Gender
Toronto, Canada
Interests
Wood Ship Modelling
Do not secure mast in the corresponding hole in the hull till you are totally satisfied with complete mast with all sections assembled. You can pull the mast in and out the hole whenever you please and fill necessary. When you are satisfied - secure the mast in the hole.
Somehow I do not understand a) what the fellow modified the standard clips for b) how this can be applied for holding first planking strips
James H reacted to a post in a topic:
HMS Victory: Caldercraft or Artesania Latina
Y.T. started following Simple, low cost, small thimbles , HMS Victory: Caldercraft or Artesania Latina , jig for making uniform footrope stirrups and 5 others
Y.T. replied to darkening's topic in Wood ship model kits
I would select a smaller size one AL at 1:84. Caldercraft is 1:78 It is 5.5 feet long. -
Y.T. reacted to a post in a topic:
Young America 1853 by EdT - FINISHED - extreme clipper
8" Mini Shear/Brake
Making Slings
Gregory reacted to a post in a topic:
Recommended First Machine
If you ask me, I have no reason to question the product. I purchased Silkspan here: https://sigmfg.com/products/sig-silkspan-tissue As I said earlier. I will no longer consider any paper product for sails unless may be for furled sails. It is easy to tear and cannot be repaired if damaged. The full story of my Silkspan use attempt is here: https://shipsofscale.com/sosforums/threads/hms-victory-by-y-t-mamoli-1-90-scale.2397/post-467322
Sail feedback request, Mondfeld method
Finding a silkspan is not a problem. I got as much of it as I wanted here: https://sigmfg.com/products/sig-silkspan-tissue I just want to warn you that from my own experience I tried making the sail from it and abandoned the idea later. Silkspan is way too brittle and impossible to repair. I spent a week working on one sail and got it torn off in a second. Since then I abandoned the idea of silkspan. I work with very light batiste. You can look at my endeavors here. First picture of broken silkspan sail. Next is from thin fabric. Scale is 1:90
Wood Plank Benders - Rounding
MintGum reacted to a post in a topic:
Y.T. replied to MintGum's topic in Modeling tools and Workshop Equipment
I have been through this.the 220 V device will provide you not enough power to bend any planks. currently I am using Weller’s 110 V soldering iron 80 W power and the head from AeroPiccola plank bender which fits right into it. -
Innocraftsman Mill
hollowneck reacted to a post in a topic:
Innocraftsman Mill
If this one is still available from anywhere it is the only one worth considering. I have original Aeropiccola like this. To my opinion all the rest are not good. -
Oops -- Repairing broken bowsprit on Cutty Sark
I use this disk sander for years and am very pleased with it. It is four times cheaper than Proxxon and does same job. https://www.amazon.ca/Vibration-Free-Bench-Disc-Sander/dp/B07SFZGHVQ/ref=asc_df_B07SFZGHVQ?mcid=939201fb73b2384da47191e8a4656ceb&tag=googleshopc0c-20&linkCode=df0&hvadid=706725384462&hvpos=&hvnetw=g&hvrand=16140153878231337219&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9189954&hvtargid=pla-2245741550629&psc=1&hvocijid=16140153878231337219-B07SFZGHVQ-&hvexpln=0&gad_source=1
Disk sander is more important for wood ship modelling. I have no doubts. Table saw is complimentary especially if you are not going to manufacture your own wood planks from scratch.
1:48 La Renommée 1744 - CAF Model
I am going to stick to a brass tube. This is a sample 1 mm OD. I knock it with a center punch so it is easy to be wrapped with a rope. Not wiggling out.
Tired hearing of "pirating". Proof of pirating must be presented before accusing. In general this issue is the matter for legal courts. Has little to do with consumers.
