svein erik
Everything posted by svein erik
  1. Thanks, but I havent got the zapon on yet, so I think I will destroying the patina?
  2. Thanks for the liks, Finish the rudder and the Tiller (its not glued on yet ) but I did a horrible mistake on gluing the gudgeons to the hull and it cant be re dunn😲 Not without ripping of copper plates. ... I used wrong glue CA , so am not doing that the nex time 🙈🙈🙈, and also do Not build when you have the man flu .😷I did try ,now you can see how that went 🙊 but a question , Wats the best way to glue the gudgeons to the hull ? Svein.erik
  3. And something else ! I did say erlyer that my nex build is the cheerful, but thats on hold wat am going to start is scratch build the M/S Rogaland its a Coast ship and was buildt in 1929 in Stavanger so it a local ship . I have a meeting nex week with the foundation about the drawings so I can start planing the prodjekt for now I do Not have ide of scale and I my have many questions also😲 If some out there has seen the movie Dunkirk then you have seen the ship. I wil not start a logg for now but I wil do wen I start on the prodjekt nex year. Svein.erik
  4. Thanks everyone for the likes! I did get the zapon in my local store so now am good to go!! Svein.erik
  5. Thanks everyone for the likes and thanks dubz , Peter for the tip😊 I did also some no no (🙊🙈steeling a taco board) from the kit hen now I can turn the model when I need and also have some Items in the taco slots 😊 Svein.erik
  6. Wooo😉 😱 thanks dubz for the Quick respons befor I realy sendt a pm😊 I wil get zapon !! Svein.erik
  7. Thanks peter😊 And yes thats my nex questions , since it my first copper hull plates wat is the best way to seal and sealer to used ? Svein.erik
  8. Thanks everyone, Here is the finish result of the cradle ☺now I can move farword with the dekk fittings etc!
  9. Making the cradle using boxvood sheet from chuck, 1/8 for now its only dry fittet and need some more love . I also drill a hole in the center of the cradle so the brass tube goes in and the cable is going down to botten. Svein.erik
  10. Spiling the planks are needed and am not a first class planker bu I do try to get there, am using chuck's method lining off the hull ,this I used on my syren and also for my next,and next I yust jump into it and if I fail with a bang I yust start again, for me it was or still is the best way to learn. Its yust wood so it can be replased 😊and do look at chucks models how he planks them, my gol is to be better then him.... LOL 😭 Svein.erik
  11. Hi Frank have you take a look here! maby you have already? You maby have to re-do the planking. Svein.erik
  12. Thanks everyone, yust resive some wood from chuck (boxvood ) So I can make the New headrails 1/8" and also cradle am working on (drawings)😊 Svein.erik
  13. Thanks for the liks everyone, Still working on the hooks!! here is my next result 6mm and 4mm hook one of the 6mm I tvist the eye around ☺ Svein.erik
  14. Making more mast etc, for now yust tappering them all , drilling holes for the eye bolt using a templates and trying to make a hook or something like a hook, LOL Svein.erik
  15. Thanks Jim , I was thinking about that 😲, So I deside to wait as long as I can and make all the mast etc , Then maby yust maby .... it wil survive. LOL Svein-erik
  16. Thanks for the liks everyone 😄 working my way around, did some more dekk fittings (everything is made of boxvood )when dunn I put everything away for later. Then start with the corronades. and I also started the constitution of the bowsprit (not boxvood this time) Svein.erik
  17. Ok, I did have to try making new using boxvood sheet, so I did 😄 And here is my first result with carving. (Photo 2 is boxvood vs basswood ) Svein.erik
  18. Some more work has been dunn to the hull, but am looking at the headrails constructing and there are no laser carving 😲 These are small and made in basswood, its going to be hell on eaght to carve without nothing to go on, I took one out and make a pensel mark insted to see how it looks, wel.... I do Not now.... maby I have to make these in boxvood? Svein.erik
  19. Yes it need some work, but I wil do try it out, my next build is the 1/4 cheerful so it Mayby good for this model, so wen I get the tool home I wil see if I can get the pin off maby make it small or have different sizes 😊 Svein.erik
  20. Thanks for all the good way's for making pins😊 but first I wil try the Beadsmith-one step looper tool (1,5mm) you can get 2,25 and 3mm also. Svein.erik
