Posts posted by RussR
2 hours ago, Mike Y said:
Same as Dave, the best way to fix KS115 problems is to buy Proxxon FET and advise everybody to do the same. It is a classical example of spending money on a cheaper tool, ending up spending more money on a proper tool. KS115 is, honestly, a junk
(I had it, upgraded to FET and never looked back).
It is hard to use the table saw if you can't event adjust the blade height, and the precision is super bad (fence alignment, miter gage, etc). You also can't make any sleds for this saw, since there is only one miter channel instead of two. Its real price should be around $30, there are "saws" in this range on AliExpress and Harbour Freight. But they are asking $130 for it 😳
This would be great it one had unlimited space and unlimited funds.
For me a KS115 is a big upgrade from a miter box and a hobby saw.
Thanks for the comment.
RussR
15 minutes ago, druxey said:
I bought this saw before the Byrnes' saw came on the market. The original fence is problematic. However, fitted with an Accurizer II fence, the problem is solved.
druxey,
This would probably solve the problem. With shipping and all, this would cost 150% of what I paid for the saw.
At this point I think I can live with 0.5mm tolarance.
Thanks for your input. It is much appreciated.
RussR
Brian,
You are "probablyright". Dressing the screw to a point would screw it up for good.
I just now checked to see if there was any debris on any of the surface you mentioned. There was none.
The variance isn't consistent. I did clean the fence and table with no effect. But I did notice pits where the screw made contact with the table. So I used a sanding block and to smooth out the pits.
Now the variance is about 0.5mm across the full length of the fence. I guess for a $50.00 saw, what can one expect.
Thanks for putting me on the right track.
RussR
I bought a used Proxxon Bench Circular Saw KS115, and it works great. But there is one problem with it. When I try to set the fence it tries to cant in at an angle to the blade.
My thinking is, if the adjustment screw was ground to a center this wouldn't happen. But the way it is made that can't happen. The only way I can think of to fix this is to buy a machine screw and and cut the head off and chuck it up in a drill motor or better yet a lath and dress the end up. Then make a knob for it.
Can anyone think of a better solution?
Photo the the type saw:
Mm
Messis,
I am enjoying your build log.
I have read that some modelers use hairspray and a fan to get the effect of wind in there sails. I don't have experience with it myself but it sounded good.
RussR
On 7/10/2018 at 12:12 AM, MESSIS said:
Shipyard has reopend since yesterday. Vacations are over 😣. Here we go again...
MESSI,
I would love to see your more of your vacation photos of the ship Hermione.
RussR
Hello Christos,
I have also ordered this model with the crew figures.
Would you send me the paint colors you wrote about here in your log?
I tried to send you a message here in MSW but your box must be full and can't except anymore.
PS: I hope my ship turns out a well as yours
RussR
It is interesting to note the number of starts to the number of finishes.
Starts Finishes
Wooden Ships 1673 308
Small Craft 235 107
Plastic/Resin 172 34
XSect/Guns/Dior 52 14
Ships in Bottles 23 12
RadioControled 20 4
Restorations 14 4
Looks like there is a lot still being built or given up on.
26 minutes ago, Mike Dowling said:
That's one idea but the bank manager won't like it.
I know what you mean, I am surprised that I get away with what I do.
"Boys need there toys".
My vote is "not covered.
That is a lot of work to be covered forever.
- davyboy, popeye the sailor, Canute and 3 others
6
31 minutes ago, Gregory said:
Gregory,
Thanks for the info. So it would cost about $20.00 plus some styren or wood and a couple of connectors and a switch. One might even run it on eight D-cells if you didn't plan on using it much.
Not long ago I ask how to cut a piece of 30mm X 4mm X 4mm into four equal parts and received many great ideas.
Just now I found a video on YouTube "How To Make Mini Cutting Machine Cut Popsicle Sticks". I haven't made one but I admire the creative thoughts of some people.
I have downloaded this and hopefully I can upload it here.
RussR
How To Make Mini Cutting Machine Cut Popsicle Sticks.webm
I appreciate all you guys input on my little problem. All of your ideas are well taken and filed away in my mental bank for future recall.
What I had done was I found a piece of 3/16" square junk wood and cut it to 7mm length and sanded two edges to 4mm. I just painted them. Since they are so small I think it will look like it was planed.
At this point in my skill level I bought an AL model of the 1805 Pilot Boat for $35.00 on eBay to practice on. My skills are far from perfect at this point. It is doubtful if I will even display it. I am learning a lot. But it gives my pea brain something to do. Like they sayl "you learn by doing".
Thanks again.
RussR
That was my though, but I have to think about cutting the last piece into two. I would have to be able to hold a very tiny piece and cut it.
At this point I am thinking I would be better off to just buying some 4mm X 4mm basswood stock at Hobby Lobby and cut it with my 2" cut off power saw. The trade off is I would need to either paint them or stain them.
My complaint with kit manufacturers is they don't put dimensions on there drawings. And they don't consider how the builder is to do what is required for a good out come.
I am looking forward to the day that I reach a point to start scratch building from plans.
Thanks again for the reply.
The model that I am working on requires that I cut a piece of 30mm X 4mm X 4mm walnut into 4 equal pieces. I considered using my exacto hobby saw. It is probably to thick for side cutters. It is probably to small for a 2" power cut off saw.
What do you old "Salts" recommend?
RussR
This may be old news for some, but I just found these two videos on YouTube that was very interesting to me.
The site won't let me post the link. You will have to do a search on youtube.
"Flagship Endeavour Ship - The Launch / HM Bark Endeavour Replica / 9 December 1993 HD"
And the other one is "HM Bark ENDEAVOUR, 1999, 18th century sail training".
RussR
- uss frolick and thibaultron
2
Okay,
I own the Dremel 3000 and the drill press adapter and it works good enough for model building etc. Also I own the router attachment but haven't used it so at this point I don't have a opinion. But for a hobby tool how good does it have to be?
For a tool to make my living I want the best quality.
Royal Louis 1780 by Ulises Victoria - FINISHED - Mamoli - Scale 1/90 - French 126-gun ship
I think model builders obese over a lot of details that most people just glance over.
The only one we have to please is ourselves, even other model builders.
If someone is able to pick out all of your flaws in your work, maybe they have been there to long.
