svein erik
Everything posted by svein erik
  1. Yes I did also feel so, here is a photo of the corronades with 2.5mm Canon ball , it fitts😁
  2. Working my way in to .... dekk fittings weel from syrenscompany. The pumpe is nerly finish etc, but I did drill the hull for the Canon ball ,eeee it sems to look to small so I try with bigger 2.5mm and tested it in to the 18 punds corronades from cadlecraft (it fitts ) Maby I use this insted 😊
  3. Hanks chazz Do you have a photo? Svein.erik
  4. I have to do some mor test so I did find some pins from artesania kit I had and tested with to sorts of blackening liquid, I did also try it on a tube from K&S (the result speek from it self) The pins I have from ME (syren kit) has to be made from ....... it is crapy 😲
  5. Hi chris no I havent, but t think I wil do so, but I think I need a nose pilers thats nerow to make them small to match the 1/64 scale 😊 Svein.erik
  6. Hi Dos anyone know's were the kit eyepins from ME is made? the brass eyepins thats comes with the syren kit Seems to be different or crapy one, I have dunn the blackenig befor with good result, but this time it Seems to not stikk I did try acid dip first and so on... but its turn out the same 😲( I used carr's) Svein.erik
  7. Thanks😊 thats wat I was looking fore, am waiting for the book , lennarth petersson about rigging. but I like the photo,now I can see how it looks😊 Svein.erik
  8. Hi Jim I think I did find it out , a sling on the yard , this wil be atatch to a bigger sling from the tristletree then a rope is run true the blocks opp around the tree true som mor blocks something like that.... Se photo Svein.erik
  9. Hi a questions about the rigging of the main/fore lower course yards (brig syren ) There is a block where the sling is ( sling cleats) Is this rigged be side the sling or is this one of all? Svein.erik
  10. Some info of the ship Svein.erik
  11. Hi, and thanks again for the liks, am trying out my New tool, so I started making some mast the main and fore lower course yards I thing it looks nice when rigg😊 Svein.erik
  12. Hi folks😊 The syren is coming a long now, the hull /copper plates are now looking old and used may needs some repers soon on the slip, LOL I did also finish the conpanionway construction left the dor out for now so I dont damige it. Everything is not glue to the dekk yet. Svein.erik
  13. Thanks for the likes am now ready to mill my own planks an other stuff, and also the lathe for the mast 😊 the tool is proxxon! Svein.erik
  14. Yeee, I have finish the copper plates now , Wat a task 😊 I also made a New stamp for the dressing belt etc and am happy with the outcome since its my first time to copper plates 😊
  15. Thanks for the comments Jim and sal I wil try to use a roller😄 I wil post photo wen the copper plates are finish 😊 Svein.erik
  16. Dam this is a nice pice 😊 did the center board have an open space on each side to let the water run true ? Svein.erik
  17. Thanks for that Thomas Am just back from a trip and ready to copper again , finish it but it Seems to me the plates a slipping 😲 I used sanding sealer befor I started the task maby it was a wrong idé? And I have also only used gloves for this task. Svein.erik
  18. Hi everyone 😊 Befor I take the task of finishing the copper plates I needed a brake, so I pre made some dekk fittings (not finish yet) Gratings are from syrenshipsmodellcompany Svein.erik
  19. Finish 😅 one side, more to go before the copper plates is dunn! Svein.erik
  20. Thanks for the liks everyone, my plating is going forward, it was much easier then I belive, but am not finished yet I hope my curve on the plates is going g to make a problem to me, specialy at the bow! Svein.erik
  21. Thanks for the liks and comments I started the copper plating now , its my first time for this and I hope it goes well😉 Svein.erik
  22. Thanks for that Jim The dekk needs more cleening, but do that later wen the last nails are dunn I wil drill some hulls on both ends of the hatches . Svein.erik
  23. Thanks for the liks and comments I yust finish the treenail on the dekk, I need some more later wen the hatches is in place I used #77 drill bit for this and some wood filler (darker one) and I used 2 hull in one plank Soon I starts on the copper plates 😶 yeee. .... Svein.erik
  24. Grait build, Its Soon for the mast and rigging 😲 take care! Svein.erik
