gsdpic
Everything posted by gsdpic
  1. My steering works fine. The suspension, not really. The front wheels move up and down a bit but I think that is mostly (or maybe entirely) due to the looseness of the connections that snap together. Fortunately the kit has small, clear disks that sit under the car to support most of the weight of the model and provide an appropriate ride height.
  2. Nice build. Brings back memories....I recall being a kid in the '70s and I went thru the phase where I had a keen interest in trucks. Any time we were out on the highway, I'd be looking out the window identifying the Freightliners, Kenworths, Peterbilts, Mack, etc as they went by the other direction.
  3. Looking good, glad you are overcoming your mishaps. And yea, the suspensions and exhausts on these F1 cars always seem to be fiddly to assemble, three or four hands would be useful to have.
  4. Looking good. A few posts ago you said it was "slowly shaping up" but from my vantage point it is moving along pretty quickly.
  5. Wow that looks like a detailed kit with a lot of parts. I'll follow along to see how it goes. I think the only airfix kits I have built were some tiny WWI biplanes that had about 15 parts each.
  6. @JacquesCousteau @Ronald-V @LoydB @Glen McGuire Thank you all for your comments, appreciate it.
  7. And now, the Friendship Sloop is finished! I believe that this marks the first Bluejacket Friendship Sloop build log that went all the way to the end, though I believe at least one other builder completed the build without completing the build log. So, I hope, at least the last few posts that were not covered by anyone else may be of help to someone in the future. And of course, many thanks to those who followed along and hit the like button, much appreciated. Overall, this was a good kit that I enjoyed building. I finished it in just under a year, though during that time I also built a few plastic car models, so I took several breaks. My kit was missing some of the strip wood but of course Bluejacket was quick to remedy that without any issue. Overall things went together fairly well. As noted, planking would have been easier with a few more bulkheads but it was still possible to get a reasonable hull shape and the fact that most people will likely paint the hull helps as well. I generally built this out of the box, did not add or change much at all. Though I did come to wish that I purchased some third party rigging line. I am not crazy about the slippery, plasticky (polyester I assume) white line that Bluejacket supplies, that must be dyed if you want a more traditional tan color. It also tended to unravel quickly so I used a lot of CA to hold together the ends of the line. I had a small plastic bottle that contained some Rit brand brown dye and water. My usual procedure was to unroll enough of the cord for the next line, put some CA on the cord where I planned to make the cut and wait a minute then cut the cord. I then dipped the line into the dye briefly and pulled it out, running it across an old t-shirt to dry it and remove excess. I then let it dry some more before putting it on the boat. I actually used up all of the thicker cord that was supplied with the kit. I also, in the last steps, realized there is definitely some art to creating rope coils, and I have not yet fully mastered that art. And as I was creating the last couple of coils I was somehow reminded that the scale is 1 inch equals 1 foot and I was making rope coils that were about a half inch across, so probably well undersized. They likely would have looked better if they were at least 3/4ths of an inch long. Anyway, here's one picture of the completed model. I'll go create an album in the gallery with several other pictures. Again, thanks for reading and following along.
  8. As always, thanks for the likes. I've now added the lazy jacks on the main sail and also added the two front sails. I have pretty much completed the rigging, though as you can see, nothing is tied off. The lines are just hanging loose or in some cases weighted down with spring clothes pins. The installation of the front sails went well, though I did chop off about 3/8ths of an inch of the jib club (the plans refer to it as a jib club even though, I think, it is attached to a sail referred to elsewhere as the stay sail. I am not a sailor so don't really know one from the other). I meant to mention last time that it was odd there was no sort of parrel specified for either the gaff or boom. The plans showed both with jaws, and showed a hole at the end of the jaws, but I did not see any mention anywhere of a parrel to hold the gaff or boom to the mast. In my case, the jaws were just barely wide enough for the mast, so it was a bit of a friction fit, but I did add a small piece of copper wire between the two holes in the jaws to further hold the gaff and boom in place. I think I will redo the main sail out haul along the boom, as I just figured out that I did not do it correctly. Then I will tie everything off and form some rope coils in appropriate places, and look for any other finishing touches. But I fully expect to declare this one done in the next few days.
