RussR
Posts posted by RussR
  1. 7 minutes ago, Gregory said:
    I've bought several kits on eBay and pretty much got what i expected for what I paid.
    I once bought a kit from someone who was up front about not knowing what should be in the kit.
    Once I received it, it turned out to be severely lacking in some respects.  I contacted the seller, and they took my word for the depreciated value and gave me a partial refund with no argument.
    I think most people are honest, unfortunately there are some that aren't so.
  2. Of course one has to read all the description and look at all of the pictures and ask questions plus check the sellers feedback score.
    If I can see the bulkheads and the keel plus unopened accessories I am good to go.
    Like I said, if I didn't have something else going I would have bought it for 25% retail.
    I have bought and sold model kits on Ebay and never had a problem.
  3. I just had an offer from a Ebay seller for a new Corel SM21 Misticque 1750 1:50 for $150.
    https://www.ebay.com/itm/294164707845?ul_noapp=true
    If I didn't have so much on my plate I would buy it.
    I am reasonably sure that the sell would take that from any buyer.
    The current price on Modelexpo is $600.
    I have no connection to this sale at all.
    Russ
  4. When I did my Hermione, I ended up cutting the cap off with a razor saw and adjusted the stem to fit. Now that I look at the completed model I can't tell I did anything.
    Most of the flaws that I use to fret over, I can't even remember. Most viewers myself included won't be able to pick your flaws out. Because the rest of the model will over shadows the nit picky flaws. Of course we all want to build the best we can.
    As far as time consuming.
    I do this for the fun of it and not for a source of aggravation. And this gives my pea brain something to do.
    You are doing a great job and I look forward to more.
    RussR
  5. I thought that the mast need a block instead of an eye bolt. And I didn't like where the two lines terminated. So, I added the block and made a cleat for the mast to tie the lines off.
    Some random shots of the finished model
    And finally an overall shot of the finished model.
    I think I'll take a brake before I start my next project. It will be either the 1/350 plastic Titanic or the BB 1/75 Vasa.
  6. continued from the previous post.
    This a forward shot of the canon installed.
    Top of the fabricated mast. I had to drill and cut the slot for the pulleys. The red piece at the top was turned on a used Proxxon Lathe that I recently bought.
    This is the completed Yard Arm (the center part anyway).
    Rope coil jig that I made.
    Couple of the rope coils installed.
    Here I am cutting out hull cradle out of some #1 pine.
    I had one of the stablizers(?) in the wrong place and had to move and repaint.
    Interior shots of the finished model.
    I made the base out of plain old #1 pine with four coats of Minwax Wipe On Polly with a light sanding between coats.
    I ordered the name plate on Ebay. I think he did a good job.
    To be continued in the next post.
  7. I have completed the Armed Launch and will post the few photo that I took along the way.
    This was an older kit. There wasn't any laser cut parts and had to be cut with a scroll saw. This is the transom decoration pieces that had to be cutout and shaped.
    I took a brake and put up some shelves to put some of my tools on. I got tired of having to dig in a closet or floor for a tool. I eventually add another shelf under this one.
    Couple of the barrels that came with the kit. The one on the left I sanded the prefinish off so it could take the stain. Panart probably buys them like this. I also painted the bands black not shown.
    This is a shot of one of the tubes that had to be fabricated. The construction was straight forward. A pedestal like thing was made and you had to glue cut planks around it.
    Another shot of the same
    The blocks on the right is what the blocks looked like out of the kit. The ones on the left is what they looked like after I reworked them. I don't have a block sanding drum. So I had to do them by hand. Then I stained them in Minwax Golden Oak.
    Here I am making the sail. I just glue the rope on to the sail with Tacky Glue and rolled it on. I also had to cut the sail down because it looked to bulky on the Yard Arm.
    Here I am installing the canon and the associated rigging.
    This is the tiller with the rigging installed.
    This is ten photos, so I will continue with the next post.
  8. 22 hours ago, mtaylor said:
    Russ,
    Have a look at the build logs here on MSW also.   They will be a big help.
    Yes, I have and have bookmarked most of them for future reference.  They will be a great help as well as the links provide by Backer.
    Before I start I need to put up some more shelves in my work shop (spare bedroom).
    And I am recovering from "lazyitis". 🙂
    Some days I have to kick myself in the a$$ to do something.
    RussR
  9. On 10/15/2020 at 7:52 AM, Backer said:
    The Billings Vasa has its shortcomings, but you  will enjoy building it.
    These links are very helpful
    http://www.wasadream.com/Index/indexenglish.html
    https://sites.google.com/site/clayton707/vasa1628
    Thanks look like great resources for my built. I am sure I will utilize them a great deal. I don't want this to be another model without regard to the real ship.
