4bas
  14. Black GND wire nearest the outside of the case is the usual standard, yes. There was no connection diagram with the ESC? Ridiculous. 👎 Bob (not Bruce; sorry about that!), can you tell us the link where you ordered it from?
  15. ???? 🤔 Perhaps you could download the pdf manual for the ESC from the seller? Or else wait for it to arrive, presumably with at least some instructions.
  16. Bruce, that's the servo reversing function. It allows you to, on a per-channel basis, reverse the direction a servo will rotate with a given signal from the transmitter. For example, if you found that your rudder turned left when you turned the transmitter wheel right, instead of changing the physical linkage from servo to rudder you can just servo-reverse that channel. I had a look at the manual for your FS-GT3B and here are a few things to note: Pg 7 - in Chinglish they seem to tell you to have the receiver antenna oriented vertically, not lying along the boat's keel. Pg 21 - ABS brake function: you don't want it for a boat so turn it to OFF. Pg 23 -shows how fwd/reverse is controlled by the trigger which can be pulled OR pushed. Now I understand; I assumed the trigger could only be pulled like on a firearm or a slot-car racing set. If the motors go backward when you want forward, you can servo-reverse the throttle channel instead of swapping physical wires. It's a pretty terse manual but that's common in RC where prior knowledge is assumed. You need to read the ESC manual to find out to properly set it up for fwd/off/rev control at power-up. By the way, what's the model number of the new ESC? I'd like to look through its manual too, to be able to help you.
  17. OK. To augment my knowledge, how does one put the boat into reverse with these land sets? 🤔
  18. If it was me, I would step one power the receiver from some other 6V battery if I could (you can buy servo cable extensions and cut one connector off to connect the red and black wires to battery) and test that the Tx and Rx bind according to whatever LED flashes the receiver should display. Then plug in your rudder servo and see that it works. Power on and off several times to ensure the binding holds and see that the rudder servo behaves as you turn it. You really shouldn't have to do the above; this brand new stuff should all work. Now you know that the RC set and servo work properly. Then remove the external battery and plug in the ESC to the receiver with your 12V battery packs connected. Turn the ESC on and manipulate your throttle according to whatever ESC start-up sequence the manual specifies (which calibrates it for min/max throttle). I'm not familiar with that "land" type transmitter you have; for an aircraft transmitter used with a boat one usually powers up with the throttle stick in the centre (for "off") perhaps waits for the ESC to beep, then moves the stick to "full ahead" (wait for the beep if applicable) then moves the stick to "full reverse" and you're done. For your land transmitter I presume the trigger is just "min to max" and direction is specified by a separate switch? Or is this "brake/reverse" function I've seen mentioned something the trigger can do? I don't know. You need to consult the manuals. The ESC should now supply 6V to the receiver. The cable connecting the ESC and receiver carries the throttle signal to the receiver and also supplies the 6V to it. Test that the rudder servo still works. If not, unplug it and put two small wires into the receiver's rudder connector and measure the voltage across the 6V/GND pins. If it does then connect the motors to the ESC and test. Again if there are problems phone BIg Rich and he'll talk you through it. I wish I could drive over and help. Good luck!
  19. I think she looks great with furniture and crew of models aboard!
  20. Glen, she's a thing of beauty........the ship, and Dimples. 🙂 By the way, that video about eating Pringles the "engineering" way was hilarious.
  21. I have to comment as clicking "wow" just doesn't do your work justice. Incredible skill on this intricate network of piping. She'll be a sight to see afloat!