  9. Great recovery! That picture of the air box really shows off your fantastic finish.
  10. Thanks for the likes or for just stopping by to take a quick look. I've now attached the main sail, along with the boom and gaff. I still need to tie off and trim some of the rigging and I need to rig the "lazy jacks". Then it will be on to the two front sails which should be much easier to rig, so I am getting close to the finish line.
  11. Strange that the reaction only happened where the black number decal was. Maybe it was somehow related to having two layers of decals there. Otherwise, the finish looks fantastic. Good luck resolving the issue with the bubbles on the numbers.
  12. Welcome Andy. Also check out the forum sponsor Evan Designs. The sponsors are listed on the lower right hand corner of the main home page, at least in a PC browser. Evan Designs sells LEDs for lighting various projects (ships, doll houses, other models, etc) and also has some how-to info.
  13. Wow, been almost a month since I last posted. Thanks for the patience of anyone following along. Of course in that month I made another tangent 🙄: But now I have sown the sails. I used pretty much the same technique as with my America build, and I documented it in that build log so won't bother doing so here. I do need to still punch some holes where the sails are attached to the various spars and need to add the reef points. But then it is on to the simple running rigging to get the sails attached.
  14. Off to a great start. That polished aluminum on the interior is looking especially good. I used matte aluminum on mine. The replacement JPS decals look good too....the gold color looks pretty accurate. As I recall when I built mine, some of the third party decals looked more like yellow and not so much like gold. Your upper cowl looks good too; mine had a bit of twist/warp to it. Anyway, you are bringing back some memories. I am looking forward to see what you do with the kit, I am sure your efforts will outshine mine.
  15. Well I keep going off on a tangent from my Friendship Sloop to build another car, trying to reduce my stash though I keep buying more for some reason. Below are a few pictures of Revell's 1969 Chevy Camaro Z/28 RS. As you can see in the last picture, I used the same color as on my mid 80's Porsche 911. It is actually a Porsche color but I figured it was close enough to Chevy's LeMans Blue metallic. Thanks for looking, hope you enjoy. I swear I'll drag that sewing machine out and make those sails for the sloop.
  16. Glad you came back to post the final pictures. Very well built, very attractive build. The stained wood, red window frames, and blue/gray top all look great together. I lived in Raleigh long ago....sounds like about the time you moved there. I was there from 1989 to 1997. Went to grad school at NC State then worked in the area for about 6 years before transferring to Austin.
  17. Wow, the paddle wheel looks great. I imagined it was a bit larger until I saw the picture of your hand holding it. That was quite a project on its own.
  18. The whole build looks really good, but the finish on the main prop is really outstanding, with the wood, yellow paint, and three different metal colors, and just the right amount of shininess.
  19. Just catching up on your build. The finish looks great. One of these days I'll get serious enough about modelling to wear gloves while handling the under construction build.
  20. Well done Glen, amazing work! As for Johnny's suggestion.....I think you should model that list picture and have the whale boat glued to the top of the inside of the bottle!
  21. Looks great from here. And I agree with your earlier comment about the pre-printed tires....they look good and add a lot to the model.
  22. Looks great, like you are overcoming all the challenges well. That rear suspension does look like a delicate and fiddly piece.
  23. Been a bit since I did an update, but I now have the standing rigging complete. I started by painting the traditional metal blocks and deadeyes that Bluejacket supplies. I used some primer first then a couple different flavors of Tamiya brown paint. It works ok though as usual, it can be easy to scratch off the paint while handling the blocks or deadeyes. I then attempted to start the rigging using the thin stranded copper wire supplied in the kit but I was not happy with it. It was difficult to work with, unraveled when you cut it if you did not first put CA on it, difficult to fasten, and I felt it was too thin. It was a quarter millimeter so full size that would just be 3 millimeters in diameter, less than an eighth of an inch. So I dug into my stash of stuff from earlier projects and found some beading wire and crimp tubes. It was also multi stranded but coated in clear plastic which held the strands together. I think the plastic also gave something for the crimp tubes to bite into. After crimping I also put a dot of CA on but I am not sure that was necessary. Anyway, there were only about a half dozen bits of standing rigging, so once I got into it, the job went pretty quick. And yes I realize that I should have had the chain plates leaning forward, more in line with the rigging, but too late now. Thanks for looking in. I guess it is now time to get out the sewing machine and start working on the sails.