    RussR
  10.  I received the Billing Boats Vasa sometime ago. And I have completed my Panart Armed Launch. The only thing now is waiting on an engraved nameplate. I will update my log after it arrives.
    The decision now is, do I build the 1/350 Titanic (plastic) or the Vasa. My 20-year-old son wants me to start the Vasa. My lining is to the Vasa.
    The quality of the Billing Boats material isn't up to some of the other five kits I have built. But I knew that going into it. Up until now, I have been an out of the box builder. So I have some research ahead of me. If anyone has a resource that would help,  I would like to know.
  11. On 10/13/2020 at 2:57 AM, grsjax said:
    Great kit.  I would take it but I already have one in my stash.  List it on eBay for $100 and it should sell pretty quickly.
    I just sold two new Model Shipways kits that I lost interest in on eBay and was able to recoup what I paid plus enough to buy lunch (no big deal).
    https://www.ebay.com/itm/114430221299?ssPageName=STRK:MESOX:IT&_trksid=p3984.m1561.l2649
    https://www.ebay.com/itm/114430215984?ssPageName=STRK:MESOX:IT&_trksid=p3984.m1561.l2649
    I have found that if you open the bidding low enough (about 25% of retail) you can generate a lot of interest. And if you package it up weight and measure it then use the Ebay shipping calculator (and not try to screw the buyer). You have a real good chance of selling what ever you are selling for a good price. This goes for anything you might want to get rid of.  The perfect scenario is you get two or more bidders in a bidding war. Of course if the bidders don't show up you are obligated to sell at what ever it goes for but at least I got rid of some of my junk. And believe me I have a lot of junk.
  12. Well, now I have done it.
    Yesterday I checked, the sale had ended, the price went back up. This morning I checked my cart, the price went back to the sale price. So I bought it. I got what I wanted for almost half of what another well known US supplier offers the same thing.
    Thank you, Modelexpo.
    However, I won't be starting this project for some time.
    I need to finish the Armed Launch and the Titanic.
    My thinking was I didn't want to fill up the house with a lot smaller/simpler models.
    That is enough to last for at least a few years.
    Thanks to all for your input and interest.
    RussR
  13. On 9/26/2020 at 7:27 PM, RussR said:
    And if I wait long enough this will pass and I won't have to do anything.🙂
    The sale ended last night. The price went from $300 back up to $470.
    That was a close call saved $300. 😊
    It wasn't like I didn't have anything to do.
    I have my Armed Launch to finish.
    And after a few months, I picked up a new 1/350 plastic Titanic for $45.
    Until I get a clean slate, I won't be buying anything for a while.
    RussR
  14. On 9/26/2020 at 10:27 PM, mtaylor said:
    I thought the plastic was an advantage as they're crisper than most metal parts and also the reworking to get them to fit the curves.  A little hot water goes a long way to improve the fit.    I used cherry wood (very thin) over the kit planking and it came out quite well.
    These are my thoughts too.
    I have some cherry and some walnut that I could ripe if the planking didn't turn out to suit me. But I need to get more practice cutting my planking.
    RussR
  15. On 9/26/2020 at 5:41 PM, rshousha said:
    There is much less wood in the Billings kit and many parts are plastic that are metal in the Corel kit. Some people swear by Billings kits. Others prefer the double-planking on the Corel.
    That is a good reason for the price difference. I do appreciate your view.
    I would think that the plastic parts could be an advantage if they didn't fit well. I could change the shape of miss shaped plastic parts a little easier than cast metal.
    An as far as less wood in the Billing kit, I think I can buy a lot of wood if needed for the price difference.
    I haven't bought anything yet. So if I wait, this will pass, I won't have to do anything.🙂
    Thanks again for your input.
    RussR
  16. On 9/25/2020 at 10:24 PM, Gregory said:
    Have you checked out the pricing at  Cornwall Model Boats ?
    I have checked Cornwall. Their price for the Billing kit is US$359.99 plus shipping and taxes.
    ModelExpo has an end of summer sale.
    https://modelexpo-online.com/End-of-Summer-Sale--Deals-and-Steals_c_311.html?viewall=1
    20% off everything on the website (including the sale items) and 25% off orders over $600.00 plus free shipping on orders over $100
    The Billings Kit works out to a few dollars less than $300.00 with free shipping.
    ModelExpo has PDF instruction for download. But they are in Dutch (I guess). So I ran them through a translator. They are typical kit instructions.
    I don't work for ModelExpo.
    My question remains: Why the difference in the price of the Billing Boats Kit and the Corel Kit?
    Thanks,
    RussR
